Question about Whirlpool GEW9868K Electric Dryer
Whirlpool dryer ygew9868kl0 replaced the thermal cut off not start but brinking
kachbibi1
  • 979 Answers
SOURCE: electric dryer wont start
Just replace the thermal fuse for now. You have gotten good use from this machine. But, this is also may be the beginning of the end. Thermal fuses are not expensive either. These things just go out at no uncertain times.
Posted on Feb 03, 2009
  • 1122 Answers
SOURCE: location of thermal fuse on leq9858 l dryer whirlpool
if this is a top load?if so remove the back panel and you will see the dryer heater box to your right,the fuse is on the left side of box top,the high temp thermostat is on the bootm left and should be replaced also,before you do thatmif you have a meter remove the 2 wires from the heating element and check it on omns,no meter?remove the 2 screws pull the element off and look to see if the coil is broke anywhere,let me know how you do-mkie
Posted on Apr 20, 2009
protek480
  • 1714 Answers
SOURCE: whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Posted on Jul 12, 2009
mgprice
  • 744 Answers
SOURCE: I have a Whirlpool LGB6000KQ1 Gas Dryer. It
Hello, Unfortunatly your wrong on all 3 counts sorry :) This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safty valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Posted on Sep 09, 2009
Testimonial: "This was the exact problem. My dryer works perfect. It was a $40.00 fix!"
hiltonjug
  • 612 Answers
SOURCE: LER4634EQ2 whirlpool electric dryer. heating
I know this might sound stupid but try this. Find your fuse box, locate the breaker that runs your dryer. Flip it off and then back on. If i'm correct, it will work. Everything on your dryer works off of one leg of the 220v. The other leg goes to the other side of the element. If you have a meter. check for 220v at the plug. Everything you listed is what makes the dryer heat other than the thermostats. Check the cycling thermostats like you did the other pieces. They look like the thermal cut off. They have two wires and they are round.
Posted on Oct 10, 2009
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
Dryer still runs it just isn't getting warm
The heating element is wired in series with a thermal cut-off and a high-limit thermostat both located on the heater housing.The thermal cut-off blows open when the high-limit thermostat fails to cycle off in order to regulate the heating element temperature. When the thermal cut-off is blown, power to the element is cut-off and the dryer will not heat. Replacing both thermal cut-off and the high-limit thermostat if the former is indeed blown. Click on the links below for the troubleshooting and repair details.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Front Bottom Panel) Running But Not Heating
Jun 18, 2011 | Whirlpool Dryers
Cabrio electic dryer has power but will not run
There is a thermal fuse wired in series with the motor and if it is blown, power to the motor is cut and cannot. No dryer function works when the motor cannot run. The thermal fuse usually blows due to a failed exhaust thermistor. Check for clogged lint filter and/or restricted vent system then replace both the thermal fuse and the thermistor if the thermal fuse is found blown open. This is a DIY repair which only requires very minimal effort with a screwdriver.
Disconnect power then remove the back panel and locate the thermal fuse and the thermal fuse on the blower housing.
Click on the link below for some troubleshooting information before replacing the thermal fuse and the thermistor.
Kenmore and Whirlpool Dryers Not Starting
Jun 17, 2011 | Whirlpool WED7300XW Dryer
My whirlpool leb 6000 pqo will not heat
check heating coils, high limit, temp selector switch.
Apr 05, 2011 | Whirlpool Dryers
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
No a kenmore 80 series dryer will not heat . if the heating elment is good & fuse is good what else could be the problem
The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The problem is very likely in the thermal cut-off and the high-limit thermostat located on the blower housing. The thermal cut-off blows when the high-limit thermostat fails and cuts power to the heating element. Both the thermal cut-off and the high-limit thermostat need to be replaced if the former is blown open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Mar 09, 2011 | Kenmore Elite HE3 Steam 8676 Dryer
LER4634EQO Whirlpool Heavy Duty Extra Large Capacity 4 cycle 3 temptures My dryer is not heating. I have checked the breaker(s). There is not much lint around the dryer in the back or the vent, what...
The problem is likely in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
The
thermal cut-off (cut-out) and high-limit thermostat are sold as a kit with part number 279816 and costs about $30.
In case the dryer still doesn't heat up with the
thermal cut-off (cut-out) and high-limit thermostat bypassed, bypass the cycling thermostat then replace it if the dryer heats up. Check the heating element for broken coils if the dryer still doesn't heat up with the three components mentioned above bypassed.
Feb 10, 2011 | Whirlpool LER4634J Electric Dryer
LER 5620KQO won't start. Any ideas?
I would think that you either have a bad thermal fuse, Thermal cut off or bad door switch. Most likely a bad thermal cut off.
Nov 17, 2009 | Whirlpool LER5636P Electric Dryer
Overheated , now fixed but have no powe
You may hae a non-resettable thermal fuse that opened.. when that happens.. system won't operate..
Sep 03, 2008 | Whirlpool LEB6300 Electric Dryer
Whirlpool GEW9868K Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
