Question about TechShade - M923 Truck Parts & Accessories
Heat stopped working - TechShade - M923 Truck Parts & Accessories
  • 38 Answers
There are several possible reasons as to why you are not getting any heat in your vehicle. 1) Low coolant level; check coolant level in radiator/reservoir to make sure that it is within operating range (check with engine cold). 2) Improperly operating thermostat. If your thermostat is stuck in the open position, the engine will not reach operating temperature and the engine coolant will provide little or no heat to the car heater. Check your coolant temperature gauge on the dash to make sure that it is the normal operating range. The thermostat will need replacing if the engine temperature is still in the low range after 10 minutes, or so, of running. 3) Plugged heater core. After engine has warmed up, place your hands on the two smaller coolant hoses that lead into the firewall/heater. Both hoses should be hot (the inlet slightly hotter than the outlet) If one hose is hot and the other is only warm or cold, than the heater core is likely plugged. I would recommend a cooling system flush in this case. 4) The heater control valve is not open. The heater control valve is a valve located in one of the smaller coolant hoses leading to the firewall/heater core. It is usually cable operated, but may also be operated by a vacuum motor. Make sure valve is moving when the temperature lever or knob on your instrument panel is moved from cold to hot. If it does not move, and it is cable actuated, ensure that cable is connected to the valve arm and dash control lever. If it is vacuum controlled check small vacuum hose for kinks and leaks. Remove vacuum hose from valve and check for vacuum when heater control is moved from cold to hot. If vacuum is not present, there is a problem with the heater control (possibly a vacuum leak under the instrument panel or at the temperature control).
Posted on Feb 13, 2014
I have a Rheem Classic Super Quiet 80 gas furnace (for heat). The fan stops when the "heat" turns on.
Any time I ever had trouble,first thing to suspect is the thermostat.
They lose contact sometimes and sometimes you tap the face and they work til next glitch.
If the thermostat has some years on it,go ahead and replace it.
Can't you just leave the heat and fan in auto? That would be best,I think. don-ohio
Jan 10, 2017 | Heating & Cooling
Heat stops constantly
try changing pipesensor or thermostat they are most likley to go on a aircon let me know if it worked it should cause i had the same problem with mine till i changed the pipesensor and thermostat
Mar 17, 2014 | Daikin Heating & Cooling
Heat and air unit heat stopped working
1-Check Thermostate for setting may wrong or Th. faulty.
2-Fuse near to heating element blown, Change it.
Nov 12, 2013 | LG Electronics 23,500 BTU 230v Window Air...
Heat pump fan will not stop running
could be a heat sequencer. if the stat was bad it would run constantly in both modes.
Nov 12, 2012 | Heating & Cooling
2001 toyota celica no heat coming out
check your radiator level, as stupid as it sounds my 01 celica didn't have heat for 2 years. I was thinking it was the heat flap or something because when I drove the heat would start working and when I stopped it would stop working. Yesterday the car overheated so I checked the antifreeze and added about half a gallon. The car stopped overheating and as a side result the heater started working normally again. I did head slap and went on with life. Most vehicles have the heater core low to the floor but in the celica it is actually higher than the motor which means if fluid is at all low it won't work as it turns out.
Nov 22, 2010 | Toyota Celica Cars & Trucks
The heat in my 1999 Buick Century stopped working
could be a vacuumn device in the heater system itself, or a thermostadt problem just above the water pump, unless you have more than minium experience with repairing autos, take it to a good mechanic, should be less than $100 fix.
Mar 05, 2010 | 1999 Buick Century
Heat is sporadic. model DDE5900RALWH erial G246248G
Make sure lint filter is clean also frre airflow from Exhaust, if tisis ok could be thermostat or element, try basic stuff 1st...
Feb 22, 2010 | Dryers
2002 taurus, power windows all stopped working at once along with lighted window switches. Drivers window stuck down. Relay was hot! Also heater blows cool air, started doing this after I added radiator...
LOOK FOR BLOWN WINDOW CIRCUIT BREAKER.YOU HAVE A SHORT IN WINDOW SWITCH OR BAD WINDOW ELECTRIC MOTOR.YOUR HEAT PROBLEM IS A STOPPED UP HEATER CORES.THE STOP LEAK STOP ITS HEAT.THE STOP LEAK HAS STOPPED OR PLUGGED YOUR HEATER CORE SO COOLANT CANT PASS THROUGH IT.YOU GOING HAVE TO FIX RADIATOR LEAK AND REPLACE HEATER CORE TO GET HEAT AGAIN.
Jan 28, 2010 | 2002 Ford Taurus
Drum runs, but no heat
i would first look at the heating element. check for continuity.
Feb 08, 2008 | Dryers
TechShade - M923 Truck Parts & Accessories Logo
124 people viewed this question
Top WeatherTech Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a WeatherTech Vehicle Part and Accessory Expert? Answer questions, earn points and help others
