Question about Drills
HOW TO REMOVE THE CONNECTING ROD FROM MY HILTI HAMMER DRILL MODEL # TE-16C
THE PISTON CONNECTING ROD IS BROKEN AND I NEED TO REMOVE IT TO REPLACE IT
rowdy45176
  • 2176 Answers
SOURCE: Hilti TE-60 hammer drill
what I would do if you have a fax machine is call 1-800-879-8000 and request a schematic on this tool first. Some of their products are not that easy to disassemble. I never have worked on the TE-60 but have on some of their other products and they are all different. Hope this helps
Posted on Dec 19, 2008
  • 123 Answers
SOURCE: hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Posted on Oct 09, 2009
  • 61 Answers
SOURCE: HAVING A PROBLEM WITH MY HILTI TE5 HAMMER
the bearing in the chuck is probly missing. replace the ball baering.
Posted on Oct 11, 2009
  • 165 Answers
SOURCE: Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
Posted on Feb 27, 2010
ftw1952
  • 10319 Answers
SOURCE: Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Posted on Mar 11, 2010
Hilti TE 74 not hammering
It takes 70 cc of oil in the gear casing. Too much oil will snap the connecting rod. If it did not have oil in it there might be a leak somewhere
Nov 06, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
DRILL TURNS SLOW OR JUST GROWELS.NO HAMMER ACTION IN DRILL OR HAMMER MODE.FROM WHAT IVE READ SOUNDS LIKE CONNECTING ROD IS BROKEN.IF SO ARE THEY AVALIBLE AND CAN YOU GIVE ME AN APPROXIMATE COST FOR...
First thing you should do is contact Hilti's customer service @ 1-800-879-8000. they can get you any parts you need. Ask them to run the serial number. it is possible that that tool is still under their 2 year warranty.
Jul 27, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
I have hilti te 72 it works but will not hammer
More than likely the con rod is broken. To check remove the shift lever on top by removing the center phillips head screw. then with internal snap ring pliers remove the snap ring.put your phillips screw back in with out the shift lever. Take a pair of pliers and grab the screw and pull the shift boss out. You then can see if the con rod is broken or not. The bad news is those parts are hard to come by.
Dec 15, 2010 | Hilti Drills
We have a Hilti TE72 Hammer Drill.... We have taken it to fix but they say they can't find parts... We think it is the piston and a rubber gasket that goes with the piston.... Do you have this?
Parts are no longer available for the TE72. You may find some used parts on EBAY. If the tool is not hammering it would need more than the piston and oring that goes on the pistion. Without all the proper seals and gaskets I would not even attempt to repair. If you do attempt to repair it do not put more than 70cc of lube in the drill. Too much oil will distroy the gears.
Aug 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 17. Hammer doesnt work. Rotary does.
Most likely the O-rings are worn - tool has no compression to move the hammers inside.
Less likely: the connecting rod for the piston is broken so piston isn't moving - or 2nd hammer is broken into pieces.
I would open it up & check the orings first
Jul 31, 2010 | Hilti Drills
Turns but does not hammer
Hilti no longer carries parts for the TE72. You would have to find parts on Ebay or somewhere like that. There is a good chance that the con-rod is broken. Taking off the selecter lever on top. Removing the snap ring and then pulling out the shift boss will allow you to view the con-rod.
Jun 03, 2010 | Hilti TE 70 Hammer Drill Performance...
Hilti drill want hammer.
Not positive but I think that it works on air. Is there a cylinder with a piston in it. The orings could be blown?
Im not positive. Just tryn to help
May 30, 2010 | Hilti TE 70 Hammer Drill Performance...
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
HILTI TE 72 STOPPED HAMMERING BUT STILL WILL DRILL
It could be that your connecting rod is broken. You can check by taking your shift lever off of the top of the gear housing and then removing the snap ring to remove the shift boss. That will allow you to look at the crankshaft and connecting rod. If it is broken I would check with Hilti to see if they still carry parts for the TE 72.
Mar 07, 2010 | Drills
Hilti te-72 hammer failure
Jul 20, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Drills Logo
65 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
