Question about Zebra Symbol MC3190G Handheld Mobile Computer
How to configure Motorola MT3190 scan codabar
Cannot read bar code
If it will not read any bar codes, then it must be repaired. If it only reads selective bar codes, then perhaps the one you are trying to scan may not be of the type it recognizes.
This scanner will read the following codes: LS 1004/LS 1006: UPC/EAN, Code 39 full ASC11, Code 128, Code 93,
Codabar, Interleaved 2 of 5, Discrete 2 of 5; LS 1000: undecoded
Mar 09, 2015 | Symbol LS-1006 (ls1006i0001900z) Handheld
How to configure motorola cs3070 tab suffix
Download the CS3000 Series Scanner Product Reference Guide from the Motorola Solutions Support portal and scan the barcodes:
<Data> <Suffix 1> Adobe page 69 of 152
Scan Suffix 1 Adobe page 68 of 152
7 from the Numeric barcodes Adobe page 121 of 152
0 from the Numeric barcodes Adobe page 120 of 152
9 from the Numeric barcodes Adobe page 121 of 152
Save Configuration Adobe page 72 of 152
https://atgsupportcentral.motorolasolutions.com/content/emb/docs/manuals/13608804a.pdf
May 05, 2014 | Symbol Hotshot LS2106 Handheld
What are the specific steps to configure a Z6M printer to print in landscape as opposed to portrait?
Printing in landscape or portrait !
First of all you have to create a portrait page.
When using the label programme select he page and tick the landscape option.
When you print it will do the rotation.
May 24, 2011 | Zebra Z6M Thermal Label Printer
How do i program it with a IT 3800 hand held scanner ?
At this web link you will find the data sheet as well as several user guides.
be sure the cable you have matches the emulation you wish to user.
contact the vendor or Honeywell for information.
be sure codabar is set to on, min length at lease 3, same code out.
The turbo wedge menus are printed in codabar.
http://www.honeywellaidc.com/Site.aspx/na/en/product_center/product_support/?category=5&product=140
at this web link you can find information on the turbo wedge.
www.compseemfg.com
all menus are covered in the manual ..
to set the terminal ID
scan enter terminal id
scan 2 digits form the options page to set the terminal type .
scan exit terminal selections .
most of the menus run in this same sequence .
for example to set the AUX port on a turbo 1 to RS232
Scan Enter General II
Scan Auxiliary Port selection
Scan a 0 (zero) form the digit colum on the Options page
Scan Exit Gerneral II
Oct 22, 2010 | Compsee TurboWedge (02kt023) Hands Free
Half of the labels information is printing
I'm assuming you mean half is showing up as you go across the label. If that is the case and it's a very clear line where the print is cut off, then check the print width setting through the front panel of the printer. Press SETUP and look for setting called MAX WIDTH. It should be set to 104MM (4") which is the width of the print head. It is set to something smaller if the print is being cutoff.
If the print is fading away as you go across then that it is a print head balance issue. Look at the print head pressure dials on top of the print head assembly to make sure they are set evenly.
Hope that helps !
Apr 14, 2010 | Zebra Z4Mplus Label Printer
MC5590 - Can Not Scan All Bar Code
You would need to configure the MC55 for the specific barcodes and lengths, there are some defaults values preinstalled. You can change them in the settings of your Scan Application.
Apr 11, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
Motorola MC5590 is not able to scan barcode
download the datawedge file for the mc55. Its probably not loaded and configured. Once you have this file on the device and you need additional information please let me know
Here is the version 3.1.7
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12465&sliceId=&dialogID=162320658&stateId=1%200%20162316370
kganoe@datexcorp.com
Mar 25, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
Where is my barcode after I scan it?
Is the cradle connected to the pc via either usb, serial or keyboard wedge?
If so you will need to first, pair the scanner with the cradle by scanning the barcode on the cradle and second, configure the cradle properly so it transmits the data to the host.
Download the product reference guide from motorola website. You will get all the configuration information you need in there.
Mar 20, 2009 | Symbol LS3578-FZ Barcode Scanner - P/N...
Do I need to purchase the Device Configuration Package?
Depending on what application your client will use, you will need to configure the scanner in which ever way suits your customer.
If you use a telnet client kind like wavelink, you can configure it from there. If you planning on using some other application that has not scaner api's, you will need to use datawedge which is available as a free download from symbol support.
The DCP is normally available free of charge, however motorola has changed the downloads policy for dcp and depending on the version, you may need to provide them with information of the terminal and request the download.
I hope this helps.
Mar 13, 2009 | Zebra Symbol Technologies MC909X-G Series...
Zebra Symbol MC3190G Handheld Mobile Computer Logo
98 people viewed this question
Top Zebra Computers & Internet Experts
Mike
 steve
steve
justwinwin
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
