Question about Lego Digital Camera.
Cannot turn on Lego Digital Camera
I couldn't start my Lego Digital Camera on though I charged it for that specific time required.
I cant charge the battery through computer
The C183 isn't a battery charger. If you use rechargeable AA batteries in it, you must charge the batteries outside the camera using a separate battery charger.
Aug 01, 2012 | Kodak C183 Digital Camera
My camera won't turn on even though it's fully charged
Is there no sign of any light from the camera when you turn it on? When was the last time you used that camera? If you have left the battery inside the camera for quite some time, then most probably, it got exhausted. Despite of being charged for hours, can you put back to the charger again and see if it gives a red battery charging indicator? If it gives a red light, then you may need to replace the battery pack.
Hope this helps. Thank you for using FixYa.
Dec 20, 2010 | Olympus FE-370 Digital Camera
7340 won't turn on green light comes on for a couple clicks and turn red , it used to turn on but you had to start it several times?
Please check whether the battery is fully charged. Try power resetting the Camera.
Remove the battery from the Camera. Press and hold the Power button for 30 seconds. Then, reinsert the battery after 1 minute and check the operation.
If the issue still persists, service might be required.
Jul 26, 2010 | Vivitar VC-7340 Digital Camera
What specific memory card is required?
Memory cards should be formatted before use. They should also be formatted each time you finish downloading pictures from it.
Jul 05, 2010 | Vivitar ViviCam 3720 Digital Camera
Camera not working even though charged
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge. This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time for new batteries, or the camera may have a problem that requires professional repair.
Dec 31, 2009 | Kodak EasyShare C513 Digital Camera
When camera is turned on it suddenly powers down
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 29, 2009 | Vivitar ViviCam 5340s Digital Camera
My camera pentax optio wp wont turn on. though is
If possible, check the charger output or the charge status of the batteries with a voltmeter. That will narrow the field for you. If the charger and batteries seem OK, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 21, 2009 | Pentax Optio E40 Digital Camera
When I turn my camera on it makes funny noises and tries to open up but then closes right away it does this a few times then shuts and the screen turns blue and says D:?????? D:?????
Two possibilities: one bad, one not so bad. If you've recently dropped the camera you've likely damaged the lens tube (housing), and the camera will require professional repair. Before you panic though, the problem that you described is frequently battery related. Make sure that your batteries are the correct type for the camera, and that they are fresh/fully charged. If the batteries are OK, the problem may be due to corrosion on the contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
Sep 10, 2009 | Olympus Stylus 710 Digital Camera
I start LEGO Star Wars but then says lego starwars stop wrking
LEGO Star Wars II for PC requires the following minimum system requirements:
Operating System
Required: Windows 2000, XP, or Vista
Computer
Required: 100% DirectX 9.0c compatible computer
CPU
Required: Intel P3 1.0 GHz or AMD Athlon 1000 MHz
Recommended: Intel P4 2.0 GHz or AMD Athlon XP 2400+
Memory
Required: 256 MB RAM
Recommended: 512 MB RAM
Graphics Card
Required: 64 MB 3D Graphics card with Vertex and Pixel Shader (VS/PS) Capability
Recommended: 128 MB 3D Graphics card with Vertex and Pixel Shader (VS/PS) Capability
Sound Card
Required: 100% DirectX 9.0c compatible Audio Device
CD-ROM
Required: 8X Speed CD-ROM drive
Recommended: 16X Speed CD-ROM or DVD-ROM drive
Input Device
Required: Keyboard and mouse. Gamepad and joystick supported
Recommended: Gamepad
DirectX
Microsoft DirectX 9.0c (April 2006 Edition) is included on this CD. You will be prompted to install DirectX during the installation of this game if this or a more recent version is not already properly installed on your system.
NOTE: DirectX may require the "latest" updates for your operating system. This may also include the latest drivers for your motherboard, sound, and video hardware.
Installation: Installation requires 3.5 GB of free hard drive space. We recommend that you have an additional 500 MB of free space available after installing the game for the Windows swap/page file.
You must have local Administrator rights to properly install LEGO Star Wars II and update Dire
No other programs should be running in the background.
System resources should be at least 85% free.
To check this:
Press CTRL-ALT-DEL once, choose Task Manager, choose the Performance tab, and check CPU Usage.
There should be at least 500 MB of free hard disk space after installation.
If you experience performance issues when running LEGO Star Wars II, we recommend that adjust the following options in the Video Options menu:
Lower the video resolution.
Set Antialias to Off
If this option is set to Antialias from Control Panel, you will need to set your Antialiasing Setting to Application-Controlled in the Windows Display Properties for your specific graphics card.
Disable Bloom Effect.
Please close all other programs before running LEGO Star Wars II. This includes virus-scanning, word processing, and Internet programs. Simply disabling these programs will not always help, as the programs still use resources that are needed to run LEGO Star Wars II. If you experience problems completely closing programs that are running, consult the documentation for those individual programs. This is a common problem when trying to completely disable virus-scanning software.
Jan 18, 2009 | Origin Lego STAR WARS 2 for Windows, Mac
Lego Digital Camera. Logo
37 people viewed this question
Top Lego Cameras Experts
Are you a Lego Camera Expert? Answer questions, earn points and help others
