Question about Apple PowerBook G4 Mac Notebook
Dim screen on Mac A1013
Screen is dim
  • 69 Answers
What os are running. Check in the preference pane under display if auto brightness is enabled if yes doable an increase brightness slider.
Posted on Feb 13, 2014
Screen dim lighten
On your Mac...
Click on the Apple icon at the top left of your screen.
Then select System Preferences.
Then select the DISPLAYS icon.
In the displays window, you will should see a Brightness slide bar. Make sure that slider bar is all the way to the right. The the slider bar is already to the right side, then it might be a hardware issue with your Mac. =(
Feb 06, 2014 | Apple Computers & Internet
Hi, I have an Ibook G4 and i have a problem with my backlighting, it is very dim hardly visable. Is there any free solutions ?
F1 and F2 on the keyboard make the backlight go dim or get brighter. connect an external display to the computer if the issue doesn't show up on the external display it's the LCD inverter board that will need to be replaced.
Jan 15, 2011 | Apple iBook G4 Mac Notebook
Computer Monitor is dim
Time for a new flat screen monitor...The power supply is on it's last legs.
Apr 03, 2009 | Toshiba Tekbright 15" CRT Monitor
MacBook screen dims
first there could be many meanings of dims with a laptop screen one is backlight has turned off and it is difficult to see.  if that is the case use you brightness key to check if it is up, if it is more likely your inverter has gone up and in worse cases the screen. it may also start bright then change dim while loading
there is also the feature on mac to automatically dim the screen a little when unused for a set time.  to change this go to system preferences, go to energy saver, click show details, then move to options, and uncheck the the box that says "Automatically reduce the brightness of the display before display sleep".
i hope this is what you are talking about.
Mar 14, 2009 | Apple MacBook Mac Notebook
The screen on my Apple Powerbook G4 goes dim and sometimes out.
How long before it goes dim?
Does it start strong, then dims right away?
Feb 27, 2009 | Apple iMac G4 Desktop
MacBook Screen Problem
Hi there
If I understand you correctly from start up the screen is dim but does brighten up after time? But now after start up you are getting a flicker how ever a restart solves this.
On the dimming issue. Check your energy saving settings and brightness key is working OK.
The flickering is a bit of a concern.
Just a couple of questions.
Are there any dead spots on the screen? Areas where there are no pixels.
When you tilt the screen forward and backward, does this effect the brightness or flickering?
Paul
Sep 03, 2008 | Apple MacBook Mac Notebook
Dim Screen
A very dim screen is an indicator that the screen inverter or the screen itself is going out. Start by checking the screen connections, they sometimes work loose. If the connections are good, then it's the inverter or screen and will need to be replaced.
Jun 26, 2008 | IBM ThinkPad A21m 2628 Notebook
Screen is dim
Try looking for a function key (usually used by holding down the Fn key and then pressing one of the "F" key at the top) the key will be marked with a brightness indicator.
Is your screen only dim when running off the battery is it dim when running when the charger is plugged in as well. If it is only dim when the laptop is running on battery then this may be caused by a setting in Power Options which is located in Control Panel (that is if your running Windows). In Power Options look for settings about running on AC Power and running on Battery power.
Jan 07, 2008 | Dell Inspiron 8500 Notebook
Apple PowerBook G4 Mac Notebook Logo
48 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
