Question about fantage.com
After i put my info on freefantagehack.webs.com it said "Keywords in the labels of this form are preventing it from being submitted." What does it mean and what should I do?
Can I get a replacement rack for our Cooks 6 slice toaster oven?
try this web site supplier if they dont have one
it will be a discontinued part
you would have to find and buy a used cooks 6 toaster oven
http://spares.bigwarehouse.com.au/parts_search_result.php?keywords=toaster%20oven%20parts&submit=Search&gclid=CLrfwqKUtcwCFRQHvAodOHoLuA
Apr 29, 2016 | Toaster Ovens
The form at http://www.thecondoexperts.info/form/basic.htm is not working. That form is on my landing web page at www.thecondoexperts.info. Can someone tell me how to correct the form in order to make...
For starters, your form named basic.htm has an incorrect function:
FORM
ID="frmMain" ACTION="http://www.thecondoexperts.info" METHOD=post>
should be
FORM ID="frmMain" ACTION="http://www.thecondoexperts.info/request.php" METHOD=post>
The request.php takes the form information when you press the Submit button, processes it and sends out and e-mail to your account and the customer. If there is an error in the form the request.php will send the customer to an error page instructing them to try again.
Oct 03, 2011 | Computers & Internet
Reinstalling arcsoft showbiz2 on to computer and it is asking for an activation code ??? Have used it countless times and now can't access it without this code
1. Launch ShowBiz.
2. Under the Help menu select Online Product Registration. Your web browser will launch and display the registration form.
3. You can find your serial number in the Serial Number field of the registration form. Or you can fill out the registration form and submit it. You will need to be connected to the internet to submit the form online.
Jun 21, 2011 | Arcsoft ShowBiz DVD 2 (3265)
Kenmore Side by Side Refigerator. Freezer drain is blocking up and ice is building up in the bottom of the freezer section. We have thawed everything three times until we hear the water draining from the...
You can install a drain heater, available at http://aplusapplianceparts.com/searchquick-submit.sc?keywords=279827 to prevent it from freezing. It simply wraps around and secures to the defrost heater assembly to prevent freezing. Use coupon code 1050 for a discount on your order!
Jan 02, 2011 | Refrigerators
Hello. I need a simple help (I think). If I have an webbadress like "http://my.adress.com/home.html" and I want to make a form that puts whatever you type in a textfield at the end of the...
A simple solution would be!
<form action="http://my.address.com/home.html<?php echo $name; ?>" method="get"><!-- Note a variable after the link -->
<input type="text" name="name" value=""/>
<input type="submit" name="submit" value="Submit"/>
</form>
<?php
    if(isset($_GET['submit'])) {
        $name = $_GET['name'];
Dec 29, 2010 | The PHP Group PHP
Cannot fill net forms and submit them
It could be the web page itself but it could be the connection.  It's very unlikely to be the application/Operating system you use.
Apr 28, 2010 | Computers & Internet
I have a Saeco Royal SuperAutomatic and I'm trying to just use my own free endless supply of dilute raw HcL acid to decalcify it. Before everyone freaks out, this shouldn't be rocket science to use...
Hi I know that Durgol does not contain HCL, but a different acid and other stabilizers, to prevent corrosion of boiler parts. Remember what you put in you machine you might drink. The boilers in you machijhe are either aluminum or stainless steel and both can be damaged by HCL.
Feb 13, 2010 | Solis Crema SL-90 Espresso Machine
Editable forms with Adobe reader?
With adobe profesional you can make a PDF form, and send to the recipients. They can fill the form with Adobe reader and send it to you back, but only the data will be sent to you, not all with the pdf.
You can collect the data with your adobe profesional. Your programmer of medical paperless system can make the program to put that data in your database.
Here is the simple procedure:
1. Create form: Open adobe prof, menu advance --> Form --> create new form. You will go to Adobe design to create the form, there you can also retrieve your scanned document.
Don't forget to put "submit button" and your email address.
2. Then save as pdf form. It is ready to be send to your recipients.
3. The recipients will fill the data and send to you by pushing the "submit button".
4. You will receive the data in your mailbox, as an attachment of email. You can use adobe prof to collect it, example to put it in Microsoft Excel.
Go to menu advance --> form --> Create Spreadsheet from data files. A dialog box will come out, put in the files you received from your recipients. then go on, you will have the Excel data.
For put it in your database of your system, your programmer should create a program/ included in your system's program.
For Guest, to fill up is easy, just open the pdf form with Adobe REader, fill it and click the submit button.
Apr 15, 2008 | Adobe Acrobat Professional 7.0 for PC
JSP: Java code doesn't go steady with the HTML code,no output seen!!
<html>
<body>
<form name=form1 action=test.jsp method=Get>
name:<input type="text" name="user">
<input type="submit">
</form>
<%=request.getParameter("user")%>
</body>
</html>
Feb 22, 2008 | Computers & Internet
fantage.com Logo
141 people viewed this question
Top fantage.com Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Tom Chichester
Are you a fantage.com Computer and Internet Expert? Answer questions, earn points and help others
