Question about Estate TAWS800JQ Top Load Washer
Is the balancing bar suppose to contain water on estate washer?
How much sodium is in Balance Bars?
The amount of sodium in Balance Bars is different from flavor to flavor. The almond brownie contains the least amount of sodium with only 75 mg, while the chocolate peanut butter contains the most sodium per serving with 190 mg. Gold Caramel Nut Blast has 150 mg of sodium and Organic Cherry Almond Crisp contains only 100 mg of sodium per serving.
Jan 24, 2013 | Health & Beauty
Washer tub has water but it will not drain
If you are refering to the sloshing sound when tub is moved back and forth it is supposed to be there. That is the balance ring. It is a liquid filled ring at the top of the tub that acts as a counter weight to keep tub balanced.
Jan 19, 2013 | GE WBXR2090B Top Load Washer
Neptune-is water supposed to remain, after wash is finished, between tub and outer shell
if you hear water when you spin the basket,that is the front tub balance ring.it is filled halfway with water in order to assist mach in balancing load.that is a normal sound.the mach may also leave some water between the basket and outer shell depending on lengh of drain hose.as long as the clothes do not come in contact with the water it is fine.
Sep 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer leaking from bottom
Take the front panel off of the washer, and run it through a cycle. Watch to see where the leak is coming from. Also, pay attention to the drain in the wall when it is in spin/drain. If this has a blockage in it, it might be backing up causing water to come back out of it.
If you see no leaks the next time you run it, it's possible that it splashed over while spinning because of the off balance load and may not happen again unless it becomes off balance again.
Apr 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer leak in an estate washer
i have Had 3 estate washers leak on all four corners....there junk went with ge instead......estate washers are horrible
Mar 20, 2008 | Estate TAWX700JQ Top Load Washer
Final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
Jan 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Unbalanced washer
You are on the right track, the back legs are self leveling ( or supposed to be ). The problem is going to be on the RIGHT side, it is jammed or possibly rusted/corroded or maybe somehow it got turned slightly and is not in the track properly, it should be moving like the left side.
Nov 07, 2007 | Whirlpool LSB6200KQ Top Load Washer
Spin Shake ...
yes the water is supposed to be there, thats called the balance ring, some machine use cement others water. you say the washer is unbalanced even when empty, is there an indicator or is the machine itself physically off balance. if there is an indicator the off balance swich might have gone bad or you might need to adjust the leveling legs.
Jul 03, 2007 | Frigidaire CWS3600AS Top Load Washer
Estate TAWS800JQ Top Load Washer Logo
14 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
