Question about A&E CAGE CO 1011107 A&E Play Top Cage in Platinum
Does the cage come with a divider? - A&E CAGE CO 1011107 A&E Play Top Cage in Platinum
How do I remove the cage on this fan to get to the blades
look carefully at the edge of the cage, there are several different mechanisms for holding the cage together. one could be a small screw on the very bottom of the cage this can be loosened and then the front of the cage can be pried off the rear of the cage taking care not to damage any of the clips. another mechanism is hinged clips which can be swung away from the cage, sometimes requiring the use of a needle nose pliers if very tight. Some of the old Patton fans have metal prongs and these can be gently pushed in while removing the front of the cage. Basically you look carefully and figure it out. Refer to the manual which one can usually search for online.
Oct 09, 2015 | Dryers
I'm thinking about ordering the A&E Cage Co. Small Split Level Play Top Bird Cage. Can the divider be removed?
The great thing about this birdcage is that the divider can easily be removed. You can use it as a spacious one room cage without the divider or you can house two or more birds seperately by inserting the divider.
Feb 16, 2014 | Birds
When it comes to bird cages, why is size so important?
Cage size is a very crucial element in regards to proper bird care. The tail of your bird should never touch the back or bottom of the cage when sitting on their perch. A very general rule to follow is that the width of the cage should be at least 1-1/2 times as wide as your bird's wingspan. Keep in mind that it is not just your bird(s) inhabiting the cage but you will need a perch and most likely some toys. My personal recommendation is to buy the largest cage you can afford.
Aug 29, 2012 | Birds
What's a single bird cage?
The single bird cage comes in a variety of sizes and is suitable for only one bird. Check bar spacing and the width of your bird's wing span to determine the best bird cage fit. Elevate this bird cage to sit at a human's chest level.
Aug 05, 2012 | Birds
What's a travel bird cage?
The travel bird cage is usually a smaller version of a normal bird cage. The travel bird cage does not need to be large, nor does it need to be as durable as your bird cage. Be sure that your bird can comfortably fit in this cage for a short amount of time so that it will not become stressed.
What's a playtop birdcage?
The playtop bird cage provides a space for your bird to exercise and explore its freedom outside of the bird cage, and usually includes bird cage feeders as well. A solid top on the playtop bird cage is excellent for collecting food and other bird messes while the bird is on top of the bird cage.
Does the size of my cage matters for my birds?
In general, the larger and the more active the bird, the larger the cage one should use. The amount of time the bird will spend in the cage each day is also a factor. A bird that is caged most of the time requires far more space than a bird caged only at night.
What's a bird cage commonly made of?
The quality bird cages are often made of iron and the top quality are made of stainless steel. You can find other bird cages lessen in quality with low quality powder-coat or a painted finish.
How do I get a cage code
A CAGE Code is a five (5) position code that identifies companies doing or wishing to do business with the Federal Government. For more information, including how to obtain a CAGE Code, please use the link below:
http://www.dlis.dla.mil/CAGESearch/cage_faq.asp
Nov 05, 2009 | 2004 Enfield Military
A&E CAGE CO 1011107 A&E Play Top Cage in Platinum Logo
65 people viewed this question
Top A&E CAGE CO 1011107 Birds Experts
DaveMc3
DaveMc3
Heartland Ho
Level 1 Expert
Tom Chichester
Are you an A&E CAGE CO 1011107 Bird Expert? Answer questions, earn points and help others
