PX759AA-ABA a1120n bios unlock
Version 3.28 date 01/23/2006 ROM size 512 KB 0nx1114RE101Gold300 serial CNH5220T3Q NA570 UUID {D5440800-D0AF-11D9-B87E-8AE127278698 ASUSTeK Computer INC. model Goldfish3 Processor manufacturer Intel model Intel(R) Pentium(R) 4 CPU 3.06GHz clock speed 3066.0 MHz FSB speed 133.0 MHz multiplier 23.0x Socket 775 LGA
2 Suggested Answers
jell587
  • 447 Answers
SOURCE: want sound driver for intel celeron[Tm] cpu
Go the ASUS support site and do a model search for TUSI-M, enter the OS you need drivers for and download what you need. The soundcard integrated into that board is a C-Media CMI8738/C3DX just in case you need to find a driver for it elsewhere.
Posted on May 06, 2009
Ello. I wanted to know if there is a BIOS update for the Aspire M1100 because my BIOS dated 23/02/2008 which references are Motherboard SMBios version 2.5 Acer F690GVM Bios: Phoenix Technologies,...
The AHCI can be enabled from using the correct driver but you should have enabled it PRIOR to the OS install
Acer did not always do this but often relied on compatibility mode
The speed increase is often not that much.
The BIOS on that board can be updated but you may find that AHCI still does not work as you expect.
Mar 15, 2011 | Acer Aspire M1100-U1402A Refurbished AMD...
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
Athlon processor upgrade assistance:
Go to this link:
http://us.msi.com/?func=searchresult&keywords=ms-7025
Select the model motherboard you have and click on the CPU support link, it will show you a list of CPU's that are supported. You have a socket 939 board and AMD CPU's are now AM2, AM2+ and AM3 socket, which are 940 pin. It may be difficult to find a new CPU for your motherboard that is new since they have not been made in awhile.
Feb 09, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
AMIBIOS ROM Size: 1024 KB BIOS Build Date: Jul 07 2008 Motherboard Manufacturer Code Detected: 1131 - ELITGROUP Please Consults ELITGROUP for support AMIBIOS Build Tag: 2E3C3S1 AMIBIOS Project ID: 2E3C3S1...
I am guessing that you want a BIOS update for your EliteGroup GF7050VT-M5 Ver 1.0 motherboard, am I right? There is one update, newer than yours: (read the warning about updating [flashing] your BIOS)
If you wanted something else, it is probably there too!
Dec 31, 2009 | Computers & Internet
Hi can any one help me please
Leave it alone. Reflashing a bios is serious business and never, never guaranteed. Very often the process does not work or goes bad and then you wind up with a piece of junk due to a corrupted bios.
Mar 03, 2017 | Abit AV8 Motherboard
No sound output
You'll want to verify that the onboard audio is enabled within the bios first, beyond that the audio codecs for that mobo should be the Realtek AC97 drivers, go to this link to obtain them. You have a choice of two - the AC97 standard codecs or the HD codecs (I would probably try the HD codecs first). I would also be curious as to whether the audio hardware is showing up in the device manager at all (especially if it has the yellow exclamation point next to it).
Based on what you posted about a bios update being the catalyst I would definitely check the onboard audio enabled within the bios option first...
Please post a little more info (especially about what the device manager says) or your results from the reinstall of the AC97 drivers...
May 04, 2009 | Computers & Internet
I need drivers for my cd/dvd drive on my laptop (amilo m1437g) . i have installed vista ultimate.
I need drivers for my sound. The motherboard is as follows:
Asustek cusi-m acpi bios
Revision: 1007
Rom Size 512 kb
Processor: Intel Celeron (tm) Processor
Socket: PGA 370
plus minus 1100 gHz
Release Date: 23-Feb-2001
Feb 02, 2009 | Computers & Internet
Sound card drivers on bord need AMIBIOS Motherboard Manufacturer Identification Version 1.4 (01/12/2004) Copyright 2003 American Megatrends, Inc. This file has recorded information useful in identifying...
look et...According to the numbers you provided you have Elitegroup Computer motherboard. So for any possible BIOS upgrade, drivers or any other technical support you will need to visit => www.ecsusa.com. or call them at 510-226-7333. Suc6 Theo.nl
Jan 07, 2009 | Computers & Internet
I cant find which typ of mainboard do I have to preform an update
There is a little program called CPUz.
Download it here:  http://www.cpuid.com/download/cpuz_149.zip
Extract the exe and ini files and run the exe.
When the program comes up, click the Mainboard tab and your manufacturer and model are right there.
Dec 17, 2008 | Computers & Internet
Motherboard processor support
Processor Family Processor Speed System Bus Frequency Cache Size BIOS Version Notes Pentium® III processor 850 MHz 100 MHz 256 KB P14 or greater The following board revisions (AA numbers) support these processors: 754552-200 or later
754558-200 or later
A01450-200 or later.
See the board revision note, below, for an explanation.
800 MHz 100 MHz 256 KB P14 or greater 750 MHz 100 MHz 256 KB P14 or greater 700 MHz 100 MHz 256 KB P14 or greater 650 MHz 100 MHz 256 KB P14 or greater 600E MHz 100 MHz 256 KB P14 or greater 550E MHz 100 MHz 256 KB P14 or greater 600 MHz 100 MHz 512 KB P12 or greater All board revisions support these processors 550 MHz 100 MHz 512 KB P07 or greater 500 MHz 100 MHz 512 KB P07 or greater 450 MHz 100 MHz 512 KB P07 or greater Pentium® II processor 450 MHz 100 MHz 512 KB P01 or greater 400 MHz 100 MHz 512 KB P01 or greater 350 MHz 100 MHz 512 KB P01 or greater 333 MHz 66 MHz 512 KB P01 or greater 300 MHz 66 MHz 512 KB P01 or greater 266 MHz 66 MHz 512 KB P01 or greater 233 MHz 66 MHz 512 KB P01 or greater Intel® Celeron® processor 433 MHz 66 MHz 128 KB P01 or greater 400 MHz 66 MHz 128 KB P01 or greater 366 MHz 66 MHz 128 KB P01 or greater 333 MHz 66 MHz 128 KB P01 or greater 300A MHz 66 MHz 128 KB P01 or greater 300 MHz 66 MHz 0 KB P01 or greater 266 MHz 66 MHz 0 KB P01 or greateri hope that this solved your request.
Sergio
Mar 13, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
