Question about Ricoh Aficio AP400N Laser Printer
Ap400n reset sc456
Aficio AP400N. How can I select service mode?
There are two ways to enter the service
mode.
Method 1: Turn the machine on while
pressing the "On Line" key and "Escape"
key together until "1. Service Menu1"
appears on the display.
NOTE: If you switch the machine off, any
jobs stored on the hard disk using
the sample print and protected print
features will be deleted.
Check first with the user tools to
see if there are any jobs stored with
these features
(Menu key - Sample Print, or
Protected Print).
Method 2: Press the "Up/Down arrow" keys
together for about 5 seconds, then press
the "Enter" key.
"1. Service Menu1" appears on the display.
Mar 29, 2016 | Ricoh Office Equipment & Supplies
I BOUGHT A USED RICOH AFICIO COLOR 3006 COPIER FROM THE UNIVERSITY OF GEORGIA YESTERDAY. WHEN I TURN THE COPIER ON, I GET AN ERROR CODE SC456. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hi there
The error code 456 - Paper transfer unit position error.
If you cannot find any jammed paper in the unit, you may need a Ricoh service guy to give it just that. A good service
regards
Graeme
Mar 22, 2008 | Computers & Internet
Ricoh AP400N Error Code SC542
You may want to try the following:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arrow to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on
I hope this helps.
Best of luck!!
Mar 02, 2011 | Computers & Internet
Hello, We have a Ricoh Aficio AP410N Laser printer. It stoped working and gives the error code SC514. Resetting it didn't help. Could you please advise? Many thanks
There is no SC514 on an AP410N. Do you mean SC541? SC541 is a fuser code that a technician has to reset. It could be something as simple as a power spike, or it could be a dirty sensor or a blown board.
Jun 01, 2010 | Ricoh Aficio AP400N Laser Printer
Sc546 error
Fusing thermistor defective
The ROD was engulfed with powder not allowing to rotate. When removed everything was normal- SC546
Jan 07, 2010 | Ricoh Aficio AP400N Laser Printer
Ricoh ap 400n keeps blowing fuse
This is more than likely a statement of the electrical supply to the printer.
Laser printer's typically require a high in rush amperage to keep the fuser lamp and fuser warm. You can see the effect of this by looking at the lights in the room. If the lights dim about every four seconds its because the printer is pulling a higher amperage from your electrical system.
Normally, laser printers are "Strongly Suggested" to be on a dedicated 20 amp line. If you are using them on a normal 15 amp line that is also supplying other receptacles and devices, when the fuser demand peaks it may be enough to trip the circuit.
Now, there are a couple of ways to fix this. One is to upgrade the entire circuit to 20 amp. That include a 20 amp breaker, 12 AWG wire and a 20 amp receptacle.
If you cannot do this, then switching either the fuse or the breaker or a "Slow Blow" may help you. This type of fuse or breaker will add a delay into the "trip" part of the circuit.
Don
Dec 01, 2009 | Ricoh Aficio AP400N Laser Printer
Ricoh Aficio AP400N Laser Printer Sc 545 off on error
SC 545
A Fusing lamp stays on
The fusing lamp stays on more than
12 seconds after the main motor has
been turned off.
• Fusing thermistor defective
• Power supply board defective
• Defective connection of the fusing
This will not reset by turning of/on must enter sp modes to clear this error.
Due to possibility of fire hazard would be best to have tech look at it
Oct 09, 2009 | Ricoh Aficio AP400N Laser Printer
Ricoh printer printing error: undefined offending command: mz
it is a logic card problem. so pls checked it from service center.
Aug 25, 2009 | Office Equipment & Supplies
RICOH AFICIO AP400N - HOW DO YOU REFILL THE CARTRIDGE
this is a all in one unit. and available as supply,
Sep 30, 2008 | Ricoh Aficio AP400N Laser Printer
Ricoh Aficio AP400N Laser Printer Logo
35 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
