Question about Samsung Televison & Video
Ua5000pr led top porstion black strip show - Samsung Televison & Video
Lg 50ln5700 flashes then goes black
Hi Randy,
Since you have replaced all boards and the TV still does not work, The LED's strips have failed and will need to be replaced.
Check the link for more info about how replace the LED strips.
Feb 25, 2017 | LG Televison & Video
Ive got a LG 55" LED tv model #55LA6200 it will turn on and show the LG screen then goes black after a few seconds. Audio works and i can see the screen with flashlight which part do i need.
This could be the power supply at 55 dollars or the LED back light strips that are about 80. Unless you know how to test them, it is a toss up. Most of the time it is the led strips though. http://www.shopjimmy.com/lg/55la6200-ua
Feb 22, 2017 | LG Televison & Video
Lg black creen has sound tv
Hi James,
This is a common problem with all brands of LED TVs and mostly it is the LED strip which goes bad. If you can reach the strips, simple multimeter can be used to test the LEDs. A good LED will glow on low resistance range. In the strip also there will be only one or two or more LEDs will be defective which can be replaced individually. I hope it will help.
Good Luck.
Nov 06, 2016 | LG Televison & Video
Vizio e470i-ao led tv faded black bar thru middle of screen. still bright top and bottom, was told backlight was the issue. wwhere do i find the parts and the how to?
Hi Tala,
I appreciate your DIY approach, but the job is very delicate, risky and needs high level of proficiency. The screen is lit by several strips of LEDs. In your case probably the middle row of LEDs has failed. You have to open apart the LCD module to find out what kind of LED strips they have used and there is every chance of damaging the delicate LCD screen or the SHEET as they call it. Better hand over the job to someone who can do it.
Good luck.
Apr 13, 2016 | Vizio Televison & Video
Black screen, audio, no backlight. What's wrong?
This is most likely a failure of the actual LED strips themselves. They do attach to a board at the edge, it could be the board but you have to order the board and strips as one unit.
http://www.shopjimmy.com/lg-lc420dug-jfr1-led-strips-10-strips-1-board.htm
Apr 04, 2016 | Vizio E420I-A0 42" LED TV 1920x1080, 120...
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
I have a vertical strip about 3/16" wide about 3/4" from the left side of the page that will not print in the black only. I have replaced the black toner and black drum unit, and it is still there.
The LED Assembly LU5831001 is probably bad. This machine has 4 LED assemblies mounted in the top cover. It doesn't use a laser scanner.
To troubleshoot, you can clean them, then swap them between colors before you buy it.
25296363-yargu4yf5zncljh0zgcte5yj-3-0.png 25296363-yargu4yf5zncljh0zgcte5yj-3-2.png
Nov 24, 2014 | Brother Hl3070cw Hl-3070cw Color Laser...
Bottom half of screen is black
The display strip is not properly seated in the connector base. That is a hardware problem so dont think of a software error.
Oct 07, 2014 | Samsung Un46eh6000 46-inch 1080p 120hz Led...
Receiving fax with a black wide (2") line from fax Brother Intellifax 4100
its the problem of your LED'S strip may be one of the LED is not working.It lights up green in color & its located under the top cover from where you send fax copy.
Please rate me if it was helpfull..
Aug 04, 2010 | Brother IntelliFAX 4100 Laser Fax
Televison & Video Logo
15 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
