Question about Klip Xtreme KWC101 VGA Webcam
My kwc-101 installation cd is not working - Klip Xtreme KWC101 VGA Webcam
Installed a new KWC Domo faucet and its leaking (alot) under the sink
Does if have a sprayer and is it still hooked up?
Aug 14, 2014 | Plumbing
New kwc domo leaking under (alot) sink
mixing chamber of the faucet may be cracked
Remove flow restrictor on KWC Faucet
We have a KWC 10.501.012.000 - Systema kitchen faucet and after installation the water pressure was much lower, even after adjusting the faucet's limiter screw to "minimum". We ultimately decided that the reduced flow was unusable and called back the plumber service. They sent out a different guy this time and he knew where to find and how to remove another of the faucet's built-in limiters (it has three, apparently).
I saved the removed water limiter parts. I hope this picture of them can you or anyone else with this same problem remove the limiter and get strong flowing water again...
Jul 02, 2012 | Dmm Plumbing
No detection, no sound
101 % Working first you have to download
1. Universal audio architecture which will enable your motherboard to detect audio driver it can be downloaded from here.
2.Then you have to install the audio driver which came with your motherboard CD . Works 100 percent.
101% Guaranteed
Jan 30, 2011 | Computers & Internet
I just replaced the cartridge in my KWC faucet and now it's very hard to raise and lower the on off handle. Any advice?
It is possible that you installed a bad valve cartridge, it would not be the first one. It is also possible to over tighten the cartridge retaining nut, rare, but it can happen. In either situation you need to call KWC and ask them to send you a new cartridge asap. They are usually very easy to work with. If you need further assistance please let us know.
Sep 16, 2010 | Grohe Plumbing
KWC Domo faucet sprayer won't switch between spray and stream
Having installed and fixed kwc domo faucets for years I'd probably take the spray head off of the hose, then look into the bottom of the spray head and see if the check valve is still there. It probably is. I used to use a thin screwdriver to pry the check valve out out.It will come out. You need to work at it a bit but these hold back a lot of water pressure and catch any crud coming down the water lines.
TL
Mar 17, 2010 | Plumbing
KWC FAUCET
http://www.kwcamerica.com/wheretobuy.php
Here is the info you requested.
Apr 10, 2009 | Plumbing
Kwc kitchen soap dispenser wont work
Sorry but you need new one, the cheapest I have found is KWC America 504 938 000 Primo Lotion Soap Dispenser on amazon. I hope this was helpful, cheers
Feb 16, 2009 | Delta RP1001-BL Classic Kitchen...
Klip Xtreme KWC101 VGA Webcam Logo
27 people viewed this question
Top Klip Xtreme Computers & Internet Experts
David Payne
David Payne
Are you a Klip Xtreme Computer and Internet Expert? Answer questions, earn points and help others
