Question about Roland GX-24 Vinyl Cutter
My roland gx 24 is not cutting smooth on the upward cut, what can i do to repair this?
I am tearing my hair out trying to get any output from any of the software I have (sign cut, corel x5, easy cut, cut studio etc) from my Roland Camm1 cm 24. I can do the test cut from the cutter which...
The problem is more likely the operating system compatibility with old kit.if you are running something like 64bit windows 7 then the best solution is to have a dual operating system and install windows Xp.there may be updated drivers some where internet
wise.or you could try running in compatibility mode.
lpt and comm refer to older machines with serial port and parallel ports.if you do use USB you are better off using the rear ones as opposed to front end as they connect direct to motherboard.
if you have already tried go to the Roland site and see what support downloads can offer for system compatibility.otherwise you may find a forum via search engines with a driver.until then your machine will not communicate properly with you computer setup.also right click the executable for the software in its own folder and see if you can choose compatibility mode .best will be windows 2000 or Xp.
Mar 29, 2015 | Parallel Office Equipment & Supplies
What is meant by the term contrast when applied to drawing in graphics
Definition:
(noun) - Contrast is a principle of art. When defining it, art experts refer to the arrangement of opposite elements (light vs. dark colors, rough vs. smooth textures, large vs. small shapes, etc.) in a piece so as to create visual interest, excitement and drama.
The colors white and black provide the greatest degree of contrast. Complementary colors also highly contrast with one another.
Feb 18, 2014 | Nostalgia Air Cleaner For Harley 93-06...
How to get out of dpics mode on a roland camm-1 pro gx400
Please help us the error code comes "dpics mode" in roland gx-500
Jul 29, 2012 | Roland GX-400 CAMM-1 Pro Vinyl Cutter
PAG2200D angle grinder has 2 guards.One is a half guard,the other covers both sides of disc. Which one is used for grindins,which for cutting?
The double sided guard is the one for cutting and the single sided one is to allow you ot use the flat side of the disc for grinding. (Do not use cutting discs for grinding, on these discs use only the very edge of the disc and always wear protective eyewear and gloves. Never allow the stationary machine to rest on the disc, lay to rest with the disc facing upwards and disconnect the power lead when replacing discs etc. These are very dangerous power tools and should be treated extremely carefully).
May 26, 2011 | Saws
Manual for Roland Cut Studio Software
Here is a link for the Cut Studio manual direct from the Roland DGA website.
http://support.rolanddga.com/docs/Documents/departments/Technical%20Services/Manuals%20and%20Guides/RU_CutStudio_Basic.pdf
You Tube Videos:
part 1 of 2
http://www.youtube.com/watch?v=5IPzc2YjRS4
part 2 0f 2
http://www.youtube.com/watch?v=iHLHFz80_Gg&feature=related
Mar 20, 2009 | Computers & Internet
Please i have a roland pnc - 2300 to engrave gold peices
please i have a roland pnc - 2300 to engrave pices of gold the program software i use is called ( ats graphic suite version 1.02) when i want to start engrave i click file engrave and give the order but the printer didn't begin the engrave there was inside the folder printers a file called cut script i didn't find it and the roland didn't start engrave can you help me my email is flexoart1@gmail.com
Regards Saleem Tahir
Mar 11, 2009 | Microsoft Computers & Internet
Roland keyboard. Extremely static-y speakers. Cuts out.
It sounds like your volume slider is dirty. Try carefully and judiciously spraying a good quality contact cleaner into the slider and working it. do not use a lot. It only takes a little. Also do not use WD40.
Mar 01, 2009 | Roland Juno-D
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Roland GX-24 Vinyl Cutter Logo
63 people viewed this question
Top Roland Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Roland Craft and Hobby Expert? Answer questions, earn points and help others
