Question about Voodoo Shango
Whats the size of the crank bolt on a voodoo shango
Crankcase bolt
which one, there are many bolts,
do you mean the end of the crank shaft, front , damper pulley bolt
are you test spinning engine? or taking the bolt off or on.>?
the treads on all bolts this engine are RHT, right hand thread
bar stool: righty tighty; lefty loosy
no engine, size stated, but this works.
crank case? pan, bell, crank, head bolts. fly wheel? lots.
Jan 06, 2014 | 2006 Suzuki Grand Vitara
The bolt holding the crank position sensor sleeve is stripped
get the next size larger bolt. get a tap that matches the teaed size and re tap the hole for the new bolt. Or if the threads are not completly gone,you can try red thread locker and see what happens. if that fails, then go to top of post.
Jan 31, 2013 | Cars & Trucks
I have a 2000 suzuki vitara it is the same as a tracker i lost the bolt for the crank pulley i need to know what size the bolt is
They can't tell you what size the bolt is because it is specially made for that purpose. The bolt is made to keep the crankshaft in balance and made of extra strong steel.
I doubt you could substitute something else.
You might try a salvage yard or a place that rebuilds engines.
Dec 18, 2012 | Cars & Trucks
I like to change my own oil in my 954. over the 8 year span the bolt on the oil pan has gotten rounded. i need to replace this pluc/bolt before it gets completely stripped. i was wondering what size bolt...
If you take the bolt to a bolt shop they can measure the size and pitch, or just buy a sump bolt from the honda shop. get a new sealing washer at the same time. If the honda ones are too expensive, try the bike breakers, they are a fairly standard size, but again take the old bolt.
Apr 30, 2010 | 2002 Honda CBR 954 RR Fireblade
What is the thread size for the pedal crank spindal bolt that holds the crank onto the spindal
Hello
Thank you for using
FixYa for your problem
Sorry not sure on the thread size but any bike shop should have a bolt in stock
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 15, 2009 | Mongoose Mischief 20 Freestyle BMX Bicycle
I need to know what size wrenches are needed to replace harmonic balancer and crank sensor on my 1989 buick century 2.8 ltr. engine
you will need sockets,the crank bolt i belive is 22mm and you might need in impact wrench to remove bolt. the crank sensor is 1/2 in or 13mm, that a rachet is good.and to remove balancer sometimes youll need a puller. hope this helps.
Oct 13, 2009 | 1989 Buick LeSabre
How do I remove a crank arm from a Huffy Mountain bike?
You will need to purchase a crank puller. If you only have to do this once you are better off having it repaired in a bike shop unless you like to have tools for everything. They come in various sizes so you will have to tell the dealer which one you need and for what bike. It works like a gear puller. You remove the cap covering the bolt. You remove the bolt or nut holding the crank on and screw the puller into the threads on the crank. You then tighten the bolt that goes through the center of the puller. It puts pressure on the bolt in the center of the crank and forces the crank off. Hope this helps.
Jul 04, 2009 | Cycling
I need an owners manual for the Schwinn DX900 upright exercise bike. The older model (orange). I also do not know what size button batteries are needed . Thank You!
here you go,
hope this is what you are looking for.
http://download.dfxi.com/supportdocs/OM/Schwinn/SCH_DX900_OM_web.pdf
regards,
voodoo
Jun 29, 2009 | Schwinn Cycling
Voodoo Shango Logo
77 people viewed this question
Top Voodoo Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Voodoo Cycling Expert? Answer questions, earn points and help others
