I have white hazey lines down each side of the screen
I have hazey lines down each side of the screen, I have a arial lead from the house to the projector the lead is 50 metres long
SOURCE: White vertical line on left side of screen
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Posted on Mar 06, 2008
SOURCE: Projector shows only 50% of the computer screen
mine does the same thing but i can see the whole screen it's just half height full width, above solution about zooming to 1X is what i've been doing to fix it for the last 6 months, needs to be done every time I turn the power back on. Anybody know of a more perminate fix?
Now my power supply has gone have the projector in pieces, found a failed on transistor but because it's over heated can't read of it what type it was....
Already replaced two blown diodes in the main H-bridge
Looks like one coil will need rewinding.
If anybody has one in pieces I would be great if you can help me work out what the blown transistor was.
Posted on Mar 25, 2008
Marrie
  • 563 Answers
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Posted on Apr 01, 2008
  • 1170 Answers
SOURCE: Vertical line white, regular, blinking.
I don't think it's the bulb. Sounds like an LCD panel issue. Maybe one or more of the 3 LCD panels is either not working right or the unit has been dropped/jarred and the panels have moved (All three have to line up right optically to give the right colours). You need to take the projector to a qualified service centre.
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Posted on Apr 01, 2009
SOURCE: my toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Posted on Aug 21, 2009
What wires goes on Load and Line. on a clipsal rotary light dimmer
In normal house wiring, 110 vac, the black lead is considered the "hot" or line lead and the white one as the neutral. When wiring to a variable resistor, the variable lead normally goes to the load so the voltage can be changed and the other lead to the "line."
Feb 13, 2015 | Rotary Electrical Supplies
White line down side of screen
When the line is not there--go to a unused video input and examine the screen in that area--if you see a slightly darker area where the line was--it has permanently burned a mark in the screen itself.
Apr 25, 2012 | Samsung Televison & Video
The LCD has gone blue with some lines how do I solve it Nokia 5310
hello there!
The blank white screen or blue screen.on your phone indicates that the screen on your phone is bad,hence there is no display whatsoever on the screen.
The solution is to replace the screen with a newly purchased screen, Ensure you purchase the screen that is compatible with your phone.
thank you for choosing fixya and please rate my post!
Jan 25, 2012 | Nokia 5310 Cellular Phone
I have a white line running down the centre of my tv screen. It is a jvc and dvd combo. the dvd player is on the side of the screen
If you are having a white line in the middle of the screen and sound it an indication that you have blown the vertical deflection amplifier. Don not switch on the TV till you get it fixed as you can damage the picture tube in the central area permanently.
It is a 11 lead IC mounted on an a aluminum heat sink. Will cost you about less than 10$ plus labor to replace.
Jul 15, 2011 | JVC AV-32020 32" TV
I have 5 Hampton Bay ceiling fans originally installed in my 2001 home. 3 have light kits and work great. I am trying to install lights on the remaining 2 but get no power. The 2 wires (blue and white)...
The supply power to the fan from the house should be HOT 24 / 7. The two lines going to the fan normally have wire nuts for connecting the leads on the fan to the house power supply line and the house common line. You want to tie the blue line on the light into the same wire nut that goes to the Fan switch. White is COMMON. Just add the lights COMMON (White) line to the wire nut that has the other two white lines in it. The blue goes to the Power line from the house. Add it to the BLACK (HOT) lines wire nut that has the fans wire in it. Use your meter to be sure of what color is common and witch is hot. If you have any trouble, let me know in detail what all the colors are from the house, fan and light. I'll put it in order for you. thank you. Please vote. Roger
Apr 14, 2011 | Hampton Bay Heating & Cooling
Need to change the pass word
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial; min-height: 15.0px} p.p3 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 16.0px; font: 13.0px Arial} p.p6 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 16.0px; font: 12.0px Helvetica; min-height: 14.0px} li.li3 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 16.0px; font: 13.0px Arial} li.li4 {margin: 0.0px 0.0px 4.0px 0.0px; line-height: 18.0px; font: 13.0px Arial} li.li5 {margin: 0.0px 0.0px 4.0px 0.0px; line-height: 15.0px; font: 13.0px Arial} span.s1 {font: 13.0px 'Lucida Grande'} span.s2 {font: 11.0px Arial} ul.ul1 {list-style-type: none}
the only way to change the password is to either login to the router and
All Belkin Router's ship without an admin password. If you require an admin password then follow the below instructions.
Setup steps:
  • Connect the computer to one of the four LAN ports on the router.
  • Open a web browser on the computer.
  • In the address bar of the web browser, type http://192.168.2.1
  • Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  • Click on System Settings under Utilities on the left-hand side of the opened page.
  • You will see a feature called, "Administrator Password". Type in your current password (default leave blank).
  • Click "Apply Changes". Your new password is now active.
if you dont know your password then you have to reset the router to factory settings
Setup steps:
  • Locate the reset hole on the router. The button will be on the back or side of the router.
    See images below:
  • Leave the router powered on.
  • Use a paperclip (or similar) to press and hold in the reset button for 10 seconds.
  • Remove the paperclip.
  • Wait approximately one minute for the router to restart.
Mar 06, 2011 | Belkin (F5D5231-4) Router
Infocus DP8400x blue hazey line
this discoloration is the begining of the lcd panel being thermal damaged. this happens when the projector is being used for a long period of time and then being shut off using the switch on the rear of the projector instead of the on/off on top or the remote. to fix it it will have to be replaced. very expensive major repair.
Jul 11, 2010 | InFocus DP8400X LCD Projector
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
Hi i own a samsung digimax i5 when i take the snap inside
Scene too bright, or white balance not set correctly or shutter not held down halfway to get camera set for a picture. White screen means excessive brightness.
Dec 10, 2008 | Samsung Digimax i5 Digital Camera
69 people viewed this question
k24674
jasbo
jasbo
