Question about Maytag MER6772 Gemini Electric Kitchen Range
Hot surface indicator
My hot surface indicator light stays on and won't go off.  I have tried powering down the range as well as heating it up and cooling it off.  Any ideas?
  • 3 Answers
I have a whirlpool smooth top range, with a hot indicator for one of my elements/burner that stays on all the time. At first I could tap on the glass top and it'd go off, but then not anymore - just stayed on. Then recently, the element began to not cycle properly to provide adequate heat. I deduced the problem was likely with the limiter switch (not the infinite switch). I replaced the element (part was about $100) which had the limiter switch already integrated with it. The element works properly now.
Posted on Dec 18, 2012
  • 30 Answers
The component that controls the hot surface light is part of the element. If there is a light for each element you just replace that element. If there's one for the whole surface or each side you'll have to figure out which element is causing the problem.
Posted on Nov 14, 2007
2 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: I have a new ge range. When I turn on the left
mvek,
If you could see through the glass, you'd see "temperature sensors" located near the elements. They're very sensitive little guys, and rightly so! Their job is to detect temps and energize the warning light on the cooktop so users won't get burned.
To answer your question... It appears that there is an issue with the front left sensor (and possibly the right as well). The temp warning lamps should NEVER go off immediately. Please call for warranty repair (1-800-GE-CARES). This is an unsafe condition for you and your Family. The warning indicators are there for a reason and should indicate high temp's as long as high temp's are present.
SG
Posted on Apr 12, 2009
Hot surface indicator light stay on?
One of your surface elements is bad (the hot-element switch that is part of the element is stuck on). If each element has its own hot-light, then you know which element is bad; but if you have just 1 hot-surface indicator, your problem is figuring out which element is bad. That takes an electronic technician with patience and an ohmmeter.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 24, 2014 | Whirlpool RF378LXKS Electric Kitchen Range
Element light stays on after all power control knobs are in off position?
Good Afternoon Cindy,
I see that you are having trouble with the element light staying on after all power control knobs have been put into the off position on your Frigidaire range, model# FEF366EC. The Element ON indicator lights will glow when one or more of the surface elements are turned ON. A quick glance at these indicator lights when cooking is finished is an easy check to be sure all control knobs are turned OFF. The Hot Surface indicator light will continue to glow AFTER the control knob is turned to the OFF position and will glow until the heating surface area has cooled sufficiently. I suggest resetting your appliance by shutting the power off at your home's circuit breaker for 2-3 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "clock" button, and then you will press and hold down either the up or down arrows until the correct time appears. Try turning the burner on that the indicator light stays on the most. When you turn it off if you are still having trouble with the element light staying on, I suggest contacting a local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 27, 2014 | Frigidaire FEF366EC 30" Freestanding...
Hot surface light will not go out
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
Sep 02, 2010 | Maytag Kitchen Ranges
Hot surface indicator light stays on. the knobs
signs of a faulty hotplate sensor especially if the surface is cold
Mar 21, 2010 | Whirlpool Kitchen Ranges
Hot surface light indicator stays lit
The hot surface light is controlled by a part attached to the element called a limiter. For your model, the limiter is not available as a seperate item. The element/limiter assembly has to be replaced as a single unit. The top assembly, elements and limiters are all fragile parts.
If you are making this repair yourself, make sure the range is disconnected from it's power source prior to service.
Apr 27, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
The hot surface indicator light remains ON all the time.
Your hot surface indicator light might have a short that causes it to stay on all of the time. If you can, try unplugging it for a little while and plugging it back up. If the light is still on, you have a short. You can still use the stove, but the light staying on will not be any help to you.
Oct 22, 2008 | Frigidaire FEF366EC 30" Freestanding...
GE Spectra JBP30B0B4WH surface unit light stays on
If it's the light that indicated the element is on, replace the switch. If it's the light that indicated the element is hot, replace the element.
Jun 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
Cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Mar 08, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
Surface unit indicator light is always on
Coffy, if you are talking about the hot surface indicator lights, they are controlled by the limiter on the burner itself. When the burner heats up the limiter closes and sends power to the light (hot surface). When the burner cools the limiter is supposed to open cutting power to the hot surface indicator light. They may be stuck closed. If you are talking about the lights on the back panel, that is controlled by the infinate switch itself. Catriver
Oct 09, 2007 | Kenmore 96012 / 96014 / 96019 Electric...
Maytag MER6772 Gemini Electric Kitchen Range Logo
2,002 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
