Question about storz 20134020 Cold Light Fountain XENON NOVA 300 Light Source
No light we dont have light sours after conect to electricity
Tail lights dont work, break lights do
Did you check the fuses all so in the engine compartment fuse block? If you did check for loose wires at the bulb sockets, Loose ground wire conecting to the body, A break in a wire, If that is not the cause there is a short in the wireing, That should be check out at a auto electric shop,
Nov 28, 2012 | 1995 Mercury Grand Marquis
Sour smell in dryer
Hello JoAnn Barrett - It is very rare for a dryer to produce a sour odor. I would suggest cleaning out the lint trap or try removing the panel to confirm that doesn't anything trap there that can cause this odor. Otherwise, I would strongly recommend contacting a professional to move forward accurately with the concern.
Nov 23, 2012 | Frigidaire Electric Dryer
After conecting my set up, we noticed a yellow square in the middle of the picture.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 09, 2011 | Panasonic PT-60LC14 60" Rear Projection...
Were the black vaccum line from 4x4 conects my 4x4 dosent engage and the black line it was disconect and i tinck is the problem thanks
the only black hose i know of on the tranfer case is a vent. if it has a selecter switch on the dash its electricly activated. try putting it in neutral push on the brake and hold then switch to 4x4 mode. if the indicater light goes on and dosnt flash and you still dont have 4x4 check your hubs
Dec 13, 2009 | Ford F-150 Cars & Trucks
Daytime running lights dont work on 1996 Tahoe
Check all the fuses. Could be a bad relay for the head lights.
Aug 29, 2009 | 1997 Chevrolet Tahoe
I have a soured smell in my dryer when it not running
Does it appear that the smell is in the cabinet rather than the drum? I'm guessing that bugs or mice are living in there. There are no components in the dryer case that would smell except for a slight electrical odor. Remove the case and look around! Look for droppings around the back.
Aug 26, 2009 | Dryers
Wire conections not on right
You need to find a mechanic that is familiar with electrical repair. sounds like your"mechanic" isnt very well trained. There are wiring diagrams for the electrical system that any well trained technician will be able to follow to diagnose your problem
May 25, 2009 | Hyundai Motor 2003 Elantra
Signal lights fail to work. keeps blowing fuses.
Hi, the best way to solve this problem is installing a conector that comes allready made for your ventue ,it conects under the rear of your van an , you can buy it at auto zone ,checkers pep boys ,wallmart sells some of them too ,it goes at the original conections ,(no cutting or splicing)...I hope this help.....
Jul 15, 2008 | 2000 Chevrolet Venture
storz 20134020 Cold Light Fountain XENON NOVA 300 Light Source Logo
82 people viewed this question
Top storz Medical Experts
Rhonda Webster
Rhonda Webster
masud
masud
Ron Jones
Ron Jones
Level 1 Expert
Are you a storz Medical Expert? Answer questions, earn points and help others
