Question about Scott Aspect 30
What size bottom bracket is in the scott aspect 30
Why cant I get it off of wide screen? Everyone's head are cut off and can not read subtitles at bottom.
the aspect ratio is the picture size control
when you select aspect ratio you have to move with the arrows to get the size that fits the panel the best - go ok then exit to save the setting
if that doesn't work the the tv will need attention in a repair shop
Sep 03, 2015 | Televison & Video
Bottom bracket size
Typical mountain bicycles are 73mm, though modern (in the last 5 or so years) some have been going to 68mm. You can measure the bottom bracket shell. That is the part of the frame where the bottom bracket is inside. Measure from edge to edge without including the cups of the bottom bracket itself.
Apr 06, 2014 | Raleigh M80
Bottom bracket need replaced. needs a new crank set. what size if the bottom bracket and what size crank set is recommended, or does the bottom bracket need to come out to find the size. bought the...
impossible to tell you without knowing the bike brand and model and year, although you have provided that 1999.
If you take into a bike shop, which is the usual place to purchase the parts you need, they will be able to tell you what size Bottom Bracket will fit your bike, also what options you will have for replacement cranks and bottom bracket. This could be a very complicated issue when replacing with parts that are 11-12 years newer, the shop will be best equipped to give you all your options.
Apr 07, 2011 | Cycling
Getting a clicking sound from the bottom bracket area. I have a Denali Pro. Can I replace the bottom bracket and what size
Yes, of course you can replace the bottom bracket.
First though you will want to make sure that the clicking noise is in-fact coming from the bottom bracket. Even though it sounds like it is coming from that area there are other things that can cause a clicking noise, such as the examples below.
Front derailleur cable end hitting the crank-arm is a common clicking noise.
Pedals can also cause a clicking noise that sounds like its the bottom bracket.
chain rubbing the front derailleur
chain has a kink in it.
The size of your bottom bracket is related to a few factors:
1 - thread pitch (your bike is english)
2 - Bottom bracket width (your bike is 68)
3 - Crank style and brand. This I do not know for your particular bike as you did not provide the year of the bicycle or brand of crank, and they change.
Taking off cranks and removing and installing a bottom bracket requires many bike specialty tools and is probably not the best project if you have never done this before or own the tools. It will be far less expensive to have your local bike shop replace the Bottom Bracket then to do it yourself. Plus they can tell you what size it needs and if the click is even coming from that part or not.
Dec 10, 2010 | Cycling
My 51f59 tv is zoomed in too close to see the all of the bottom
look for a button on remote called format , aspect or picture size and press it till the picture fits the screen
Feb 04, 2010 | Hitachi 51F59 51" HDTV Projection...
How can I make the picture size fit the screen? I loose picture around the edges. Seems like it is displaying at a larger size
The issue your having is aspect ratio. Some programs and commercials are broadcasting in a higher resolution so some fill the screen and some have black bars top and bottom. I suggest searching "aspect ratio for video". It would take me all night to type it out. But you need to know how the different resolutions change the size of your image. Also in the TV's menu you should see an aspect ratio option. Try the different settings to see if you can find the best.
Aug 19, 2009 | Zenith A25A23W 25" TV
I can't get the picture to fully fill the screen on my 46'' TV. Model code ln46a750r1fxza. Used the ''tools'' button on the remote and tried adjusting the picture size, but it did not correct the problem....
First set your tv to 16:9 aspect ratio. Then go to the source ie: Cable Box or Sat Box. Then go into the User Menu and find the Set Up or HD settings or picture settings. You need to set the Box to the "Stretch" setting. Right now your source box is set ot 4:3 aspect ratio.. If you have difficulty in changing the aspect ratio on the source box, call the Cable or Sat co. They can help you.
Jul 09, 2009 | Samsung Televison & Video
Need a belt diagram
Forward belt is a 1/2 by 27 (L4270)
Reverse belt is a 3/8 by 30 (L3300)
Apr 09, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Scott Aspect 30 Logo
42 people viewed this question
Top Scott Cycling Experts
John Egan
John Egan
Are you a Scott Cycling Expert? Answer questions, earn points and help others
