Question about Maytag Neptune FAV6800AW Top Load Washer
Setup new program board
Replaced board no lights
    Master:
  • Maytag Master
  • 753 Answers
Recheck the ribbon and make sure it is seated and locked into place. I will help you please feel free to contact me. I am an authorized servicer.
Posted on Feb 13, 2014
I hsve a 2008 saturn sky base 2.4L. The dealer says I need a new body control module. My question does the new BCM require reprogramming? If it doesn't then I will replace myself. Thanks
Body Control Module (BCM) Replacement and Reprogramming
If the BCM is replaced or requires reprogramming, the following procedures must be performed in the specified order:
BCM Setup -- Using a scan tool, go to Vehicle Control Systems » Computer/Integrating Systems » Module Setup » Body Control Module. Select Setup BCM and follow the on-screen instructions, making sure to select the proper RPOs and input the VIN correctly.
BPP Sensor Calibration--Refer to Brake Pedal Position Sensor Calibration
Program Key Fobs--Refer to Transmitter Programming
Setup SDM Part Number in BCM -- Using a scan tool, go to Vehicle Control Systems » Computer/Integrating Systems » Module Setup » Body Control Module. Select Setup SDM Part Number in BCM and follow the on-screen instructions.
Dec 28, 2016 | Saturn Cars & Trucks
2004 Chevrolet colorado z71 3.5 4x4. Heater/fan,turn signal,brake lights intermittently flash on and off. Suspect bcm but don't know where bcm is and if it needs to be programmed when replaced
It's located on the passenger side A pillar. Or behind the right kick panel ! The first thing to do would be check all Modules for DTC'S ! Yes the BCM need's to be programmed when replaced !
Introduction
The procedures below will program the body control module (BCM) correctly after BCM related service, or setup the sensing and diagnostic module (SDM) serial number in the BCM after the SDM has been replaced. Before you start, read these procedures carefully and completely.
Programming a new Body Control Module (BCM)
If the BCM has been replaced, perform the following steps in order:
  1. Ensure that the battery is fully charged.
  2. Connect a scan tool to the data link connector (DLC).
  3. Turn ON the ignition, with the engine and all accessories OFF.
  4. Program the BCM. Refer to Service Programming System (SPS) in Programming.
  5. Setup the sensing and diagnostic module (SDM) serial number in the BCM. Select Setup SDM Serial Number in BCM with the scan tool.
  6. Perform the Programming Theft Deterrent System Components in Theft Deterrent.
  7. Program the key fobs. Refer to Transmitter Programming in Keyless Entry.
  8. Clear all diagnostic trouble codes (DTCs) with the scan tool.
After the procedure is completed, the personalization settings of the BCM are set to a default setting. Inform the customer that the personalization must be set again. Refer to Vehicle Personalization in Personalization.
Feb 02, 2015 | Chevrolet Cars & Trucks
I change out my controll circuit board put new one in and all they lights are flashing model WHRE5260E1WW
there should be a key sequence to program the new board as this board will fit a lot of units with different features,and you need to set the program for your particular machine,there should be an instruction sheet on how to accomplish this with the new board
Apr 03, 2013 | GE WHRE5260E Top Load Washer
Inicial setup with black screen, no video output
The cable for the back light inverter board may have come off on the mother board side or on the screen side.
2) Failed inverter board.
3) Failed lamp.
Apr 01, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
Blinking green light
TRY TO GET TO THE MENU, SETUP, AND EDIT YOUR SETUP SO EVERYTHING IS DEFAULT. I TOOK A 2001 50" HOME LAST NIGHT, MY SLEEP TIMER LIGHT ON THE FRONT, BLINKED FOR A FEW MIN. THEN, YOU CAN TURN IT ON AND RESET.....HOPE IT HELPS.......????
Dec 07, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Trubleshoot Motherboard
More than 70% of all computer problems are related to cabling and connections. Ensure all cables are connected and connected firmly. IDE and floppy ribbon cables and power cables can often go loose. Ensure microprocessor, memory modules, and adapters such as video card are inserted correctly and didn't "pop-up" due to vibration.
System has no power at all. Power light does not illuminate, fan inside the power supply does not turn on, and indicator light on keyboard does not turn on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Power cable is unplugged. Visually inspect power cable. Make sure power cable is securely plugged in.
Defective power cable. Visual inspection, try another cable. Replace cable.
Power supply failure. Power cable and wall socket are OK, but system is still dead. Contact technical support
Faulty wall outlet;circuit breaker or fuse blown. Plug device into socket know to work and test. Use different socket, repair outlet, reset circuit breaker or replace fuse.
System inoperative. Keyboard lights are on, power indicator lights are lit, and hard drive is spinning. PROBABLE CAUSE DIAGNOSIS SOLUTION
Expansion card is partially dislodged from expansion slot on the motherboard. Turn off computer. Take cover off system unit.
Check all expansion cards to ensure they are securely seated in slots. Using even pressure on both ends of the expansion card, press down firmly on expansion card.
Defective floppy disk drive or tape drive. Turn system off.
Disconnect the cables from one of the floppy drives. Turn on the system, check to see if the keyboard operates normally. Repeat until you have located defective unit. Contact Technical Support.
Defective expansion card. Turn computer off.
Remove an expansion card. Make sure expansion card is secure in expansion socket.
System does not boot from hard disk drive, can be booted from floppy disk drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Connector between hard drive and system board unplugged. When attempting to run the FDISK utility described in the HARD DISK section of the manual you get a message, INVALID DRIVE SPECIFICATION. Check cable running form disk to disk controller on the board. Make sure both ends are securely plugged in; check the drive type in the Standard CMOS Setup (in your motherboard manual).
Damaged Hard Disk or Disk Controller. Format hard disk; if unable to do so, the hard disk may be defective. Contact Technical Support.
Hard Disk directory or FAT is scrambled. Run the FDISK program, format the hard drive(See HARD DRIVE section of manual). Copy your backup data back onto hard drive. Backing up the hard drive is extremely important. All Hard Disks are capable of breaking down at any time.
System only boots from Floppy Disk. Hard Disk can be read and applications can be used, but booting from Hard Disk is impossible. PROBABLE CAUSE DIAGNOSIS SOLUTION
Hard Disk boot program has been destroyed. A number of causes could be behind this. Back up data and applications files.
Reformat the Hard Drive as described in the Hard Drive section of the manual. Re-install applications and data using backup disks.
Error message reading "SECTOR NOT FOUND" or other error messages indication certain data is not allowed to be retrieved. PROBABLE CAUSE DIAGNOSIS SOLUTION
A number of causes could be behind this. Use a file by file backup instead of an image backup to backup the Hard Disk. Back up any salvageable data. Then do a low level format, partition, and high level format of the hard drive( see Hard Disk section of your manual for instructions). Re-install all saved data when completed.
Disk formatted on IBM PS/2 will not operate with this system. PROBABLE CAUSE DIAGNOSIS SOLUTION
The IBM PS/2 uses a different format than other computers. IBM PS/2 disk format will not work in an AT type computer. Format disk in the AT type computer insert disk into the IBM PS/2 and copy the files you wish.
After install an expansion card (network card, tape drive card, etc.) the system no longer works properly. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. All or part of the system may be inoperable. The new card may work but a mouse or COM port may not work. Change the interrupt or RAM address on the new expansion card. See the documentation that came with the new card in order to change pin settings. many expansion devices come with proprietary software that will assist you in doing this.
Screen message says "Invalid Configuration" or "CMOS Failure." PROBABLE CAUSE DIAGNOSIS SOLUTION
Incorrect information entered into the configuration (setup) program. Check the configuration program. Replace any incorrect information. Review system's equipment. Make sure correct information is in setup.
Screen is blank. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. Power connectors may be loose or not plugged in. Check the power connectors to monitor and to system. Make sure monitor is connected to display card, change I/O address on network card if applicable.
Monitor not connected to computer. See instructions above.
Network card I/O address conflict. See instructions above.
Problem PROBABLE CAUSE DIAGNOSIS SOLUTION
Memory problem, display card jumpers not set correctly. Reboot computer. Re-install memory, make sure that all memory modules are installed in correct sockets. Check jumper and switch settings on display card. See display card section for information of settings.
Computer virus. Use anti-virus programs (McAfee/PC-cillin, E-port, etc) to detect and clean viruses.
Screen goes blank periodically. PROBABLE CAUSE DIAGNOSIS SOLUTION
Screen saver is enabled. Disable screen saver.
Keyboard failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is disconnected. Reconnect keyboard. Check keys again, if no improvement, replace keyboard.
No color on screen. PROBABLE CAUSE DIAGNOSIS SOLUTION
Faulty Monitor. If possible, connect monitor to another system. If no color, replace monitor.
CMOS incorrectly set up. Call technical support.
Floppy drive lights stays on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Floppy Drive cable not connected correctly. Reconnect floppy cable making sure PIN1 on the Floppy Drive corresponds with PIN1 on floppy cable connector.
Error reading drive A: PROBABLE CAUSE DIAGNOSIS SOLUTION
Bad floppy disk. Try new floppy disk.
Floppy disk not formatted Format floppy disk(type ENTER)
C: drive failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
SETUP program does not have correct information. Boot from drive A: using DOS system disk. Input correct information to SETUP program.
Hard Drive cable not connected properly. Check Hard drive cable.
Cannot boot system after installing second hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Master/Slave jumpers not set correctly. Set master /Slave jumpers correctly.
Hard Drives not compatible / different manufacturers. Run SETUP program and select correct drive types. Call drive manufactures for compatibility with other drives.
Missing operating system on hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
CMOS setup has been changed. Run setup and select correct drive type.
Certain keys do not function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keys jammed or defective. Replace keyboard.
Keyboard is locked, no keys function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is locked. Unlock keyboard
If a problem persists, please search for a solution or post a question in our tech support forum in our Help Desk.
Oct 19, 2008 | Computers & Internet
Printer Locked
Time for a new main logic board.
Feb 06, 2008 | Zebra 110Xi III Plus Thermal Printer
Maytag mbf2258hew replace jazz board
bug, the jazz board is pretty easy to replace. The light cover will slide off toward the back. Now if you look behind the control panel you will see two slots. Take a flat blade screw driver and push the cover tabs in while pulling down on the cover. The cover will come down. Two slats slide in on the front and will release, disconnect the harnesses and install the new board. Reverse the process. Catriver.
Sep 04, 2007 | Amana AFB2534DE Bottom Freezer French Door...
Maytag Neptune FAV6800AW Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
