Question about Olympus TOUGH TG-310 Digital Camera
Corroded battery terminal - Olympus TOUGH TG-310 Digital Camera
    Top Expert:
  • Olympus Master
  • 6,702 Answers
The best thing to do, is remove the old terminal and replace it with a new one. The corrosion, will go on, even after you think you removed it complete. But you should have the shills of a repair engineer. Second best thing, is to remove the corrosion as best as you can, and put aa little contact oil on the contacts. Make sure every time you recharge the battery, you check for corrosion and try to remove it.
Remove with a dry cloth, or if you have contact oil (for electronic purposes) us a little oil, but make sure the oil is removed after you removed the corrosion.
Posted on Feb 13, 2014
Try to start and it clicks
Low battery power = Charge battery.
Dirty or corroded contact at terminals = Clean and tighten all terminals.
Bad contacts in starter solenoid = Clean contacts or replace solenoid.
Battery to starter, cable corroded or damaged = Replace cable.
May 27, 2015 | Cars & Trucks
Ford tuarus has no power. Nothing turns on including ignition. Could it be bad or corroded battery cable?
Yes it can be; or it could be that the battery is dead (or bad).
Disconnect the cables, clean the battery terminals, clean the inside of the cable ends. Connect a battery charger, let it charge for at least an hour (don't just use jumper cables from another car). Once charged try it. If you still get nothing, it could be that the battery is shot. In that case, replace it.
Jul 31, 2014 | Cars & Trucks
I am trying to replace the battery for a '97 Suzuki Sidekick. The battery terminals were so corroded, I had to cut the wire and put on some universal terminals. There are two wires for each terminal-
This happens in the shop all the time. It is not necessary to remove the alarm if you have the remote for the alarm. Simply hook the battery up and press the button to turn the alarm off.
Nov 23, 2011 | 1997 Suzuki Sidekick
1982 pontiac firebird wont turn over, push on clutch turn key only one click.
This is a sign of inadequate power to the starter. This can be from a tired battery or corroded cable terminals at the battery, the input terminal of the starter or a corroded connection between the negative battery terminal or chassis to engine.
Mar 24, 2011 | 1983 Pontiac Firebird
I can't get the positive battery terminal cable off of the old battery because it is too corroded. So, I would like to replace both terminal cables and the battery. The problem is there is a wiring harness...
Best would be to wet the battery terminals with water, take a sponge and place it on the battery terminals which are corroded and pour water to it, let it stay a while and again pour some water to the sponge, you will note tht the corrosion will start to fade away and thus you will be able to remove the battery terminals kinda easily!.
Hope this helps!
Nov 30, 2009 | 1996 Oldsmobile Cutlass Ciera
Alarm says terminals corroded
One of two things:
Somewhere in the wiring you have a weak connection and it is interpreting it as a bad battery or corroded terminals. It could even be where the cord goes into the sump pump. You will have to search it completely to find it.
The alarm itself is bad.
May 25, 2009 | Ace Hardware Ace& Battery Back-Up Sump...
Internal battery terminal corroded and fell off
Old batteries leak and the battery terminals corrode. Replace the terminals and clean the area thoroughly.
Jul 27, 2017 | Canon Optics
Olympus TOUGH TG-310 Digital Camera Logo
54 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
