Hi, I have a Fujitsu Siemens C1020. The problem is that it is resarting out of the sudden, even though I had just turned it on, so I don;t think it's a heating problem. I had the windows reinstalled, also i bought a new HDD. before it restarts a blue screen with a message appears, but i can't see what it says because it lasts for less than a second.Can you tell me what could be the problem? Thanks!
SOURCE: Restart
dugiehowsa could be right but it sound to me that another reason might be that the laptop is overheated and the fan is dusty
Posted on Jun 27, 2007
ramesh singh
  • 126 Answers
SOURCE: sound drivers
u can try this if u understand
http://support.fujitsu-siemens.com/Download/ShowDescription.asp?SoftwareGUID=CB518FBD-386C-4266-8730-432160E331E7
or if u have the drivers and utilities cd with u,u can install the drivers from that disk also,or check this out
http://www.helpdrivers.com/ingles/doc/instal.htm
try this out
Go here and enter your details...
http://www.fujitsu-siemens.com/support/linkapplication.html?LNG=EN&ID=263
Try Everest Home Edition (for free but you've got to Google for it)) and then to driverguide.com to pick it up, if the Fujitsu site doesn't help with it.
u need to install this driver for ur audio for the laptop
AC97 Compliant CODEC: Conexant Cx20468 driver:-)
Now try again here and click on c1020...
http://www.fujitsu-siemens.com/support/linkapplication.html?lng=en&id=263
and when u install the driver from griverguide.com follow this
After you installed the latest VIA AC'97 Enhanced Audio Controller driver from Driverguide.com , did you check the Device Manager?
What is seen in + Audio video and games Controllers?
Since you have tried to install other drivers, I am wondering if you could have corrupted the drivers.
If you have got the Right Drivers saved , I would suggest the following:
1. Start the Computer in Safe Mode
2. Open Device Manager> + Sound, video, and game controllers
3.Uninstall everything EXCEPT audio codecs, Legacy Audio Drivers and Video Codecs
4. Close Device Manager
5. Restart the Computer.
6. When the new hardware found message comes direct the wizard to the downloaded driver for installation
the audio controller is audio controller is a VIA VT8233 AC97 Audio Controller. VIA Technology website and download the VT8233 drive and it will definately work...good luck
Posted on Jan 27, 2009
  • 13 Answers
SOURCE: lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Posted on Mar 19, 2009
  • 39 Answers
SOURCE: My Fujitu Lifebook c1020 display is bad and needs swapping. I need a repair maual.
its pretty simple to change the screen on this computer, and you dont really need a service manual (i dont even think you will find one for that)
the way you do it is remove the rubber "dots" around the screen, there should be atleast 4.
when they are out, and you have removed the hidden screws, you can take of the frontbezel around the screen.
when the bezel is off you might need to loosen or remove 1 of the 2 screwes on each side at the bottom hinge.
the screen itself is fastened to the hinge with 2-4 screws on each side of the screen. remove them, take out the flat/wide cable on the backside, and disconnect it from the 5-6cm long printbord.
reverse the process when you put in the new screeen.
Posted on May 29, 2009
  • 206 Answers
SOURCE: Hi, I have a Dell XPS M1210 laptop. I was in the
The problem that you have experienced is that your system shot down while it was in the middle of something, and now, some important system files have been lost. That is the reason why you cannot enter SAFE MODE either. The only solution is to re-install your OS. If you had some important data on it, you can try recovering it using some LIVE OS that doesn't have to be installed
Posted on Nov 17, 2009
Testimonial: "OK, how to re-install my OS? I can't get past the blue screen. And one more question: What is LIVE OS? Thanks. "
Replace the power in socket on lifebook c1020
i took apart a dell and was having the same problem. on mine it turned out to be double sided tape and it pulled right apart. but you should check, check and recheck for screws before you just yank it apart
Apr 28, 2010 | Fujitsu Lifebook C1020 Notebook
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
Keyboard @ and " keys are swapped over--- Regional settings are set to English UK
What regional keyboard settings are you wanting? English US or English UK?
Sep 16, 2009 | Fujitsu Siemens LifeBook C1020 Notebook
My laptop doesn't turn on and the red indicator of the battery
check the power settings and make sure that the battery and power cable settings are on when plugged in. Also sometimes a battery needs to be installed to do this. If the power adapter is working then all should be fine.
Aug 26, 2009 | Fujitsu Siemens LifeBook C1020 Notebook
May 28, 2009 | Fujitsu Lifebook C1020 Notebook
Sound drivers
try this out
Jan 27, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
