Question about Sansui HDLCD-4212 LCD TV
Channels not showing
When i search for channels that are not showing.my tv is sometimes hot
Would ya know if this 2006 Oct. Memorex TV mod.# mt2024 is digital or not
If no one answers on that model TV (so many models), see following: All the digital TV's have a "search channels" function from a menu button either on remote or on front of TV. See if menu has something like "Setup" and "Auto Tuning" (or words like that) which indicates a digital TV, if no channel search likely analog TV. Once clicking to search for channels (arrow buttons to get there and enter button to start, or some other buttons I saw once did that), it scans the airwaves starting with Ch2 and ending with ch 78 or so. Takes about 30 seconds for it to find channels with antenna connected. Antenna can be old UHF antenna. Search completed, the TV can show the channels in normal channel viewing. If not a digital TV, you can get a DTV converter box to get free tv off the air, it is basically a digital TV tuner that works on analog TV's. You can get those on Ebay.
Apr 17, 2016 | Memorex Televison & Video
My Tv no longer registers a signal from the antenna. I can see a picture thruogh my smart DVR and Chromecast but no pic with TV antenna. I bought a new antenna, still no signal.
Is the TV set to air or cable? It has to be set to air/antenna and a channel search has to be done first before a picture will show.
Mar 07, 2016 | Zenith Z50P3 50 in. Plasma TV
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
How do I get channels
ok,if you have a subscription to cable,you will have a cable box,you will only need to put your tv on cable and ch 3 or 4 on your tv,you dont need to search for channels,if you dont have a subscription,then you are trying to pick up over the air channels,they are called digital channels,you will need a digital tv antenna and your hdtv,you will change the settings on your tv to air or antenna,then you can search for digital channels,there are no more analog channels like we had when we are kids,they are all digital and dont need to be tuned in,if you still cant get channels please have someone help you.
May 19, 2015 | Polaroid TDAC-02212 22 in. LCD HDTV/DVD...
When I turn the tv on (vega fd trinitron) the scren is all snow. There is no signal.
Hello
Have you tested it with auto tuning progremme process. If it snow there, your TV may be working properly. Sometimes its signal input path is not Ok. Without any signal, all TVs may show either snow, or a plane blue raster if its blue back function is on. You just do the automatic tuning process once again after connecting it with an external or internal antenna. There is a socket provided there in the back side of your TV, and marked as VHF/UHF. Connect the signal source to it first.
And set your TV to autotune by slecting it from the menu of your TV. The TV will search for all the channels available at that time, and after searching is completed, it will stop and show the first channel received. Afterwards you can chage or delete or skip unwanted channels. You may have its manual with you. All the descriptions are there in that manual. Ok.
Oct 30, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Only shows channels 3-23 and then only shows a few hd channels
Are you using a Cable Card? Have you tried the Channel search function in the user menu. Select Channel set up and do a channel search.
Apr 12, 2010 | Samsung HP-P4271 42 in. HD-Ready Plasma...
I cannot get the tv to go to channel 3
i'm assuming that it works fine for other channels...most TV's have a "program" feature. This will search through your channels and see which ones are actually broadcasting so that when you flip through the channels you only get ones that actually have something on it. I would try to re-program your TV...
sometimes there's a program button on the remote. sometimes you can find the option in the menu screen.
Hope this helps,
Thomas
Feb 28, 2010 | JVC Televison & Video
New ariel installed on communal roof, have tried auto store, some channels now missing, samsung 23" LCD TV LE23R8
 you must run "auto program search"/"auto store" again and let the TV find the programs. then put them in order and store.
If you feel some channels are missing, try to find them manually. The auto store function sometimes skips programmes with less tolerant range, even if they are watchable in a fairly good quality. And search slowly and pay attention and go back if you feel you just skipped something. Good luck and lots of patience!
A new aerial sometimes might mean loss of some channels.
I hope it was helpful
Apr 17, 2009 | Samsung Televison & Video
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Sansui HDLCD-4212 LCD TV Logo
16 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
