Question about HP Compaq 6005 Pro A2W40UT Small Form Factor Desktop PC with AMD
Does the HP 6005 Desktop PC have a battery backup?
    Genius:
  • HP Master
  • 1,552 Answers
Yes, every motherboard (desktop or laptop) has a small battery that helps remember the CMOS settings when the computer is powered-off (even when the laptop's battery is removed).
Posted on Apr 23, 2014
Power on password
What are you looking to do with the power on password?
You can typically reset it by pulling a jumper on the motherboard. I've attached the user manual for your system below, consult it to locate this jumper:
HP Compaq 6005 Pro Series QuickSpecs c04123349 pdf
Hope this helps!
Feb 20, 2015 | HP Compaq 6005 Pro SK557UC Small Form...
How may i get a 6005 manual?
go here http://h20565.www2.hp.com/portal/site/hpsc/public/psi/home?sp4ts.oid=4024563&ac.admitted=1453146162451.1123376534.492883150#manuals
Jul 03, 2014 | HEWLETT-PACKARD Hewlett Packard HP Compaq...
Where can I buy a backup battery for this computer?
This is a pc desktop so it doesn't come with a battery, it uses electricity. Perhaps you meant a HP laptop and in this case I will need the model # of the laptop you are referring to
Feb 16, 2014 | HP 6005 PRO SFF ATH30 2GB160GBDVDR W7PXP ...
Does this computer have a battery backup?
Yes, every desktop computer has a small battery to retain the "BIOS-settings" when the computer is powered-off.
Feb 13, 2014 | HP Compaq 6005 Pro A2W40UT Small Form...
Drive formatted for a pavilion for use in a HP 6005? can it work?
Hi NavyGirl1,
Your PC should have 4 SATA slots whereby you can attach your old HD to the new PC and copy the files across to your new hard drive.
Let me know if you need any further help
Best wishes,
Graemevm
Jan 23, 2012 | Computers & Internet
HP Compaq 6005 Pro, nine beeps
9 BeepsNine beeps means that there has been an AMIBIOS ROM checksum error. Literally, this would indicate an issue with the BIOS chip on the motherboard. However, since replacing a BIOS chip is sometimes impossible, this AMI BIOS issue is usually corrected by replacing the motherboard.
Use utility tool like RegInOut to repair corrupt registry files and keep your computer safe from being damaged.
Jan 04, 2012 | HP Compaq 6005 Pro (NV513UTABA) PC Desktop
My computer keeps on reminding to replace onboard battery?
it's telling you to replace bios backup battery, lithium ion button type, might be next to the bios chip on motherboard......
Nov 18, 2011 | HP Compaq Business d530 PC Desktop
What replacement backup battery does the pavilion
Hi, most motherboards that I have fixed etc... have used the 3.0V CR1620 Button Cell Battery which is easily available and cheap!
Jan 05, 2010 | HP Pavilion 515n (DC471A#ABA) PC Desktop
IPAQ 1910 Backup Battery Is Dead, Doesn't Take A Charge
You need a new battery and yes you can replace it.Check with HP or a wireless store for the right battery type
Aug 29, 2009 | HP iPAQ H1910 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
HP Compaq 6005 Pro A2W40UT Small Form Factor Desktop PC with AMD Logo
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
