Question about Samsung SC-DC164 DVD Camcorder
Can not switch on
My cam still off
What's your question?brother dcp115c,machine error51?
Brother DCP115C Code: 50, 51
Description
The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses.
Switching arm assembly not engaged correctly Ink cartridge/purge switch harness not connected correctly Purge cam switch broken Gear(s) on the maintenance unit broken Paper feed motor broken Main PCB defective.
Sep 09, 2016 | Brother DCP 115C All-In-One InkJet Printer
Machine error 50 . dcp-115c
Jul 26, 2014 | Office Equipment & Supplies
How to clear "unable print 51" in Brother MFC 230c printer?
Jul 26, 2014 | Brother MFC-230c Printer
I have a Rowe ami R92 jukebox, when I turn it on I get error 37
Did you ever get an answer to you question on the error 37 for the Rowe R92 Jukebox
Peter
Rowe R-92 Jukebox
Dec 09, 2012 | Audio Players & Recorders
Not making ice cubes
Fill ice maker with tap water and let freeze. If ice dumps and water does not refill tray then the water control valve is defective. If ice remains in ice maker then ice maker is the problem.
I think Amana still uses the Whirlpool made ice maker. It consits of a mold, a paddel to remove the ice, a motor to drive the paddel and a cam. The electrical part consists of mold, thermostate or sensor ( use to be thermo-disc), micro switches, 1 to hold the unit running 2nd to alow water to flow at a certain time and a mold heater. Sequence of operation: Thermostate senses mold is cold, activates motor to turn paddels and cam. As cam turns it depresses a micro switch to hold motor running. Motor cam and paddel turn, mold heater is also turned on. As mold warms the paddels scoup out the ice. Contunes to turn until a spot on the cam activates another micro switch to allow water in. Motor continues, as cam reaches a spot it releases the micro switch for water andthen the switch holding the motor on and unit shuts off ready to do it again.
Sep 09, 2010 | Amana ARB2257C Bottom Freezer Refrigerator
My nav cam 6200 will not switch on
its atechnical problem or might be with the battery try it after changing
Sep 04, 2009 | Evesham Nav-Cam 7700 GPS Receiver
Kenmore Electric Dryer - won't start -Replaced Start Control,won't start but hear Timer ''clicking'' . How do I test timer ?
did you check the household fuses/breakers if yes then the problem is can be the thermal fuse it white in color and is on the blower housing (vent) ohm if you get no reading then replace it as I always tell self repair people to unplug the unit for your safety
Sep 01, 2009 | Kenmore Dryers
I don't know how to get the pictures I took off of my panosonic DMC-LZ2 I have it plugged in but my computer doesn't recognize it..
switch off your digi cam !!!! connect the digi cam via dta cable to the PC !!! now switch on the cam !!! keep your digi cam in display picture mode !!! now u can use your digi cam like a pen drive
Jul 21, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
How do i switch on the web cam?
It is software based. Open the application your are using and the cam should activate.
Jun 03, 2009 | Acer Extensa 500T Notebook
I have vista HP touch screen computer and my webcam does not work please help me fix this problem
hello,
If the webcam is built in to the HP comp then, you have to install the correct driver of the cam, else maybe the cam is switch off try to find any button to switch on your cam.
or verify also if the cam is detected in the system.
melnavz
Nov 27, 2008 | Computers & Internet
Samsung SC-DC164 DVD Camcorder Logo
18 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
