Riso error code T5
When i put it on it displays ready but when i press the print botton it displays T5
Bubbabear64
  • 2794 Answers
SOURCE: Copier light will scan but will not print.
Black toner supply mechanism malfunction. It could be a bad toner cartridge.
Posted on Nov 19, 2008
  • 5 Answers
SOURCE: Error Code T14 on Riso GR3770
press reset .. is drum in home pos. ?
Posted on Feb 09, 2009
  • 22 Answers
SOURCE: RISO RZ200
D22-542 is saying that there's a problem with the printed circuit board on the print drum. It's not communicating with the machine. D04 -534 says that the incorrect ink cartridge is installed. First, is this a new drum you are introducing into the machine? if it is, not all drums are interchangeable. You need to get the right pcb (printed circuit board) for the ink drum you are using to match your machine. Second.. Something is mismatched here with the ink cartridges. The only way you'd get the ink cartridge error is if the drum is in the machine. I had this problem with a Rn 2130 ui.. I bought a used drum off e-bay and it wouldn't work. When I stole the pcb from another color drum it worked fine. If you have been using this drum in this machine before... be sure that the connection between the drum and the machine is good. Make sure you have the right ink cartridge too. Some of these aftermarked re-sellers sell stuff that doesn't line up with the tabs on the inside.. I've got some ink here that if you hold your toungue just right and turn the tube about 2 degrees it'l work.
Posted on Aug 14, 2009
  • 76 Answers
SOURCE: Have riso cr1610 - prints for few copies, stops,
Ink overflow. Fit new squeezy gear in drum.
Posted on Oct 08, 2009
  • 747 Answers
SOURCE: Riso RA 4050 displaying error code E 57. What is
papper jam.
Posted on Feb 15, 2011
Error code PO4-513 on rz 390. overflow problem. I've seen the drum taken apart and cleaned out. any step by step instructions?
There is a much easier way to solve this problem. get a reem of paper and put it in the machine.
next turn the power off hold down the left and right Print Position arrows and power up the machine.
when it boots it will show u a number. at this point you can let go of the arrows.
press the yellow clear button 1 time and the machine should show all zeros on the display.
enter the code 80 and press start. the machine will make a master. after that it will show you 80 again.
press the c button at the bottem of the keypad and it should show 0000 again.enter 888 and press start and set the print speed to the slowest speed possible. (if it keeps jamming try pressing stop and repeating above steps but with code 81)
this is the ink drainage mode it will keep printing until you press the stop key.when the image starts getting light press the stop key and turn the machine off and then on again. and the code should be gone!
Jun 22, 2011 | Riso RZ390 Duplicator
My riso ks 800 duplicator shows E13 Error code
my riso ks 800 duplicator show error code E3
Apr 14, 2011 | Office Equipment & Supplies
ERROR CODE T04-513 FOR RISO RP 3790
riso rp 3790 no imprime, no copia, me dijeron que borrara errores pero no se donde, creen que sea eso
Feb 27, 2010 | Riso Office Equipment & Supplies
Riso 390 has error code d4-534
The machine do not reconise the ink.At the back of the ink there is a electronic chip that tells the machine what tipe of ink it is.There is a problem with that chip or the ink is not compatible.Replace your ink in most cases this will solve it,but let me know if I can futher assist.
Thanks for supporting us.
Dec 11, 2009 | Riso RZ220 Duplicator
RISO RZ200
if show ERROR CODE D22-542 means the board in the drum have some problemif show D04-534 means you are using not original ink, but just press restart key is ok.
Apr 13, 2009 | Riso RZ220 Duplicator
I HAVE A PROBLEM WITH MY RISO RZ200.ON MY DISPLAY APPEAR AN ERROR CODE D22-542.IF I REMOVE THE CARTRIGE APPEAR D04-534.WHAT SHOUD I DO?
go into test mode..
turn off machine and turn it back on while holding down the left and right print position arrows.
if the error code shows up.. press the yellow reset button to clear it.. you will then see a number (firmware ver.) press the "C" button on the number pad..
you should then see the display all zeros "0000"
enter 890 and press start.
then when it beep press the "C" again enter 112
when it beeps again press and hold the yellow clear button and the machine will reboot...
i am sorry to say that if this did solve the problem you will need replacement parts or a new drum
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
Riso Rz 220
Remove the master that is on the drum. Then check the master roll remove it cut about 18 inches off then re install master roll. hit the reset, then print bottons.
Jun 11, 2008 | Riso RZ220 Duplicator
13 people viewed this question
k24674
jasbo
jasbo
