Question about Honeywell Heating & Cooling
Thermostat says recovery - Honeywell Heating & Cooling
Honeywell thermostat "In Recovery" Message?
In recovery only shows on programmable stats. It refers to the adaptive recovery when using the programming. Over time the stat will learn how long it takes to cool or heat to the programmed set point. For example, if during the day the programming is set to 80?, and at 4:30 the programming drops to 76?, if it takes 2 hours for the temperature to reach 76?, it will learn that it takes 2 hours and eventually it will start turning on at 2:30 so that at 4:30 the temperature is satisfied instead of at 6:30, at which point it is no longer in recovery
Aug 05, 2014 | Honeywell Heating & Cooling
How to take out system in auto recovery?
I have this same issue but figured out it is just the energy savings system regulating the change in temperature it doesn't really mean anything It is only for your system but if you place your thermostat on a temperature hold it won't go through the auto recovery system
Jul 14, 2012 | Hunter Fan Company 5/1/1 Programmable...
How difficult is it to replace a thermostat? on a contour 1999. has the smaller engine
REMOVAL & INSTALLATION
2.0L Engine
See Figures 1 through 6
Fig. 1: Remove the coolant recovery tank hose from the water outlet
Fig. 2: Remove the upper radiator hose from the water outlet
Fig. 3: Remove the three retaining bolts for the water outlet
Fig. 4: Carefully separate the water outlet from the thermostat housing
Fig. 5: Remove the thermostat from the housing
Fig. 6: Make sure you replace the O-ring when installing a new thermostat
  1. Disconnect the negative battery cable.
  2. Drain and recycle the engine coolant.
  3. Remove the air intake resonators.
  4. emove the upper radiator hose and coolant recovery tank hose from the water outlet.
  5. Remove the three retaining bolts from the water outlet and remove the outlet from the thermostat housing.
  6. Remove the thermostat and O-ring from the housing.
To install:
  1. Thoroughly clean the housing and install the thermostat and new O-ring into the housing.
  2. Install the water outlet and tighten the retaining bolts to 71-97 inch lbs. (8-11 Nm).
  3. Install the upper radiator and coolant recovery tank hoses to the water outlet.
  4. Install the air intake resonators.
  5. Connect the negative battery cable.
  6. Fill the cooling system with the proper 50 / 50 mixture and start the vehicle.
  7. Bleed the cooling system and check for leaks.
Hope this helps (remember to rate and comment this asnwer).
Jan 10, 2011 | 1999 Ford Contour
I need to change the thermostat
REMOVAL
  1. Remove upper intake manifold.
  2. Partially drain cooling system below the thermostat level.
  3. Remove upper radiator hose from outlet connector.
  4. Remove coolant recovery system hose from outlet connector.
  5. Remove coolant outlet connector bolts.
  6. Remove thermostat assembly, and clean sealing surfaces.
INSTALLATION
  1. Place the new thermostat assembly into the coolant outlet connector, aligning air bleed with the location notch on outlet connector.
  2. Install coolant outlet connector with thermostat in position onto thermostat housing. Tighten bolts to 12.5 Nm (110 inch lbs.).
  3. Install upper radiator hose.
  4. Connect the coolant recovery system hose.
  5. Install upper intake manifold.
  6. Fill cooling system.
  7. see thermostat mounting are below
Oct 19, 2010 | 2002 Chrysler PT Cruiser
Replace thermastat where is it and i need a easy fix solution
2.0L & 2.4L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect battery negative cable from remote negative terminal on shock tower and properly isolate to prevent accidental reconnection.
    CAUTION This operation must only be performed on a cold engine.
  3. Drain cooling system to the thermostat level or below.
  4. Remove or disconnect the following:
    Coolant recovery system hose Thermostat/engine outlet connector bolts Inlet hose and coolant elbow from thermostat housing
  5. Remove thermostat assembly and clean sealing surfaces.
    Fig. Thermostat and housing-2.0L and 2.4L engines
To install:
  1. Place the new thermostat assembly into the engine outlet connector. Align air bleed with notch on the cylinder head.
  2. Install engine outlet connector onto cylinder head and tighten bolts to 110 inch lbs. (12.5 Nm)
  3. Connect the coolant recovery system hose.
  4. Fill cooling system.
  1. Drain cooling system to the thermostat level or below.
  2. Remove the Coolant Recovery System (CRS) hose and thermostat/engine outlet connector bolts.
  3. Remove the thermostat assembly, and clean sealing surfaces.
    Fig. Thermostat assembly-2.0L engine
    Fig. Thermostat assembly-2.4L engine
To install:
    1. Align air vent upward with notch on the cylinder head (2.0L engine).
    2. Make sure spring side of thermostat faces cylinder head.
  2. Install the engine outlet connector onto cylinder head and tighten bolts to 110 inch lbs. (12.5 Nm)
  3. Connect the Coolant Recovery System (CRS) hose.
2.4L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the cooling system to the thermostat level or below.
  3. Remove the Coolant Recovery System (CRS) hose and thermostat/engine outlet connector bolts.
  4. Remove the thermostat assembly, and clean sealing surfaces.
To install:
  2. Make sure the spring side of the thermostat faces the cylinder head.
  3. Install the engine outlet connector onto cylinder head and tighten bolts to 110 inch lbs. (12.5 Nm)
  4. Connect the CRS hose.
  5. Fill the cooling system to the proper level.
Hope help with this (remember rated this post).
Apr 15, 2010 | 2002 Chrysler Sebring
THERMOSTAT DOES NOT FOLLOW SCHEDULE. COMES ON
sounds like it is in smart recovery mode check installer set up
Dec 18, 2009 | Honeywell Programmable Thermostat Heater
Where do i refill coolant? message reading low engine coolant.
please rate, thx Coolant Recovery System NOTE: When the water thermostat (8575) is closed, there is no flow through the radiator coolant recovery reservoir (8A080).
Trapped air in the cooling system must be removed. A pressurized radiator coolant recovery reservoir system is used which continuously separates the air from the cooling system.
  • When the water thermostat is open, coolant flows through the small hose from the top of the radiator outlet tank to the radiator coolant recovery reservoir.
  • The radiator coolant recovery reservoir separates any trapped air from the coolant and replenishes the system through its radiator coolant recovery hose to the water thermostat housing.
  • The radiator coolant recovery reservoir serves as the location for:
    • service fill
    • coolant expansion during warm-up
    • system pressurization from the pressure relief cap and
    • air separation during operation
  • The radiator coolant recovery reservoir is designed to have approximately 0.5-1 liter (0.53-1.06 quarts) of air when cold to allow for coolant expansion.
Jul 08, 2009 | 1995 Lincoln Continental
Error Message RE CO on Indiglo
Auto recovery – allows heating and cooling systems
to gradually recover from an energy-saving setpoint
temperature to a comfort setpoint temperature. Auto recovery
calculates the time needed to adjust the temperature to
the next program setting. When the thermostat is in Auto
Recovery mode, the display will flash alternating messages of
RECO and the time. Auto Recovery can be disabled by sliding
the recovery switch on the back of the circuit board to the
disable position.
(Auto Recovery will not operate if Permanent or Temporary holds
are on.)
Press Hold/Return during the Auto Recovery process to
manually cancel the recovery.
Jan 05, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
42 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
