Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Frezer drawer stuck - Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
My stove drawer is stuck and it won't close or come out , what to do ?
drawer is stuck Anon, Pick up on drawer as far back as possible with some force,shake it up and down, this should allow you to lift drawer from track/slides. Clean and lubricate all wheels, bearings and track/slides and reinstall drawer.
HELP bottom oven drawer stuck on new GE range
How to Open an Oven Drawer That Is Stuck eHow
How to Unstick Oven Drawer
Stove Drawer Stuck or Jams DIY fix
Apr 02, 2016 | Kitchen Ranges
Why Bottom freezer drawer wont stay open
Freezer and refrigerator doors aren't usually supposed to stay open. The units are usually installed so that they're slightly tilted to the back to make sure gravity will close the doors if you forget to. If you are SURE - I mean really SURE - that you want your freezer to stay open you should check the drawer rails to see if they're adjustable; if they are, trying raising the back of the rails (or lowering the front). If the rails are not adjustable, try adjusting the front feet of your fridge so that the front of the whole unit is just a tiny bit lower than it is now. Don't lower it too much! If you do, the doors won't stay closed; they'll leak cold air and you'll lose food.
Jul 18, 2014 | LG LMX31985ST Super-Capacity 4 Door French...
Paper drawer stuck closed in imageclass d1150 how do I get into the printer
the drawer wouldn't open due to paper being stuck between the drawer and machine. ---www.doinggroup.com Email:market@doinggroup.com
Nov 29, 2013 | Canon imageCLASS D1150 All-In-One Laser...
Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Jenn-Air JCB2059ES refrigerator makes weird noise
Sounds like the plastics are just rubbing from vibration. redistribute the contents of the drawer and see what that does. Good Luck.
Nov 21, 2009 | Refrigerators
MY REFRIGARATOR IS LIQUING WATER ON THE FREZER COMPARMENT AT THE BOTTOM MAKING A BIG PIECE OF ICE NOW I HAVE PROBLEM TO CLOSED THE DOOR
Probably the drain hole inside the freezer in the bottom back wall is clogh,put hot water in it until melt the ice and keep putting hot water to make sure it goes through.When the drain is clogh the defrost water goes down to the freezer floor and freezes up and the drawer stick to the ice.
Jul 13, 2009 | Refrigerators
Refricerator/ Frezer is on and runing but not frezing or refricerating
On front of refrigerator and near floor remove kick plate and look for a small box with a hole in center. If you find the part I want you to turn the center clockwise slowly until the refrigerator stops or starts. I may be stuck in the defrost position. If it begins to work we need to replace the timer. Let me know what you find, Thanks, Sea Breeze
Apr 23, 2009 | Refrigerators
Kitchenaid built-in refrig 15 yrs old cold freezer, warm fridge
it.s the frezer that makes the refer cold.the evap fan in the frezer moves that chilled air to the refer.if that fan is slow or any blockage inthe air ways it slows that process.Also the frezer should be close to 0 degrees if theres a defrost prob that would make fresh food warmer
Dec 31, 2008 | Refrigerators
Water on inside of refrigerator
there is a dran for the defrost in the frezer that is cloged up need more infow to till u more
Dec 02, 2008 | Whirlpool Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
18 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
