My Newlec Electronic 7 system is heating up the water but it does not keep the hot water for long. The boost doesn't seem to work either. this is happening since i reset the timer 3 months ago. I've changed it then to winter clock and put the extra couple of hours of heating in the afternoon as i was having guests so wanted make sure we'll have enough hot water. I did set everything back but now when i have shower in the evening i need to rush in order to avoid cold shower. I tried different settings. I now have the boiler set to go on at 1am till 5.30am, then 3pm to 5pm and again 7.30pm to 8.30pm. It use to be set for few hrs at night & the couple of hrs in the afternoon and was enough for washing dishes, shower or bath etc. now with the extra hrs it doesn't last.
3 Suggested Answers
  • 1340 Answers
SOURCE: Hi there, I just moved
There should be an access panel on the water heater.Take it off and check the temperature setting.If there is insulation covering it,just cut a **** in it,about near the middle toward the front side facing out from where it is,or it could be on the side.Sometimes when a house is on the market,if they turn on the power for shows,the water heater will be turned down completely because it's not being used.If that doesn't work,it ost likely needs a thermocouple.If this does not solve it,please do not approve/disapprove this yet as it will cut off our link,unless your problem is solved 100%.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Good luck,Greg
Posted on Dec 02, 2010
  • 8404 Answers
SOURCE: my boiler heating is working
As I understand your question, you have a boiler with a 'summer/winter' hookup for domestic hot water.
Your boiler should run all the time, i.e. not be shut off by you. Your boiler provides hot water for baseboard heat in your home ... possibly through several 'zones' each controlled by an individual thermostat and circulator. Yours may be a steam system. If this is the case, you have radiators not radiant baseboard heaters and no circulators.
Your summer/winter hookup provides a constant supply of domestic hot water. It does this by taking cold water from your water main and passing it through a copper coil which sits inside your boiler and then to your hot water main in your home. Since the coil sits in the hot water at the top of the boiler, it is constantly being heated. This coil may be in a deteriorated condition in your case or it may be too small for your needs.
Several years ago, I did a small upgrade to my mid 1950's era American Standard boiler. The summer winter hookup in my case was mounted on a 4 inch cast iron boiler plug. The coil was 12 feet long (folded up to a package about 1 foot long). I was very afraid when the plumber came in with what amounted to a 10 foot long pipe wrench. My fear was I would have a pile of broken cast iron at the end of the day. All is well that ends well. He got the old one out and replaced it with a coil that consisted of 20 feet of copper tubing 3/4 inch in size (the folded tubing was about 20 inches long and fit nicely into the boiler). We now have all the hot water a household consisting of one guy and three gals would need in all but the extremest of times..
I think you r answer is here ... replace your summer/winter coil with a new, bigger coil.
Something else I did. My kitchen is 60 feet (pipe wise) from the boiler. It takes a long time to get hot water there. I put in a small electric hot water heater just under the kitchen. I put a timer on it so it runs for a couple hours in the morning and a few hours in the afternoon. The hot water line from the boiler serves as the cold water input to the heater. I now enjoy the convenience of quick hot water in the kitchen with the relatively low cost of oil heated water from the boiler as a relatively small cost of electricity.
My winter settings are 160 - 200 and my summer settings are 120 - 150 which seems adequate for our needs.
Thanks for your question at FixYa.com. I hope I have been of assistance to you today.
Posted on Feb 05, 2011
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Off peak hot water not heating!!! :(
The Economy 7 can control different types heater. Some heaters do not have off-peak ... but you can solve problem..
Copy following link:
http://waterheatertimer.org/pdf/QE7-INSTRUCTION.pdf
If timer is wired to two different elements, then the night rate element or off-peak element might be burned out. Test element with multimeter.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Also this timer is wired so either Off-peak is getting power or Boost is getting power, but not both at same time.
If heater has off-peak element, then there will be a wire connected to terminal 5, going to heating unit.
If there is no wire on terminal 5, then there is no off-peak element, or wiring has not been connected. However you can change the timer function by moving wire on terminal 4 to terminal 5. Then only the off-peak timer function will operate, and not the boost.
You can also fool the timer, by setting time clock differently. Instead of setting timer for current time, rotate the dial and fudge current time by 10-12 hours so water heater thinks it's time for boost, but the actual time is during off-peak hours.
If terminals 4 and 5 both have wires, then either the element is burned out, or the timer has malfunctioned. Again, you can fool the timer by setting current time differently, and solve problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 26, 2013 | Water Heaters
I just moved to a new house and it has a Newlec NLH27. The hot water works ok but I have no central heating. Any advice?
when system is set to ON, it is just re-circulating air at same temp. first thing to try, instead of setting to ON, set to AUTO
Dec 20, 2012 | Water Heaters
Mitsubishi paragon plus error 5
job of compressor is to cool only (air conditioning) while heating is usually from the hot water from engine to radiator which circulates inside a small radiaror located inside the dash board.connected to the intake fan with the help of ducting and water control system.
i do not know what mitsubishi uses but it has to be the manual water control valve or an electronic switch to let the water run through the inner heat radiator to give hot air to the passenger compartment. in you case it seems it is electrical relay or awitch malfunction.
Aug 29, 2012 | Televison & Video
Water wont heat up unless the central heating is on at the same time and the boost button wont work at all
Need to know more about the system... zone valves ot pumps....indirect hot water tank or internal coil??
Here is a tip that I wrote that may shed some light on things for you...
In most cases problems with the circulator pump boil down to two problems.
The most common is air in the lines causing an air lock.
The next problem is that the pump gets stuck and is not running even though it may be hot and seem to be running. In this cause the pump can sometimes be taken apart, cleaned and it will work, but usually it needs to be replaced.
Here is a tip that I wrote that will explain circulator pump problems in more detail.
Heating Circulating Water Pump Problems
heatman101
Apr 22, 2011 | Heating & Cooling
I have just moved into my new apartment it as a newlec nle7 water heater with a timer, i can't get it to work, i need a user guide manual lisa
I think it is the same as the Horstmann Electronic 7 immersion heater timer. You can download it free from the Horstmann web site.
Dec 24, 2010 | Heating & Cooling
Newlec nle7 instruction manual
Struggling to get the timer sorted on the newlec nle7 to get regular hot water
Oct 28, 2010 | Kitchen Ranges
1995 ford escort 1800 petrol
cooling system is a simple pump and radiator to cool if water is not pumping or circulating check for rad blockage thermostat stuck closed. need to know more...... how bad did you overheat it??? blown headgasket??
Aug 31, 2008 | 1995 Ford Escort
Cycle stops, won't drain
This is either a bad timer or a bad heat sensor. On most cycles that call for the water to be heated it will pause the timer and continue washing/heating until the sensor is satisfied the water is hot enough. Try selecting a quick, delicate, or china cycle without heated rinse or dry. If it works this way the timer is fine but the sensor is bad. Sometimes cold water to the machine will cause this problem because the machine is not capable of totallly heating cold water. It is only designed to boost the temp. Make sure you run hot water at the sink before you start the machine.
Jul 03, 2008 | GE Nautilus 24" Built-in Dishwasher
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
