Question about Coffee Makers & Espresso Machines
Coffe grinder does not start anymore
My dear neighbour asked me to have a look at her very old coffee grinder, from my inspection, it all appears to be fine, just trying a wild guess in replacing the motor start capacitor, but difficult to procure it, in small quantities, anyone can shed some light?
SOURCE: Cuisinart Coffe Maker has no power
Cuisinart replaced the coffee maker. It was still under the 3 year warranty so Cuisinart told me to take it back to one of the stores that sells Cuisinart coffee makers because the store I bought it at was going out of business.
Posted on Nov 24, 2008
SOURCE: grinder does not work!
http://www.cerinicoffee.com/custompages/Tech/Grinder_Adjustments_for_Italia.pdf
Posted on Apr 12, 2009
  • 1089 Answers
SOURCE: Saeco Italia Sup021 YR flashing red malfunction light
HI
If you don't hear the grinder motor, I would say you have a disconnected grinder wire. These motors are DC so make sure that you connect it correctly or your grinder will run backwards.
Posted on May 30, 2009
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Posted on Aug 14, 2009
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
  • 22 Answers
SOURCE: A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Posted on Jan 31, 2010
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
Jura ena don't grind coffee
new grinder teeth
Dec 27, 2013 | Jura ENA 3
DCC-790 Cuisinart coffe maker won't grind
what showing on display ,when push to make coffee? If showing grinder block-then you have to replace the grinder to fix it. Try to grind coffee ,but without beans-if grinder start but rotate slowly -you have to replace grinder and change the brushes of the motor.
Oct 04, 2013 | Saeco Royal Professional Espresso Machine
Coffee comes out too slow
hy
only one couse for that
the coffe is to fine
ther is a scrow on the coffe hube shoes fine and grosso
start one esspresso order and move the scrow tho the grosso side withe the grinder moving
Aug 10, 2013 | Nuova Simonelli Microbar Espresso Machine
Kpcg100np1 kitchenaid coffee grinder purchased used (working) arrived with two shattered parts: the selector knob and the finger guard. Have replaced the knob. Unfortunately then discovered finger guard...
I have a parts exploded diagram this will be beneficial in disassembly i am sure please go to the link below and download the PDF file, you need Adobe reader to view it. Sometimes in the shop, we will Ahem... break, smash, the "Old" bit to get the "New" bit installed, sometimes there is no other way, however. But of course if you can take it down completely, that is best. Anyway have alok at the diagram, that should give you a heads up.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212130.pdf
Mar 16, 2010 | KitchenAid Coffee Makers & Espresso...
Grinder starts up but wont grind..nothing happens. one week old
I think this might be because no beans have gone down into the mill. There is a definite difference in sound when it is actually grinding beans. Try emptying the beans out, set it to the coarsest setting, put the beans back in, shake the thing a bit then turn it on.
Jan 17, 2009 | Krups Burr Coffee Grinder
Grinder runs with NO beans inside
Fill beans before they run out!
If you hear the grinder running empty, press the same button you pressed to start making coffe to cancel the current cup -or, if some beans were ground, stop the water a bit earlier to make a shorter coffe using the same method (press the button you pressed to start the cup). The auto-detect of beans missing is a very minor and largely useless feature.
Jul 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
From 1-7 on the coffee grinder, which is the finest grind.I Hve misplaced my manual
If you take of the bean hopper and the adjustment pin, then you can turn the outer ring clockwise 4 step.
Check also that the ring not is loose.
Jul 15, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee watery
Setting your dose at max and grinder at finest is not good. This means that you are asking the machine to grind coffee really fine, and then dose maximun amount which can lead to the grinder getting clogged. If you are looking for stronger coffee, it is best to have several shots that one that has too much coffe and too fine. For stronger espresso, use less water instead of more coffee. Two shots of 2 oz. espresso (made with 7 grams of coffee) are more flavorful & sweeter than one shot of 4-oz. espresso made with 14 grams of coffee which could clog your grinder and door/channel. At this point, you need to clean the grinder ( inlcuding the door/channel). I suggest you have an Authorized SAECO Service Center check your machine. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Jun 15, 2008 | Saeco Caffe Charisma Espresso Machine
How do you take a bosch coffe grinder apart?
Using a screw driver or the old butter, pry off the bottom piece.  Be careful though, getting it back together is really tricky if you don't pay attention to where all the parts go.
Feb 05, 2008 | Bosch MKM 6000 Electric Blades Grinder
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
