Question about Jasco GE Wired Color Camera with Night Vision, 60ft Cable, 45231
Rewire 45231c camera
My end cut off what do i match the r/w/y/blue wires to
How to repair cut camera wire 45231c
This will need repair by a qualified artificer.
Nov 17, 2016 | Cameras
Wiring diagram for 45231c wired color camera security system was cut and wire is missing
Call the cops. This may be an indication that someone is planning to rob your home.
May 19, 2016 | GE 45231 Home Monitoring Camera
My end has been cut off my camera 45231c can I replace with USB end
Yes, but you will have to know the pin out so you know what cable is going to which cable.
Nov 10, 2015 | Cameras
How do I rewire a cut harness car radio of a chrysler town country 2010
If you have original cables match pins. Otherwise there should be a diagram or table (paperwork) explaining where to wire in the new to old wires.
Feb 07, 2015 | Chrysler Cars & Trucks
How do I bypass a factory amp in a 2014 dodge charger se? I am having trouble hooking up my 5 channel amp which leads me to believe that there maybe a factory amp installed on my car.
Doubtful, trace wires from speakers using test light, does new amp have coaxial connectors? you may have incompatible model, probably need to match amp with new head unit, worst case you can rewire speakers directly to amp, use new wires, leave old wires in place just cut ends and put tape over.
Nov 11, 2014 | 2014 Dodge Charger
Seats wires were cut, between the two front seats and also from the drivers seat to the panel. Need to know instructions to rewire
what u need to do is count how many wires are cut and will the wires reach eachother like do you need extra wiring to make up the differance all the wires are in colors like blue and red black and white 2 colors per wire some wires are a single colre ie blu blk rd yl match up youre wires to each other blu to blu red to red etc you will need **** connectors u can get at any automotive parts store or even walmart will have these u will need 1 **** connector per broken/cut wire all u do is strip the end of each wire about 3-8ths long slide one end into the **** connector and crimp that side then strip the other wire of the same color about3-8ths of an inch slide it in to the corresponding color **** connector
Oct 10, 2009 | 1995 Mercury Cougar
I need to replace vacuum hose
If you have a vise, put the end in to and you want to just squeeze it so you can get to the 2 tabs inside and using 2 flat blade screwdrivers, pry outward and the hose should come out of the cuff. Sometimes you can just cut and rewire, but watch and match colored wires to the right colors, mix them up and you would have a electrical mess. When you put it back together, push the cuff down until you hear it snap into place.
Mar 24, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Jasco GE Wired Color Camera with Night Vision, 60ft Cable, 45231 Logo
53 people viewed this question
Top Jasco Home Security Experts
Lawrence Oravetz
Are you a Jasco Home Security Expert? Answer questions, earn points and help others
