Question about HP new HP Pavilion dv7-6187cl Notebook PC gamng laptop Intel i7 dv76187cl
How to fix a compressed boot manager on a hp laptop
2 Suggested Answers
  • 733 Answers
SOURCE: boot manager is compress
Boot Manager is compressed???
here are two solution:
1.
"BOOTMGR is compressed. Press Ctrl+Alt+Del to restart"
Check points for fixing compressed boot-manager:
Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair".
If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files.
If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands:
compact /U C:\bootmgr
compact /U C:\ntldr
If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands:
attrib -c c:\bootmgr
attrib -c c:\ntldr
2.if the above solution did not work for you try this easy way:
reboot, push open the dvd drive, load OS Vista CD/DVD, before the ridiculed bootmgr compressed shows, shutdown, boot from the dvd, let the installer do it’s job.
when reach choice “install now” choose “repair the pc” instead.
In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
click Startup Repair.
Just click “load drives”since you know the answer about “repair”….nothing wrong..)=:
see that??, you’re inside your HD!! I assuming that from here everybody knows what to do, if not, that what follow:
Browse for your “C” Drive, right click properties and fellas, reverse what you did, exit, reboot.
Posted on Feb 07, 2010
I was given an Acer Extensa 4420 shortly there afrter i turned it on and the boot manager was compressed. is there a fix i can do myself for free
Try to boot up into the Recovery Console. If you can get there, go into explorer, right click on the boot drive(it is seperate from your c: drive) and de-select "compress this drive".
If that does not work and you can somehow boot to a command prompt, go there and then type compact /U C:\bootmgr and compact /U C:\ntld
If that does not work, borrow a windows disk from someone you may know and enter the recovery console off of the disk and do the 1 step above.
Sep 25, 2012 | Computers & Internet
It will not reboot the message 'boot manager is compressed' is displayed and will not move past it
  • Boot into Windows Recovery Environment (usually the install DVD or Create a Windows Vista/7 Recovery disk on an USB stick) and perform a "Startup Repair".
  • If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files.
  • If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands:
    • compact /U C:\bootmgr
    • compact /U C:\ntldr
  • If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands:
    • attrib -c c:\bootmgr
    • attrib -c c:\ntldr
May 05, 2011 | Advent 4211c Notebook
I get a bootmgr compressed error when i start my acer netbook its telsl me to hit control alt delete but this only repeats over and over how can i uncompress the bootmgr file so the netbook boots up
Boot Manager is the file controlling the boot security process and is corrupt.
Try and start in safe mode and run CHKDSK/F
If you can't get it to work, use your recovery disc and recover your system.
Feb 05, 2011 | HP Mini 1000 Netbook
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer Aspire 8920-6048 Notebook
Boot manager is compress
1.
compact /U C:\ntldr
attrib -c c:\ntldr
Feb 05, 2010 | HP Mini 1000 Notebook
Toshiba Satellite a135-s4427 Boot Manager Missing
its not the hard drive my frined, its the boot loader it has been deleted or it has been compressed the only way to fix this is to use the recovery cd you have, to boot from cd-rom you need to go into bios which is usualy F2 or F5 key, then under boot manager or somthing is the primary and secondary boot, change the primary to CD-ROM, then save it and restart then it should boot from cd-rom then you have do a start-up recovery.
Jan 22, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Compressed boot manager
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
Aug 28, 2008 | Computers & Internet
Boot manager compressed
You are stupid!!! of course there is another way!!!!
http://answers.yahoo.com/question
/index?qid=20080612115923AAgIovt
Guru my ***!!!!
May 04, 2008 | Computers & Internet
HP new HP Pavilion dv7-6187cl Notebook PC gamng laptop Intel i7 dv76187cl Logo
11 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
