Question about Whirlpool RBD245PDS Electric Double Oven
Oven comes on but after short while it trips circuit breaker
    Prodigy:
    An expert who has answered 500 questions.
  • Whirlpool Expert
  • 650 Answers
There is a possibility the you have a weak circuit breaker. This sometimes happens when the breaker can't handle the rated load. If you are not getting any pop or other sound like a short. This is where I would concentrate my attention.
Posted on Mar 02, 2014
4 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: whirlpool double oven display is off
The only repair is to replace the ERC (clock).
Sorry.
Posted on Mar 27, 2009
jcarlton214
  • 105 Answers
SOURCE: Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
Posted on May 28, 2009
  • 25 Answers
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Posted on Jun 25, 2009
Hi I have a 4year old Lamona 4601 double oven, the top oven/grill works fine but when I turn on fan oven it trips the power on the main house fuse board.
When the main breaker trips it indicates current is escaping from the circuit to ground.
If it is a micro-circuit breaker that trips it indicates the circuit is consuming too much current - a short circuit.
Either way the wiring or the oven elements have a fault and need attention.
Dec 20, 2017 | Ovens
Temp control knob loose on old Frigidaire oven
my best guess its A Frigidaire wall oven, circa 1966-1970,
unsafe to use at any time if the temp controller trips the circuit breaker
could be the oven thermostat causing the trip as well
if Frigidaire are still in business
You will need to ask an electrician to fit a /tested used controller or new superseded part temp controller and knob
Oct 11, 2016 | Frigidaire Ovens
Main oven wont come on or the light but the fan does
Hi, I hope I can help you. If you're referring to the overhead fan above the oven, that fac is usually on a separate circuit. The oven itself is connected to a separate circuit breaker, hence, that is why the oven and light won't come on.
Check your circuit breaker box, and see what circuit has tripped. Check to see if there are any burn marks around the breaker before resetting it.
The reason the breakers may trip, is the breaker is old, may have the incorrect rating, or may be linked to other circuits, such that when too many items are all drawing power at once, it will trip the breaker.
Feb 02, 2016 | Ovens
What can cause the Circuit Breaker to trip out when the door of my Zanussi ZYB594X oven is opened and the internal light comes on?
I suppose, the light did not work because the circuit breaker was released.
In this case, try to find a short-circuit in the following circuit : microswitch (door lock) - power board - light bulb.
Dado
Oct 18, 2014 | Zanussi Ovens
The oven has just started tripping the fuse box, where do I start looking ?.
The oven element is the most likely culprit. With the oven turned off check the element for any holes/blow marks. When this occurs the element short circuits to earth causing the circuit breaker to trip.
Feb 18, 2011 | Ovens
Main oven trips electric when switched on top oven works fine also grill . did notice that fan was making a noise
If the fuse or circuit breaker is tripping it is most likely a short circuit in the oven element.
Feb 09, 2011 | Tecnik TKC8082 Electric Double Oven
Gas oven plows circuit brake when oven turned on model mgr5765qdw
Short in the wiring to the oven igniter or bad igniter system. Some kind of short causes the breaker to trip. Extremely rare to have a bad breaker.
Mar 03, 2010 | Maytag Ovens
Whirlpool RBD245PDS Electric Double Oven Logo
76 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
