Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
My Maxtor basics 500 GB says file H is not accesible. The file or directory is corrupt or unreadable
SOURCE: I:\ is not accessible the file or dir.is corrupted and unreadable
Hi and thanks for writing back. I found that since the drive turned to a raw that windows will not read it.I don't know why it turned from ntfs to raw but it did. so I downloaded the O&O file recovery trial ver.to see if I could recover the pics. and movies.It took 5 hrs. to run and it recoverd everything.now I have to buy the software. but I know it is still all there.this software will even recover reformatted drives.Anybody that gets the same error mess. look to see if your file system has changed.If so it looks like recovery software is the only way to go.I have other good info on this and other maxtor hdd I will check back on post and write if you have sim.probs.
Posted on Jul 01, 2008
SOURCE: power supply for Maxtoe Basics External Hard Drive 500GB
Is 12VDC 2,0A the inner pin is + and the outer pin is -
Posted on Dec 04, 2008
  • 14 Answers
SOURCE: Maxtor won't allow me to delete files that are no longer on my XP
You might not be able to see the hidden files... If this is the case you can enable XP in order to view them as follows.....
Windows XP and Windows 2003
To enable the viewing of Hidden files follow these steps:
  1. Close all programs so that you are at your desktop.
  2. Double-click on the My Computer icon.
  3. Select the Tools menu and click Folder Options.
  4. After the new window appears select the View tab.
  5. Put a checkmark in the checkbox labeled Display the contents of system folders.
  6. Under the Hidden files and folders section select the radio button labeled Show hidden files and folders.
  7. Remove the checkmark from the checkbox labeled Hide file extensions for known file types.
  8. Remove the checkmark from the checkbox labeled Hide protected operating system files.
  9. Press the Apply button and then the OK button and shutdown My Computer.
  10. Now your computer is configured to show all hidden files.
Posted on Jan 08, 2009
Geekinator
  • 183 Answers
SOURCE: my onetouch mini 4 maxtor is corrupted what shall i do to fix it?
Hello there architect_ce. Let's see if we can get you just the right GEEK-steer you need.
"...it says its unreadable..." I presume by this you mean:
1. It mounts and shows up in your "My Computer" and/or "Disk Management" console [Start > Run > type "diskmgmt.msc" (without quotes), then hit Enter].
2. When you attempt to open the drive (by clicking on it) you then receive that "unreadable" error message (probably something like "drive is not accessible. The file or directory is corrupted and unreadable.")?
Is this your situation? If so, you need to recover all one-of-a-kind, doesn't-exist-anywhere-else, need-to-have, can't-afford-to-lose data off that failed drive by copying it to another known-good drive (or network share if available). But of-course you probably already know that. With that said, you have four courses of action to (hopefully) get this accomplished. Progressively do the following until you get some joy:
NOTE: Self-swear yourself to the opening passage of the Physician's Hippocratic oath ... "Above all, do no (more) harm". By this I mean, don't bump or jar the drive. Treat it as if it were a delicate piece of crystal.
1. Perform a "Check Disk" (aka scandisk) on the problem drive.
  • Open "Command Prompt"
  • Type "chkdsk DRIVE_LETTER: /F /X" (without the quotes), then hit Enter.
    Where DRIVE_LETTER = the letter assigned to the problem drive. EXAMPLE: chkdsk G: /F /X
2. No joy? Try this peculiar, yet surprisingly often successful, home remedy:
  • Place your failed drive into an air-tight sealed zip-lock bag.
  • Place it into your freezer. Yes, I said freezer. The longer the better, but leave it there for at least 24 hours.
  • Afterward, take it out and immediately connect it to your system, boot-up, then attempt to access the drive and begin copying over your data from it to another drive (starting with the most important items progressively down to the least important).
  • Return to freezer if/when successful copying begins to diminish due to the drive warming up.
3. Still no joy? Next is the more traditional software approach:
Get yourself a solid performing data recovery software application designed to do just this task. There are MANY to choose from. I've used SpinRite with moderate success in the past. However, since you probably do not have a software currently, I would recommend relying on the latest performance comparisons and choosing one based on that. After all, anecdotal opinions (even my own) do not supersede competent, well conducted evaluations of the LATEST/CURRENT versions of a software. Refer to http://data-recovery-software-review.toptenreviews.com/.
4. Still no joy? The only potential remedy left is paying for the expert services of a data recovery professional.
  • Google "certified data recovery".
  • Here also, there are many to choose from, with prices typically ranging from modestly expensive to are-you-kidding ridiculous. Only you can carefully weigh the value of your data against the quoted cost.
  • However, if you do decide to go this route, make sure whomever you turn over your drive to is a Certified Data Recovery Professional (CDRP) http://www.iacertification.org/cdrp_certified_certified_data_recovery_professional.html. There's no shortage of slip-shod, think-they-are, wanna-be's in this area of expertise who will after their failed attempt, leave you with a then absolutely unrecoverable drive.
You said the problem drive contains "...all of my back up and impt files...". Does this mean that at least some of the data contained on it are indeed backups, and therefore the originals are on another (source) drive? If so, don't redundantly spin-your-wheels recovering files you don't need to. Especially during the freezer method, as time is of the essence recovering what you can, as fast as you can, before the drive warms up.
Lastly, but no less important: Please, please, please let this be the last lesson you'll need for the rest of your life about the vital importance of backing up ALL essential data. By backing up, I mean it must simultaneously reside in at least two separate drive locations. Placing originals on your backup designated device does not mean it's backed up simply because it's your backup device. A word to the wise is sufficient. But don't beat yourself up too bad. Virtually everyone has to go through this at least once in order see the light. Hell, there are many who never heed the painful lesson. If you learn it the first time, believe me, you're doing better than most.
GOD-speed and good luck. Please let me know of you have any further questions, and/or just to let me know how things worked out.
"Today's the best day of my life...and NOW you're part of it!"
Posted on Mar 24, 2009
halbrook
  • 560 Answers
SOURCE: I need to replace the power adaptor for a Maxtor
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Posted on Apr 27, 2009
Cannot copy 22168504[1]: The file or directory is corrupted or unreadable
Try this quick step:
1. On your windows desktop. Open My Computer. On the drive where you encounter an error right click into it. example the dive C is the source of files to be copied.
2. Click Properties and this window appear on popup and click Tools
3. Click Error Checking and this popup appear, check the two checkbox shown and click OK
4. This dialogue box appear, then click OK, restart your PC and let the scandisk check your PC until it will continue loading to windows. Try copying again your file after checking if it works....
I am happy to assist you. Hope I help on hold problem...
Oct 24, 2009 | Maxtor DiamondMax 6L160P0 160 GB Hard...
Problem in external hard disk
Type this command in command prompt " chkdsk /r " in specfic disk prompt (eg) f:\> chkdsk /r
Oct 05, 2009 | Western Digital My Book Essential Edition...
About my seagate 160 gb hard drive (external)
i hav usb seagate 160 gb hard disk.nw it is nt getting open message is the file or directory is corrupted or unreadable........CHKDSK is also not working for it.error is "unable to determine volume version and start"....plz help fast
Jul 26, 2008 | Seagate 160GB 3.5" External USB Drive 160...
External hard disk unreadable
Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
External Hard drive Failure
Seems to me like your MFT of FAT is corrupt. You can go ahead and do a format on it by right clicking and going to format. You should then be able to copy your backed-up files back onto the drive.
Nov 12, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
"Drive not accessible. The file or directory is corrupted and unreadable"
Check similar threads...But basically if you're HD is intact use Testdisk 6.8....Read the documentation first otherwise you may make it worse....Yes it can still be worse ! Try explaining the symptoms in detail like what error message you're getting etc...The more you detail the better we can help you...
Nov 12, 2007 | Western Digital My Book Essential Edition...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
23 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
