M2n-mx bios problem
Displays the message boot block ver 024 bios checksum error searching for floppy floppy not found searching for cdrom cdrom not found i removed the bios chip from the socket programmed it with m2n-mx0411.rom file but same message again please help
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Try new cmos battery
Posted on Jun 10, 2014
4 Suggested Answers
  • 10406 Answers
SOURCE: boot block compatible ver.024
Bad BIOS checksum: the software on a chip on the motherboard has become corrupted.
Sometimes, you can find a "BIOS update" on the manufacturer's web-site, so that the contents of that chip can be refreshed,
i.e., by booting from a diskette (or from a USB memory-stick) that contains the replacement software.
Contact a qualified technician, and pay them for 1 hour of labour.
Or, replace the motherboard.
Posted on Jul 17, 2009
  • 11 Answers
SOURCE: Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Posted on Jul 27, 2010
SuperTech-11
  • 1591 Answers
SOURCE: BOOT BLOCK COMPATIBLE VERSION VER
click this link or copy and paste it in your browser address bar:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5SD2-VM&p=1&ft=3&os=29#P5SD2-VM-0515.zip
In the most recent (top) listing, click the GLOBAL that does NOT say DLM at the end (the second GLOBAL link)
Make note of where the file is being saved!
Unzip the file using winzip or power archiver or some such utility (Depending on your OS, Windows may simply open it for you)
Copy the extracted file P5SD2VM.ROM either to a floppy, or burn it to a CD.
Put the disk with the file on it in the appropriate drive and reboot the system.
The motherboard should now repair itself, and give you the latest bios in the process.
This will fix your system, but I'd get a program called FIX-CIH from http://www.grc.com/fix-cih.htm
Run that program to make sure you aren't infected with the CIH virus (one of very very few viruses that will kill your BIOS like your is) Just to be sure it wasn't a virus that did it.
That should FixYa.
Posted on Apr 06, 2011
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
How do you flash the BIOS
What happens when you turn the computer on?
If the bios is working enough to enable you to boot from a CD download the new bios from asus along with there AFUDOS.exe flash utility and make a bootable CD and copy both to it.
If the bios is completly none functional you should be getting this msg when you turn the computer on,
Boot Block Compatible Version Ver .010
Bad BIOS checksum. Starting BIOS Recovery
Checking for floppy . .
Floppy not found
Checking for CD rom . . .
CD not found
Floppy not found
CD not found
Repeat adinfinitum.
If this is the case you need download the most recent BIOS from compaq and either copy it to a bootable CD if you have this capability or buy a floppy drive for $5 and make a bootable floppy on a working computer and copy this BIOS file to it. Then rename the bios file to A8N32SLI.ROM.
You may not even need make the floppy bootable but I would just in case.
Stick the floppy in the drive turn the computer on and you will see
Checking for floppy . . .
Floppy found.
Reading file "A8N32SLI.ROM" . Completed.
Start Erasing...
Start programing . . ./
Please turn off your system and power on again to get system back.
and happy days will be here.
Jun 29, 2012 | Compaq Presario CQ61-310US Laptop
BAD BIOS CHECKSUM, STARTING BIOS RECOVERY...
I have seen this be a CMOS battery many times. Also, you can try flashing the BIOS if you continue to have troubles after replacing the battery. You should be able to find that information on the motherboard manufacturer's website.
May 05, 2011 | Computers & Internet
Boot block compatible ver.024 Please do not insert disc into cd-rom or floppy drive if you want to recovery with an usb device bad bios checksum.
Jul 17, 2009 | ASUS M2N-MX Motherboard
My computer can not boot -BIOS ROM checksum error
to be honest if you have tried to re-flash your bios, and it did not work you still either have hte wrong version or the disc drive your using to flash it from is faulty. try another floppy drive/disc and try again. if that dont work. to be honest it's not worth getting it repaired just go out and spend £30-40 on a new mobo. sorry i'm not more helpfull but i dont believe it's worth spending that much time and effort on an old system like that with this kind of problem. good luck to you. let me know how you get on ok.
Jun 15, 2009 | EliteGroup K7VTA3 V5.0 Motherboard
No bios computer will not boot
you have to have a bootable floppy disc
Jun 01, 2009 | ASUS M2N-MX Motherboard
BIOS 1004 cpu not support
I got it :-)
Damn Asus , it was a hard session ;-)
1. Make an ISO from your original Asus CD denn insert (with isobuster or something) the Bios Firmware 1004 in the main Dir name the file M2N-MX.ROM
2.Burn a Second disc with the 0804 Bios ROM also rename the 0804 Rom to M2N-MX.ROM
3. Go to EZ FLASH with ALT + F2 and then insert the 1004 CD wait till Erasing is ready Then Turn OFF your PC :-) so you crashed the bios thats what you need to run the embeded CrashFRee Tool
4 After you turn your PC on insert the 0804 CD then it flashes the this Rom and we are Happy :-)
mfg Eddi Hope this helps someone
Apr 16, 2008 | ASUS M2N-MX Motherboard
Weird error message on boot. BIOS error?
This is a strange one. Does the BIOS on your motherboard detect your hard drives at all? I'd try the lowest level first. If so, then try to boot from your XP CD ROM (hopefully this should work). Try to go into recovery console to see if your hard drive can even be mounted by the system. I'd check there.
If you still have issues,try to reflash your mobo BIOS to the most current one. Could be a flaky BIOS issue.
Feb 06, 2008 | AMI American Megatrends UltraSCSI...
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
NO CD-ROM FOUND
Nov 15, 2007 | ASUS M2N-MX Motherboard
Please Tell me, ASUS P4S8X-MX Problemn
First of all, try to reseat all the cables inside your computer just make sure there aren't any loose connections.
If that doesn't work you will have to reset your BIOS. (Follow the instructions in your motherboard manual.)
If even after resetting the BIOS the problem is not solved, you may have to replace your CMOS Battery.
Oct 18, 2007 | ASUS P4S8X-MX Motherboard
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
