Question about Mitutoyo Series 192 24" Height Gage
Display shows E-oF, will not operate
Straight after you power on the display shows E-oF. The gauge has been sitting in a store room for some time and not used
Followed turn on instructions in manual.CO display 2 days. continually. Unit gets Very warm & fan runs if turned off. Have to unplug to stop. Unit used approx.3 mo in '14 & just restartd this week.
could you be mistaking the room humidity indicator for the time? reason I ask is on these one display units this happens more frequently than Id care it too , the one display shows both time and room humidity also set point humidity , the only way one can tell is on some models there is a tiny light that shows up next to labeled function , easy to miss It , also if your machine is sort of new (last few years) it has been decided that it's more efficient to let the circulation fan run all the time , regardless of room humidity . this makes it a little annoying (noise) but they do cycle the compressor to regulate the room humidity
May 28, 2015 | Dehumidifiers
Why wont it turn on?
if power is applied then display should show current room humidity , if set is pressed then display should show current set point for desired room humidity , this has to be less than first display otherwise the control will think room has acheeved desired setpoint and shut off , the one of these i had seemd to have an overly sensative collection bucket full sensor and had to be "just right" for unit to run
Feb 17, 2015 | Haier 45-Pint Dehumidifier
How do I get the display to show my drive direction to be straight ahead, not 'NORTH' as being straight ahead?
In the navigation options menu, select Map Options and then Map Mode. Select Head Up, 2D or Head Up, 3D as desired.
Feb 06, 2015 | GPS
Proform elliptical 820 left sitting for months in florida room but worked fine before, batteries replaced, now the rpm's don't show and programs won't start. i have a feint memory of havin
1) replace by new batteries with the same type fulll charge, with the same mark, with the same polarity
2) clean the contacts batteries with contacts cleaner for a dirty, corrosion, etc
3) adjust the REED switch, test it, clean it, and tight any plug or connector.
4) tight the ribbon cables for keypads good connection.
Try again.
Of course you must know the power cord is o.k the c. breaker you must reset and some fuse is o.k o replace see the b.diagram
God bless you
Nov 19, 2012 | Exercise & Fitness
My SMH9151W Samsung Microwave displays a -SE- or a -5E- and will not operate. I unplugged over night and still will not operate
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
Mar 20, 2012 | Samsung Microwave Ovens
How do you get the clock to operate on a battery only (uses a 9V). I insert the battery, then unplug the clock. The display is dark. But when I plug it back in, it is on the right time. If there was a...
They're just used to retain memory. That's all. Once power comes on, the time should be correct. Now if the power went out and there was no battery on the clock, when the power comes back on it goes straight to flashing 1200.
Jun 28, 2011 | Westclox 181961 Omni II Clock Radio
Model N1506, I need Operation instructions for this Woods Light Timer?
N1505 timer manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 01, 2010 | Hardware & Accessories
Demo mode rs255sl
This function is for a display purpose on the floor of show room or store.
1) Mode ON/OFF
1-1) For the exhibition mode, press Power Freeze and Freezer Temp. buttons simultaneously for 8 seconds until a
“ding-dong” sounds.
1-2) Press the same time buttons again for 8 seconds to cancel this mode put with a “ding-dong” sound.
2) Operation
2-1) Most of the system function except the compressor operation are working properly.
2-2) There is no defrost cycle in this mode.
Mar 21, 2010 | Samsung RS265LBBP Side by Side...
Zen V plus display
screen would have to be replaced
· For parts email: arnoldjin@hotmail.com see if he has one.
Sep 18, 2007 | Creative Labs ZEN V Plus MP3 Player
Colour Noise and Dim Display
you may have a slightly damaged power supply...although swapping the main supply chassis may solve, I have seen front panels that have an additional supply section. look on the front panel board for any TP's and probe with an O-scope. if you see a TP that may also show (+ xx V), where xx is a numerical value-may be one x only, the scope must show a straight horizontal line that is shifted vertically away from its normal (ground) position. that confirms a DC value present. then determine the DC value of the shift. Another possibility, since you invested, is to search ebay for a second unit for part swapping. look for as-is units.
May 27, 2007 | Panasonic AG-1980 S-VHS VCR
Mitutoyo Series 192 24"  Height Gage Logo
20 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Doug Adams
Doug Adams
Glenn
Glenn
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
