I required the below IC & Transistor for my Technics SU-V5 amp as asked by the technician,where could i get it.(B817,TA7317P,6552).
5 Suggested Answers
ColdTattoo
  • 219 Answers
SOURCE: lost technics su-v300 amp power cable
http://www.mcmcables.com/category/120611000/120600000/Power%20Cables
Check it out.
Please give me a good rating!
Posted on Sep 21, 2009
  • 130 Answers
SOURCE: Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Posted on Dec 05, 2010
AJIN G
  • 6694 Answers
SOURCE: what is technics amplifier su z2 ic number
HI,
The out put ic number of Technics SU Z2 is SVITK2038. If you can sent your email address the i will sent the schematic diagram
OK
Posted on Oct 28, 2011
SOURCE: TECHNICS SU-V50
Goodevening,I<m looking for an current Drive for mt amplifier technics SU-V50.
Posted on May 27, 2013
Good day i have a Technics amplifier SU-X320. Problem is it powers up up there is no sound. Checked all basic fault finding, suspect it is the volume IC.
"Volume IC" do you mean an IC that is a pre-amp and controls the volume and things like tone? Or do you mean the main power amp IC, which will be on the big heat sink?
If you amp uses the latter and not individual separate devices for the power amp, suspect that over the other IC. But if the amp has separate power amps for both channels, replace the IC.
Oct 09, 2013 | Technics Audio Players & Recorders
Technics Amplifier SU-V4
The clicking sound will be a relay for the protection circuit. That could be faulty, but first check out the main devices on the main amp section. Those attached to the big heat sink. If you see a single IC amp that could well be faulty.
Oct 04, 2013 | Audio Players & Recorders
Transistor b817
The device is available to buy for under 1 dollar! Just search Google for 2SB817. By the way it's a 100 watt 12 amp device.
Aug 17, 2013 | Audio Players & Recorders
What is technics amplifier su z2 ic number
HI,
OK
Oct 10, 2011 | Technics SUV500 2-Channel Amplifier
When I turn on my technics SU-V55A amp, the current drive does not engage. If I leave it, it normally comes on after a period of time. The amp then runs ok.
Check for dry solder joints especially on the main power output transistor.
A blown power transistor will stop the 'Current Drive' from engaging so if the problem you have is intermittent then it is most likely dry solder joints.
Hope this helps.
Oct 06, 2011 | Technics SUV500 2-Channel Amplifier
Technics amp SU-X999. I need an output I.C type SVI-4004
NAother option is to fix a universal amplifier kit into the set which powers from the same voltage preferrably a MOSFET drive which are very much available in the market and can be suited into the set. They will alos be very effficient but take care tto do the fixing mechanically , connecct the right power and groung with good shielding. Disconnect the old amp totally and use the power lines that come to the IC. I hope this works for you. Good day
Jul 30, 2010 | Technics Audio Players & Recorders
Technics SU-G95 Amplifier and no sound on left speakers
Usually this is a defect in the output amp IC. If you have no experience with repairs of these types of units, have it checked by a service shop. If the output AMP IChas failed, it will cost about $75 for a replacement. This unit uses an RSN3306P IC .
Dan
Mar 14, 2010 | Technics Audio Players & Recorders
I need a cooling fan for my su g50 where can I get one web site maby
The fan assembly can be purchased from tritronicsinc,com (use the guest account) for $24.31 using part number SYE1128-4
Dan
Jul 11, 2009 | Technics Audio Players & Recorders
Technics SU-V98 No Sound
If I understand your posting correctly, the amp works using the Aux In connectors but not using the VCR1 even when VCR1 is selected correct? If that is the case, there is an internal electronic switching IC (TA9263 I think) that may be defective. This is not a complex repair and can be confirmed easily by any shop that does audio repair. They will trace the incoming signal with an oscilloscope to the IC and see nothing come out when VCR1 is selected. The IC costs less than $10.
Dan
Feb 05, 2009 | Technics SUV500 2-Channel Amplifier
TECHNICS SU-V50
Hi max
I have done a followup with Technics Parts agents in the US, they will get back to me and then me to you shortly :) A vote as FixYa would help improve my ratings. Thanks
Graeme
Feb 06, 2008 | Technics SUV500 2-Channel Amplifier
41 people viewed this question
 Grubhead
Grubhead
