PrintCopy .infohttps://printcopy.info > code=SC390
Code: SC390; Description: TD sensor error 1. The TD sensor outputs less than 0.5V, 20 s after the TD sensor initial setting has been performed.
Missing: cod ‎' Must include: cod
Fixyahttps://www.fixya.com > ... > Ricoh
The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that ...
Copytechnethttps://www.copytechnet.com > 56632-sc-390-a
Sep 24, 2011 - I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed ...
Question edited to add the word Nintendo, because not everyone is a mind reader.
Question moved from Computers, to Nintendo now we know what a '3ds' is. Also fixed to '3DS'.
Switch off
Open Toner Cover
Switch on, holding "System Menu"
Go to "Secure Setting"
"Enter"
Hold "Start" "#" "Enter"
Scoll down to "Maintenance Mode"
"Enter"
Scoll down to "U163"
Scoll do "Execute"
"Enter"
Close Toner Cover
Leave run for a few seconds
Switch off
Switch on....
USE ONE OF THIS 1130-1580-1854-0764-5567-9967 or
1130-1562-7968-0324-7878-1383 or
1130-1684-5908-1910-0406-7468 or 1130-1866-7730-4861-6160-1013
DON'T FORGET TO RATE
Try to access the .jad directly by browsing to http://tether.com/t/tether.jad
I've found third-party sites hosting applications causing this error to occur on my 7100i
Is this COD??
If so back up your gamesaves from COD to a meme stick.
Then put COD in and see what happens.
If it works then the game save was corrupt.
And yes you will have to start again.
