Question about Health & Beauty
Brakes locked and left one broken - Health & Beauty
My 2003 lincoln aviator key won't turn
Try looking at the Brake lights when the brakes are pressed. There is a switch on some of the brake pedal levers that sends a signal to release a Lock-out for the Ignition.
If the brake lights do not work, the brake lever switch is out of position or broken.
This is a common problem with many Ford designs and occurs when the drivers feet hit the switch.
Mar 16, 2013 | 2003 Lincoln Aviator
Rear passenger tire on ford ranger locks up when moving forward
Pull the brake drum off to see what's binding-brakes won't retract, emergency brake is stuck, a brake shoe return spring may be broken. Raise the rear and take both drums off to compare left and right side brakes and all the parts therein.
Feb 25, 2013 | Cars & Trucks
Left rear drum brake locks up and releases on my 04 dodge neon
need to check your emergency cable its probably stuck
Feb 21, 2013 | 2004 Dodge Neon
Rear left wheel locked
Have you pulled the wheel and checked the brakes yet ?
Jan 23, 2013 | Ford Transit Cars & Trucks
Rear left tire will not turn
sounds like the brake is locking up. reach under car and pull down on emergency brake cable or just wiggle it to see if it works. if not remove tire and check back brake. it could be the springs are broken or the nails that hold on the brake shoes have errode to the point where they broke. just check it out!! have a good day !!
Feb 18, 2011 | 2000 Ford Contour
Broken wires on left side break caliper
These are either Brake Pad wear sensor or Anti Lock Brake Wires.
Anti Lock ABS system will be inop' if ABS wires broken.
ABS Lamp will be on too.
Jan 14, 2011 | 2000 Volkswagen Beetle
96 chevy beretta..when braking, the left rear of the car squats, left rear tire almost seems to lock up, is this just new brakes time or something more serious?
It sounds like something in the left rear drum is causing it to lock up. It may be contaminated linings, from a leaking wheel cylinder or maybe some broken hardware. You'll have to remove the drum to take a look.
Jun 12, 2010 | 1996 Chevrolet Beretta
Left rear wheel locked up not right think it might be brakes am i right
Could be, also could be wheel bearing. Have to remove wheel and brake drum. Linkages on brake could have broken in drum causing brake to lock up.
Mar 05, 2010 | 1988 Chevrolet C1500
Ignition key won't turn
Make sure you keep your foot on the brakes while turning the stairing wheel left to right try turning the key the sametime.
Oct 19, 2009 | 2000 Saab 9-3 Viggen
Health & Beauty Logo
287 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
