Question about Big Game Treestands Big Game 330-Pound Digital Game Scale Big Game 330lb Digital Game Scale GSD330
Send me calibration procedure. - Big Game Treestands Big Game 330-Pound Digital Game Scale Big Game 330lb Digital Game Scale GSD330
Mitutoyo 543-256 linear error of 0.028mm over full 12mm stroke. Repeatability is perfect, mechanically is perfect. Is there a re-calibration procedure?
Ensure your testing procedure is perfect. If your testing procedure is proven, then you will need to send it for repair. At that point, either your scale or grid assembly is damaged or requires adjusting.
Canada's Gauge Repair Specialists
Precision Tool Works - www.precisiontoolworks.com
Jan 08, 2015 | Mitutoyo Measuring Tools & Sensors
Tip
How to calibrate the MSA Altair 4
Want to calibrate the MSA Altair 4 Gas Detector or MSA Altair 4X? Here's how:
1. Turn the MSA Altair 4 and MSA Altair 4X on in normal reading mode. Do this by pressing and holding the center button.
2. Once the MSA Altair 4 and MSA Altair 4X is in normal reading mode, you need to send it into calibration mode. Do this by pressing and holding right beeps at you and the screen asks you to zero the monitor (sensor refresh on the MSA Altair 4X).
3. Now that the screen is asking for confirmation, press the center button once to confirm. This will send the monitor into zeroing mode. Now is a good time to set the monitor down, and grab your calibration gas, regulator, and calibration adapter.
4. Open the valve on your regulator. This is a very important step so you do not ruin your calibration gas cylinder. Now screw it in to your calibration gas cylinder. Close the regulator once you hear gas spewing out of it. This is the signal to know your regulator is good to close. Continue screwing in the regulator until it stops. Do not overturn it.
5. Attach the tubing to the hose barb on your regulator. Make sure the tubing is also connected to your calibration adapter.
6. Wait for the screen to come up asking for you to apply calibration gas. Once this screen comes up, press the center button again to confirm. Screw the calibration adapter in to your gas detector. Once it is screwed on, turn on your gas.
7. Make sure your calibration gas values on the screen match what is on your calibration gas cylinder!
8. Once the calibration procedure is completed, turn your gas off and remove the calibration adapter from the MSA Altair 4 or MSA Altair 4X. The screen will go back to normal reading mode within a few seconds.
9. Congratulations! You have officially calibrated your MSA Altair 4 or MSA Altair 4X gas monitor. Make sure to record these readings in your calibration log!
If you come up with an error, the most likely bet is a bad oxygen sensor, but it could be a number of other issues. Feel free to email me.
on Sep 29, 2014 | MSA Altair 4 Multigas Detectors - 10085989
How do I calibrate a topcon laser ?
There are detailed instructions in your users manual on how to check and adjust your Topcon laser. You'll need a tripod, 2 vertical surfaces about 50 meters apart and your laser receiver. It's done by marking positions of the beams, on the different surfaces and then adjusting your laser position to the center of the different positions.
The procedure is different for different models, but i have attached some pictures from the manual for the RL-VH4 series. calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-0.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-2.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-5.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-9.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-14.jpg
Aug 11, 2014 | Topcon Rotating Builders Red beam Laser...
Insert black crd message zebra p120i
Dont worry, this is not error! The printer is asking to continue with calibration procedure:
After a few seconds, the printer prompt for the black card when it displays "INSERT BLACK CARD" so, Feed the black card through the front of the printer (where the card exits through) with the black side up, until the printer takes the card in automatically. You will get one of two results: a. RIB SENSOR PASS. Indicates the ribbon sensor was calibrated successfully.
May 29, 2014 | Zebra P120i Thermal Card Printer
Need calibration procedures for my ge cooktop pp950
Fred,
Did you get an answer? Having the same problem!
Thanks!
Apr 21, 2013 | GE PP950SMSS
Good morning. my printer will not calibrate. Could you please help me out?
Perform a Manual Calibration:
Perform a media and ribbon sensor calibration to reset the sensitivity of the sensors so the
media and ribbon are detected more accurately. If you change the type of ribbon or media,
your printer may operate better if you perform this calibration.
Calibrate Media and Ribbon Sensors
Use this procedure to adjust the sensitivity of the printer's sensors. In a
printer that has the Thermal Transfer option installed, both media and
ribbon sensors are adjusted. In a Direct Thermal printer (no Thermal
Transfer option installed), only media sensors are adjusted, and the LCD
displays for ribbon do not appear in this procedure.
Important • This procedure must be followed exactly as presented.
All of the steps must be performed even if only one of the sensors
requires adjustment. You may press the left arrow at any step in this
procedure to cancel the procedure.
How to select this parameter:
1. Press ENTER to start the calibration procedure.
The LOAD BACKING/REMOVE RIBBON prompt displays.
2. Open the printhead.
3. Remove approximately 8 in. (203 mm) of labels from the backing,
and pull the media into the printer so that only the backing is between
the media sensors.
4. Remove the ribbon (if used).
5. Close the printhead.
6. Press ENTER.
The message CALIBRATING PLEASE WAIT displays.
The printer adjusts the scale (gain) of the signals that it receives from
the media and ribbon sensors. On the sensor profile, this essentially
corresponds to moving the peak of the graph up or down to optimize
the readings for your application.
RELOAD ALL displays.
7. Open the printhead and pull the media forward until a label is
positioned under the media sensor.
8. Reload the media and ribbon (if used).
9. Close the printhead.
10. Press ENTER.
The printer does a calibration; during this process, the printer
determines the label length. To see the new readings on the new scale,
print a sensor profile.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 25, 2011 | Zebra Z4Mplus Label Printer
Reader 6oo Touch : calibration error detected.
This error indicates that an issue occurred during the calibration procedure. Follow this procedure to resolve this issue.
1. Using the stylus, tap the "X" to restart the calibration process.
2. Tap the center of each "X" that appears on the screen.
3. When "Touch Panel calibration completed" is displayed, click "OK".
After performing the above steps, the issue should be resolved.
If the issue still persists, perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object.
If unfortunately the issue still didn't resolve, service of the Reader may require. Follow the below link to initiate the repair: http://eservice.sony.com
Feb 04, 2010 | Sony E-reader Portable E-book MP3 Player
CALIBRATING A TANITA KD-200-110 DIGITAL SCALE.
According to Tanita, you must send the scale back to the factory to adjust the calibration. As of September 2011 the cost is $125.00
This is more the scale costs.
Moral of the story. Don't buy Tanita.
Aug 24, 2009 | Tanita 1479V - Digital Pocket Scale /...
Big Game Treestands Big Game 330-Pound Digital Game Scale Big Game 330lb Digital Game Scale GSD330 Logo
Top Big Game Treestands Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Big Game Treestands Health and Beauty Expert? Answer questions, earn points and help others
