Question about Roland Printhead FOR SC-540 / SJ-540 / SJ-640 / SJ-740 / XC-540 1000002201 22805470
I need the printer driver for colorip
I bought a second hand roland printer cutter machine, it came with the computer an older pc. no original softwear, for some reason i have lost the printer driver for the sc540-soljet pro11 print and cutter machine. i am using colorip software. i am pretty ignorant about all of the software. i have spent a lot of money fixing this machine and now cant send designs to printer. can you help.
I am tearing my hair out trying to get any output from any of the software I have (sign cut, corel x5, easy cut, cut studio etc) from my Roland Camm1 cm 24. I can do the test cut from the cutter which...
The problem is more likely the operating system compatibility with old kit.if you are running something like 64bit windows 7 then the best solution is to have a dual operating system and install windows Xp.there may be updated drivers some where internet
wise.or you could try running in compatibility mode.
lpt and comm refer to older machines with serial port and parallel ports.if you do use USB you are better off using the rear ones as opposed to front end as they connect direct to motherboard.
if you have already tried go to the Roland site and see what support downloads can offer for system compatibility.otherwise you may find a forum via search engines with a driver.until then your machine will not communicate properly with you computer setup.also right click the executable for the software in its own folder and see if you can choose compatibility mode .best will be windows 2000 or Xp.
Mar 29, 2015 | Parallel Office Equipment & Supplies
Machine is not responding
Did you get a fix to this problem? I also have the same problem
Jan 03, 2014 | Roland GX-300 CAMM-1 Pro Vinyl Cutter
Can someone tell me how to use my Roland CAMM-1 CM300 Pro vinyl cutter with Windows Vista as it's a pretty old machine and I think will only work with Windows 98
You should Buy a newer Model, Vista will not detect it. That is why Vista was a mistake... I like Linux Computers much better
Sep 25, 2013 | Computers & Internet
How to get out of dpics mode on a roland camm-1 pro gx400
Please help us the error code comes "dpics mode" in roland gx-500
Jul 29, 2012 | Roland GX-400 CAMM-1 Pro Vinyl Cutter
All four colors wont print roland sp300v
you print head is dry out. Normally, it happened on Magenta and Cyan colors.
Apr 09, 2010 | Office Equipment & Supplies
Can I still use the Cutter if it has run out of ink
my pc doesn't accept usb. it always open an dialog box and asked me to search.
Dec 09, 2008 | Office Equipment & Supplies
Colorip machines to run on Versaworks
what rip software can I use on a roland sc-500? jimrothfuss@gmail.com
Nov 16, 2008 | Office Equipment & Supplies
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Roland Printhead FOR SC-540 / SJ-540 / SJ-640 / SJ-740 / XC-540 1000002201 22805470 Logo
Top Roland Office Equipment & Supplies Experts
Chas Peters
Level 1 Expert
Michael Harrier
David Payne
David Payne
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
