SOURCE: Oven Temp
After it drops temperature, how do you get it back to the desired degrees? It sounds like the thermostat isn't keeping up.
SOURCE: oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Plz rate my solution.
Thanks.
SOURCE: whirlpool double oven. fan assisted oven is not heating up fan is
NEEDS A NEW HEATING ELEMENT
SOURCE: My kenmore gas oven won't heat. I turn to dial to
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
SOURCE: My double oven has stopped working, its only the
If the fan is working o/k, then you need to fit a new oven element, located at rear of oven behind removeable cover.
Please rate my solution.
Thanks.
