Question about Sony Playstation 3 (PS3) Console
Unable to search on internet through ps3
Ive connected up the ps3 to my modem with the correct type of cable, i can play online against people worlwide no problem, i can also access the playstation storeĀ  all works ok , however when i want to browse the internet no matter what i type in it, it comes up with no results, i have done a internet test (via the ps3 main menu) and it says all is ok, is there something im not doing or have done wrong , any help would be most greatful. thanks
  • 4 more comments
  • paul1976 Nov 09, 2007
    No search found is what comes up on the screen every time i try to use the interner would appriciate some help with this problem
  • keocher Dec 02, 2007
    I have the same problem. My connection is fine and the playstation network seems to be working ok but if I try and search a web page it just tells me that no search is found.
  • Anonymous Jan 31, 2008
    I have the same problem any help? Rob
    me too
  • faolanhanna Feb 15, 2008
    i have the same problem
  • Anonymous Feb 19, 2008
    i have the same prob has anybody got answere
Press triangle then change your homepage to www.google.co.uk
Posted on May 26, 2008
Same goes for me can do all online games n wat not but wont let me surf the internet
Posted on Jan 06, 2008
I have a PS3 slim console and it is having some internet problems that I cannot figure out. I have a CAT-5 ethernet cable plugged directly into my modem which is directly connected to my PS3. Many times...
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Nov 07, 2010 | Sony PlayStation 3 Slim Black Console
I am unable to connect to the internet as it is not accepting wep code
If you are using a router, the problem probably has to do with the router. In order to find out, disconnect your PS3 from the router and plug it directly into you modem. If your modem is not near your playstation 3 then move it close to the PS3. The modem plugs directly into your cable line so there is a good chance that the television you play your PS3 on has a cable connection. One you have connected your PS3 to your modem, press the reset button on the modem. Turn your PS3 on and go directly to your network settings. Click on Internet Connection Test (do not bother trying to set up a connection manually) If you are getting a connection then you are ready to go.
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
How to get it online with a ps3? I hooked it up to the ps3 with the Ethernet cable. It says connection failed .but it wont go online. Any help would be dearly needed. Thanks
First test the Internet connection by connecting a LAN cable from your DSL or cable modem to your computer and see if you can get into the Internet.
If you can't access the Internet then phone your ISP and get them to test your connection to your modem.
If the Internet connection is OK then click on this WEB site and follow the instruction to configure the PS3 :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Jan 01, 2010 | Arris SURFboard SB5101 Cable Modem
Had my ps3 for year and half now, never played online (80710102)
Ok first off create a psn account online via computer, this is free of charge. Then after that connect your ps3 via cable to your modem. turn it on and access network settings. Then select internet connection settings, select easy. After it is finished select test connection. Should this time out it means you have a faulty connector somewhere, try checking your cables and the ports on the ps3 and modem. But if it states connected, back out and go to network via your ps3 dashboard then select sign in and enter your account info from your psn account.
Dec 08, 2009 | Sony Video Game Consoles & Games
How to hook Cricket USB Broadband Modem to my PS3
is it possible to connect my ps3 to the internet using cricket broadband modem?
May 03, 2009 | Sony Playstation 3 (PS3) Console
How to connect an online games in ps3
if u want to connect to online gaming u will need to first register on the playstaion network.
Dec 11, 2008 | Sony PlayStation Portable (PSP) Console
Ps3 online
gucciskills, this is a common problem if you have other people using your home internet connection at the same time. I have that problem every now and then even with no one on the home PC. It just means you are losing your connection. Try and reconfigure your router setting and see if that helps.
Jun 02, 2008 | Sony Playstation 3 (PS3) Console
Ps3 Unable to obtain IP address and connect to internet
maybe the modem set is different from the modem in the lap top in other words maybe you ps3 needs higher and better connection
Mar 31, 2008 | Sony Playstation 3 (PS3) Console
Connecting to the Internet
Turn off the PS3, unplug the power to the cable modem, let them sit 5 mins. Plug in the power to the cable modem ONLY, wait for all lights to be on steady except for the activity light Then turn on the PS3 and check the network IP addy.
Sep 14, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
461 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
