Question about Thoroseal Thoro 5 Gallon Concrete & Masonry Sealer T1956
Is this black and white as in picture ? - Thoroseal Thoro 5 Gallon Concrete & Masonry Sealer T1956
Color pictures in color come from the printer in black and white
u need to change settings on the printer from black n white or printer settings in windows is set to black n white. even your graphics software could be set to black n white. normally its windows or on printer itself in configuration settings
Oct 19, 2014 | Kodak Office Equipment & Supplies
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Hi, how do you take black and white pictures on the Olympus µ Tough 3000 ?
you can't shoot in black and white but you can take a picture and change it to black and white.after taking your picture use the color edit option at playback.arrow right or left to choose the picture then press the ok button.use the right and left arows again to select desired color and press the ok button again.this will save a seperate image copy of you original only in black and white.
hope this helps.
Jan 09, 2011 | Olympus ? Tough 3000 / Stylus Tough 3000...
you have the cables hooked up the wrong way
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Black and white pictures
Are you serious?
I hope this question is a genuine one:)
You don't have to buy any special card, in fact there is no such thing as b&w picture card.
Please view the below for instructions:
Oct 25, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Color vs. Black/White picture issues
If the trouble is black and white looseboard in CRYSTAL. Loose need to resolder.
Apr 16, 2008 | Toshiba CF36G40 36" TV
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Taking black and white pictures
After checking out the owner's manual for that device I do not believe that this camera supports taking pictures in black and white. I believe that the only option you will have in this situation is editing the pictures once they have been transferred to the PC.
Sorry.
http://answers.yahoo.com/question/index?qid=20071105134544AAxrlIy
Nov 10, 2007 | Cameras
Thoroseal Thoro 5 Gallon Concrete & Masonry Sealer T1956 Logo
222 people viewed this question
Top Thoroseal Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Thoroseal Building Material Expert? Answer questions, earn points and help others
