Question about Toshiba TEC B-472 Thermal Label Printer
Error sign shows On Error shows: SG;0015,0404,044 after press restart shows: SG;0015.0036.048
Tec B-472
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
Change graphic settings to 8 bits or 4 bits instead of Topix compression in the driver.
Firmware too old to understand the instructions.
Posted on Jun 10, 2014
  • 300 Answers
SOURCE: tec 472 qq no print
First of all can you print just from the printer ie
Turn on the power while
holding down the [FEED]
key and [PAUSE] key?
Posted on May 18, 2008
  • 300 Answers
I can only guess there must be a problem with a setting either within the printer or your pc. It's unlikely to be a hardware fault as the printer self tests ok.
I have repaired quite a few of these printers, but haven't had your problem. I can only suggest your compare the settings (baud rate etc)
Posted on May 19, 2008
SOURCE: TEC 472 QP PRINTER
Try with CUPS --- oh, sorry, it's for Linux only, my bad
Posted on Sep 10, 2008
SOURCE: TEC B 472 QQ
Swapping the parallel port to the printer should allow it to connect via parallel. Run through front panel diagnostics before/after install. depending on firmware it will tell you if the parallel board is installed.
Posted on Mar 26, 2009
  • 254 Answers
SOURCE: TEC 472 Error message- SG: 139, 0010, 064
This is syntax error, the coorect is SG;0139,0010,064....
Posted on Sep 04, 2009
Error sign shows On Error shows: SG;0015,0404,044after press restart shows: SG;0015.0036.048
If you are using a windows driver do not use Topix in the graphics.
Use 8 bits or 4 bits. The firmaware may not be able to understand the Topix algorithm. What you have is a syntax error displayed.
Feb 13, 2014 | Toshiba TEC B-472 Thermal Label Printer
Error sign shows
this is syntax error .
Check firmware version
- Topix grahics with firmware version 3 or higher
- Use compress or ascii graphics in the driiver
hope this helps
Aug 24, 2012 | Toshiba TEC B-472 Thermal Label Printer
Tec b-472 gap sensor
use detection transmissve in the driver
Aug 13, 2012 | Toshiba TEC B-472 Thermal Label Printer
TEC B 572 WHEN USING DATA TRANSFER SWITCH BOX.. ERROR CODE SG;0040,1120,1384,00 APPEARS ON 1 MACHINE.
This may be a firmware problem! or problem on the communication port
This is a syntax error detected by the machine
Aug 01, 2011 | Toshiba TEC B-472 Thermal Label Printer
I have a tec b472 printer that is showing and error message that reads - XR;0297,0000,029 Can you tell me what it means
This is a syntax error.
The XR; xxx is to clear a portion of the print image
There is an error in geration this instruction
Reason may be the square drawn is off the label size.
Check the values
{XR;XXXX,YYYY,ZZZZ,AAAA'}
where
XXXX = X start coordinates in 10th of millimeter
YYYY = Y start coordinate
ZZZZ = End X coordinates
AAAA = End Y coordinates
Jan 10, 2011 | Toshiba TEC B-472 Thermal Label Printer
I am not able to print to a local printer TEC 472 on LPT1. I get no error.
The B472 has a contronics SPP mode parallel
Check that you have the correct settings on your computer.
Besides take care the DB25 is a serial connection with
9600,n,8,1 setting by default
Jan 03, 2011 | Toshiba TEC B-472 Thermal Label Printer
Sg: 0284, 0046, 017
Syntax problem
electrical problems or use of topix graphics with a firmware not accepting the commands.
Use 8 bit graphics
May 12, 2010 | Toshiba TEC B-472 Thermal Label Printer
May 09, 2009 | Toshiba TEC B-472 Thermal Label Printer
TEC B 472 QQ
Nov 09, 2008 | Toshiba TEC B-472 Thermal Label Printer
TEC 472 QP PRINTER
Jan 08, 2008 | Toshiba TEC B-472 Thermal Label Printer
Toshiba TEC B-472 Thermal Label Printer Logo
121 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
