Question about Stihl Ts 410 420 Cut Off Saw Decompression Grommet
Ts410 cuts out whenmachine is tipped forward anybody else have this problem?
Ts410 wont prime
air leak in fuel system \ one of the pipes blocked (the return pipe that goes back to the tank) or pipes on wrong
May 08, 2014 | Stihl Ts 410 420 Cut Off Saw...
Stihl saw cuts out when machine is tilted forward on ts410 anybody else have this problem
Fuel pick up will be your problem. Buy new fuel filter and fuel line from in tank to carby. Most likely a split in the fuel line in-tank
Feb 13, 2014 | Stihl Ts410 Ts420 Cut Off Saw Piston Kit...
Stihl Ts410 hard to start and erratic running
http://www.mediafire.com/download/dk8dipzr69pksrk
I've added the breakdown manual for you, have you replaced the fuel and air filters. could be a simple issue of not being able to draw up the fuel from the tank. Stone saws deal with a lot of dust and this seriously effects their running and also their cooling capabilities.
Jan 31, 2014 | Stihl Saws
Starting ts410
This might be an ignition problem... Try setting in new fuel if that doesn't work take it to the shop.
Nov 21, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
2 year old TS410 no power recently, was serviced , correct mix but dies when pressure comes on ,blade stops, starts fine and runs idle fine-tom
Hi Thomas its probably had its high/low screws reset and whilst it runs fine on the bench under load its running weak try unscrewing the high screw out a half a turn
Aug 16, 2013 | Stihl Ts 410 420 Cut Off Saw...
Ts410 stihl saw stopped working
Starting procedure for Stihl.
(cold starting)
Place cutoff saw on floor (flat clear surface).
Hold throttle in, while pushing on switch all the way down.
Hold cutoff saw firmly.
Pull starter handle until saw fires, it should then cut out.
Click the starter switch up 1 click to half choke.
Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Mar 31, 2013 | Stihl Ts410 & Ts420 Cylinder & Piston Kit
When fitting coil pack on my stihl ts410 what size gap do you leave?
The thickness of a stangard business card. .010-.015
get a free manual from a Stihl dealer like www.arcolawn.com
Dec 27, 2010 | Stihl Ts 410 420 Cut Off Saw...
Stihl Ts 410 420  Cut Off Saw Decompression Grommet Logo
57 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
rlev_7
Level 1 Expert
Spud Howell
Are you a Stihl Saw Expert? Answer questions, earn points and help others
