Question about Onkyo TX-SR606 Receiver
Error XXVCC connects to Magnavox Blu-ray playing movie error clicks on an movie goes blank for a few seconds and comes on again repeating several times
5 Suggested Answers
  • 151 Answers
SOURCE: Sound skipping while playing Blu Ray
HI, make sure the audio out put on the ps3 is set to hdmi and set to stream dolby digital,aac, dts, etc,then set audio input on your 696 to hdmi,also check that audio out for hdmi is set to off in the hardware menu on your amp,if you still have problems use the optical out on the ps3 as the ps3 does not out put hd master audio or dolby true hd only pcm, you will still get dolby digital.
hope this helps.
CABLE GUY.
Posted on Feb 08, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I cannot get video signal from my Samsung p1590
I think this one is for the Onkyo wizards:
I would write them via email here:
http://www.onkyousa.com/feedback_form.cfm
1-800-229-1687
However I did find this 2 page hookup manual with nice notes at link listed below that may help you solve the mystery:
(seems you may have to assign the digital input)
http://filedepot.onkyousa.com/Files/QuickHookup/TX-SR606_QSS_En_A.pdf?CFID=918117&CFTOKEN=40624545&jsessionid=f0306ea8a0d68bb60a49102e3e5510576756
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Thanks for using FixYa!
Kelly
Posted on Feb 19, 2010
domotek
  • 591 Answers
SOURCE: receiver turns off at volume
It is picking up DISTORTION and is going in to shutdown mode.... (protecting your system) play it at 44 or less... not because it's BLEURAY that it's perfect, the level and quality varies from one recording to another... think of a cuttoff just like a car engine when someone tries to go over the dangerous level of RPM's... the engine cutt's off...
Posted on Aug 06, 2011
dduncan774
  • 760 Answers
SOURCE: black and white picture from blu ray player
Run the Blue Ray straight to the TV and see if the picture is still in black and white. If it is you know that your reciever is fine and the problem lies in the player or the TV. If the picture is normal then you probably have a bad HDMI IC that will need to be replaced.
Posted on May 10, 2012
Why doesn't my recorded dvd-r movies play on my magnavox dvd player
Does your DVD player support that version of DVD disk? Not all players will handle DVD-R. Check the manual for compatibility.
Try recording to DVD+R then see if your player will play it.
Also, in what format (.avi, .flv, .mov, etc.) was the item recorded and is your player able to handle that format? Again, check the manual for compatibility.
Jan 20, 2015 | Funai FDRV90E DVD Recorder/VCR
Sony bdp-bx57 signal cuts out
test the connection see the diagram attached. Clean the contacts and connector with contacts cleaner.180f246a-cc1f-493b-9d8e-3abff472975f.jpega07d2d96-4cdd-4858-8bc3-356bb92dae0b.gif
However you can restore in the menu to factory default.and see what happen.
Jul 13, 2013 | Sony BDP-BX57 Blu-Ray Player
Do I need a remote control to control the Philips magnavox model DVD 815AT. It plays the commercials on the video disc. When it comes to playing the movie, it keeps repeating itself and it won't go...
Usually most DVD's play movie trailers and sometimes advertisement before the movie will play. Once the ads or trailers are done it should go to the menu screen and at that point "play" or something like that should be underlined. If it is you can press play or select on the DVD player then the movie should start : )
Jul 27, 2011 | Philips DVD815AT DVD Player
I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder. Model# ZV427MG9 A. When recording from a VHS home movie tape to DVD there is a high pitch squealing sound. When playing the DVD...
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
Mar 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Sony Blu Ray S350 plays well but have intermittent loss of video signal. Screen shows coloured background (yellow or white), audio continues to play then screen goes black then picture returns; this cycle...
It may be a problem in the digital section of the TV. If you find a part of the movie that blanks out, try rewinding back to it and see if it goes out again. It may also be the HDMI cable you are using. The blank out is often the result of the TV trying to adjust to the correct resolution for the program being played, and we need to diagnose why it is changing resolutions. Microwave interference and voltage fluctuations can also cause these issues.
Feb 25, 2011 | Sony BDP-S350 Blu-Ray Player
Magnavox NB500MG9 BluRay Player
A Blu-ray player can play DVD or CD and still not play Blu-ray. It may play Blu-ray but not CD or DVD, or burned discs. This is all caused by the 'optical' a part that reads the disc in the machine. Your player will need service as a Blu-ray optic cannot just be 'dropped' into a player.
Mar 28, 2010 | Magnavox NB500MG9 BluRay Player
My ps3 turns on and off ok, plays movies off the hard drive and will play ps3 games but has suddenly stopped playing movies ( dvd & blu ray ) it recognises the disc and goes to play it but the screen...
That is actually a poor conclusion. There are three different lasers, one for blu-ray, one DVD and one for CD games all in one holder inside. It certainly CAN be the laser. The description id the DVD/Blu-ray part is having focus problems. Contact Sony for a service center that can install a new drive (It needs to be calibrated on install)
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
Magnavox portable dvd mdp1810a - no picture
I have this player. It's sensitive to power fluctuations. If the power isn't steady, the picture goes out. You don't need to shut the lid, just quickly press the tiny plastic pin near the hinge under the screen. It does the same thing as closing and opening the lid would do. Not sure this will solve it, but I found that to help. By the way, I broke the car charger for mine and am looking to buy one. If you ditch your player, let me know.
Feb 19, 2010 | Philips Televison & Video
80GB PS3 displays Snow/White screen during playback
Did you ever figure out how to fix this. We simply took our system and hooked it up to a different tv and it stopped. I personally think the problem is with the HDMI cable and wether the cable and the socket are connecting.
Aug 29, 2009 | Sony Playstation 3 (PS3) Console
Onkyo TX-SR606 Receiver Logo
24 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
