Question about Dell Computers & Internet
Error lights 1&3 are lit on my Dell Optiplex 960
The computer starts run's for 3 seconds, then shuts down. Error lights 1 and 3 are lit
SOURCE: Dell Optiplex gx280 shuts down and orange power light blinks
It happens because the power supply is overheats and computer goes to standby. The power supply is 160w or lower. Specially it will happen if you put more devices in such as video card or sound card. So the only solution you have is to place a small 1or2 fans toward the power supply to make it cooler. And 1 more thing the power for the fans should come from other sources.
Posted on Dec 29, 2008
oblivion2k
  • 150 Answers
SOURCE: Dell (ie optiplex 330) would not boot with the orange light on
Do you have a lot of accessories plugged in? They may have overloaded the power supply and if this is the case you will need to buy new power supplies. If this is not the problem, check to make sure that the computers have plenty of ventilation in the back. If they don't, they may have overheated and melted quite a few different components.
Posted on Feb 27, 2009
nitin_s_s
  • 29 Answers
SOURCE: OPTIPLEX 960 error codes 1 and 3 at startup
Blinking amber ... seems like an isuue with the power supply .. check if you see the power supply fan spinning at the back of the system tower... If its spinning then you could try reseating the memory modules inside the system tower . Opem the tower and then disconnect the green colour ruler shapped modules which has a latch on either sides. then try turning in the system ... check if turns on properly.
Hope its informative.
Posted on Apr 02, 2010
Testimonial: "Thank you - computer works with another power supply. You got it, Master!"
SOURCE: No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Posted on May 21, 2010
SOURCE: Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Posted on Jul 22, 2010
How do i reboot a dell optiplex 960 to factory settings if i cannot login?
How to enter BIOS?
1. Turn on or restart your computer.
2. Press "F2" to enter "System Settings" (BIOS) when the DELL icon appears.
Restore the BIOS to default settings.
Press "Caps Lock", "Num Lock" and "Scroll Lock" buttons to light up the corresponding lights on the keyboard. Then, press the following three combination keys:
Alt+E - Clear (Release) the interrupted resources and reallocate resources at next startup. After pressing the combination key, you will hear a sharp beep tone.
Alt+F - Restore BIOS to the default settings. After pressing the combination key, you will hear a sharp beep tone.
Alt+B - Restart the system.
Password clearing method 1: When the password input box appears, type in the password and press "Ctrl" and "Enter" simultaneously.
Password clearing method 2: Remove the PSWD jumper on the MB and start up the system. Set the password to empty in BIOS, shut down the system and reconnect the PSWD jumper.
Hope this method will help you otherwise check Dell Optiplex 960 Manual- https://guideusermanual.com/product-name-optiplex-960-manual&po=344822&lang=English for expert's suggestions.
Dec 24, 2016 | Dell Computers & Internet
Error light code 3 & 4 in front panels
Hi Carlos, error code 3 & 4 is caused by faulty RAM (Memory modules) installed in the PC. You could try the following to resolve the issue:
1. Open up the computer cover
2. Locate the memory module(s)
3. Remove them memory module(s)
4. Use a can of compressed air or spray contact cleaner onto the center of the DIMM connectors to clean all the contacts. Do NOT use a normal brush to clear dust away. Wait for 5minutes for the contact cleaner to dry.
5. Reseat the memory module(s)
6. Turn on the computer and check if codes 3 & 4 still light up. If it does not, it should boot into the Operating System.
7. If codes 3 & 4 continues to light up, you will need to run a memory diagnostic test to determine which of the memory module is faulty.
Sep 07, 2016 | Dell OPTIPLEX 960 MT Desktop Computer...
2 3 4 orange blinking lights/ automatic start up and forced shutdown/ optiplex 960
Log in to: http://www.dell.com/support/home/us/en/04/product-support/product/optiplex-960/diagnose and send this info to Dell. As I recall lights 2,3,4 are either memory or HDD failure.
Run Diagnostic Run Diagnostic Diagnostics can be run on supported Dell devices with a full version of Windows.
Already have an error code from running ePSA diagnostics?
Dell devices come with preboot diagnostics to capture error codes. If you have already run a preboot system assessment (ePSA), enter the error and validation codes with your Service Tag below and complete the steps to resolve your issue. Enhanced Preboot System Assessment Error Code (without 2000-prefix) * Validation Code * Service Tag * Part Serial # (optional) ; ;
Mar 28, 2015 | Computers & Internet
DMA page register read/write failure
According to Dell you will need to run their diagnostic utility to find out what is really causing this error code
http://mss.net/Links/DellDocs/OptiGX260/UserGuide/advtshoo.htm#1163831
read the part about how to start dell diagnostic
Feb 26, 2015 | Dell OPTIPLEX 960 MT Desktop Computer...
I have dell 960 switch it on but light turns to orange
Could be several things.
1. could be the power supply
2. inspect the motherboard for bad caps.
If the above is OK. Try removing and reseating the CPU, Memory and CMOS battery.
Apr 15, 2014 | Dell OPTIPLEX 960 MT Desktop Computer...
Led indicator lights
Following are the various ways to clear the CMOS or NVRAM on Optiplex systems:-
The computer must be disconnected from the electrical outlet to clear the CMOS setting.
Remove the computer cover.
Locate the CMOS battery on the system board.
Note the orientation of the battery, usually the plus side is up, and remove it.
Wait for 3 to 5 minutes for the CMOS to clear.
Replace the battery in the socket.
Replace the computer cover.
Plug the system and devices back into the electrical outlets and turn them on.
And Sec option jumper setting also available you can used:-
Turn off the computer and disconnect the power cable from the electrical outlet.
Locate the 3-pin CMOS jumper (RTCRST) on the system board.
Remove the jumper plug from pins 1 and 2.
Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
Replace the jumper plug on pins 1 and 2.
Close the computer cover.
And More Support see link:-
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-755_user's%20guide_en-us.pdf
If more Technical Support Call.
Aug 22, 2013 | Dell Optiplex 755 Desktop Desktop Computer...
OPTIPLEX 960 error codes 3 and 4 at startup. Solid amber light.
"optiplex 960 error codes 3 & 4 at startup"
Found out by myself the google suggestion to look up the Dell Diagnostics page:
http://support.dell.com/support/edocs/systems/Op745/en/UG_en/trouble.htm
Lights 3 & 4 means "Memory modules are detected, but a memory failure has occurred." Bingo! I didn't actually replace memory sticks, but pulled them out and put back in one by one. Only three out of four sticks were accepted. Works.
Jun 05, 2012 | Computers & Internet
Hey, My Dell Optiplex GX270 will run for a quick second, beep, and then a light with a barrel looking icon lights for a second too. How do I fix this? Thanks so much!
I would run diagnostics. Here's how you do it if the utility partition exists on your hard drive:
Starting the Dell Diagnostics From Your Hard Drive
  1. Shut down and restart the computer.
  2. When the DELL™ logo appears, press <F12> immediately.
NOTE: If you see a message stating that no diagnostics utility partition has been found, run the Dell Diagnostics from your Drivers and Utilities CD.
If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer through the Start menu and try again.
  1. When the boot device list appears, highlight Boot to Utility Partition and press <Enter>.
  2. When the Dell Diagnostics Main Menu appears, select the test you want to run.
Aug 11, 2009 | Dell Optiplex GX270
Computers & Internet Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
