Question about Fisher and Paykel Washing Machines
F&P gw612 error 368
Error occurs after rinse cycle ooxooxox lights, suspect lid not locking?
  • 28 Answers
If the x represents light on then that fault code indicates pump fault.It's blocked or over heating
Posted on Mar 07, 2014
stephanos18
  • 144 Answers
SOURCE: Fisher & Paykel GW612 beeps before spin.
You have fault code 66 (01000010) Phase 6- Pressure Transducer (Ptx) Error - Frequency >90kHZ. In simple terms you need to replace the main "Motor Control Module" Cheers
Posted on Mar 24, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
SOURCE: Maytag washing machine skips rinse cycle
Don't know how to solve it, but I do know that the Solution #1 is WRONG.
I have a 5 year warranty on my washer, but I hate people coming into my house. Background check or not, people are people.
Any ways, when they do fix my problem I will let you know. It's an electrical problem.
I know our electric meters are running, but all you have to do is put the washer on "SPIN" cycle, and it will spin and the water will come out. Or you can put your washer in RINSE cycle, since it did not actually rinse.
I was standing and I watched my washer fill 3/4 full with water, and the skip to "COMPLETE" all on it's own. It was suppose to fill all the way to FULL.
Thinking though, I have well water, and I have rust in my water, and I noticed that my water is pouring slower into the washer, maybe there is a clog with rust or something I'll have to clean the filter, but any ways, maybe the washers have a timer, and when it's to the time it should be complete, it skips to complete. It does take DOUBLE time for my water to go into the washer. I was standing there for several minutes.
Any ways, I hope that will help. My washer first did that a few months ago, it didn't do it again, I didn't think anything of it, then it did it again last month, and about every 2 or 3 washes, it does it. It's NOT the weight of my clothes! I wash mini loads and it does it.
Posted on Dec 13, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have just put new
I do not have the exactamundo but here is an GWlo3 Repair Manual with photos F&P Fileshare
Bonus
Posted on Dec 30, 2009
SOURCE: door is locked code F21 wont run or cycle or empty water
Try hitting the stop button twice - we are having the same problem but ours isn't draining
Posted on Jan 13, 2010
Hi, My Fisher & Paykel GW612 washing machine is not spinning, just thumping back & forward, error code 40 on the lights tells Me to carry out a clutch disassembly procedure any help please !!!
Inner spin bowl rises up when water level is high & disengages a clutch gear. When water drains out bowl settles back down and gear engages. Error 40 is saying that the gear has not locked in place and engaged. Remove lid, take out agitator. Under agitator is a cap held in place with 4 screws. Take out screws (do not drop them down through the slots in the bowl) Take off cap & gear underneath will slide up & off the shaft (gear will be tight to pull up due to soap build up.) Inspect gear for damage & clean out any dirt or obstruction. Re assemble and try wash cycle. If you still get the same fault you may have a faulty control board.
Jul 07, 2017 | Fisher and Paykel Washing Machines
LID WON'T LOCK & LID LOCK LIGHT WON'T COME ON
I would suspect that your lid lock switch is faulty, or maybe it has come unplugged from the motor controller module. You can access this by removing the whole top moulding but I cannot remember now how to do this now. But it wasn't difficult. Hunt around and download a copy of the service manual and the IPB.
Sep 13, 2014 | Fisher and Paykel GWL11 Top Load Washer
Why does the lid lock light start flashing after the wash cycle and will not rinse or spin?
Lift lid, stick screwdriver into slot where lid latch-pin inserts and see if it goes into the cycle. If so, try adjusting position of latch.
Sep 01, 2014 | Washing Machines
Need to do a reset on a gw612 after changing the cold valve
There is no reset for these.
If you are getting error code 48,49,50
your motor controller board is faulty.
Feb 21, 2014 | Fisher and Paykel Fisher & Paykel Washer
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
Gw612 error code lights
the motor controller needs replacing. this fault is not servicable at home.
Sep 07, 2013 | Fisher and Paykel Fisher & Paykel Washer
Washer starts to fill stops then drains F 81 error code
Whirlpool Error - lid (F81) - Open/Close Lid
NOTE: The letter/number in () is what is saved in the computer/control memory.
lid flashes when the following conditions occur:
? User presses START with lid open.
? User presses START after 2 consecutive machine cycles without opening lid.
? The machine/motor control cannot detect the lid switch opening and closing properly.
Hope helps.
Sep 09, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Mar 09, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
166 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
