Question about Hickory Hardware 1-1/2 In. Statuary Bronze Small Magnetic Catch - BEL-P650-STB
How many catches are in this package? - Hickory Hardware 1-1/2 In. Statuary Bronze Small Magnetic Catch - BEL-P650-STB
How to change rear brake pads on 2012 dodge caravan
could be seized or over extended and catching somewhere. May need to be screwed in not just pushed in.
Aug 01, 2014 | 2012 Dodge Grand Caravan American Value...
Need assitance catching up on mortage payment
Make more money and make the payment
Oct 17, 2013 | Computers & Internet
Security
As a free anti-malware (anti-virus) that will actively catch malware as it comes to your system, I actually recommend Microsoft Security Essentials. I would also install Malwarebytes Anti-Malware (the free version does not run in the background) so you can do virus scans when you want if you think something may have gotten past the Microsoft tool.
Jun 13, 2013 | Microsoft Windows XP Home Edition
Paper feed
Make sure your paper is not curved. Fan the paper and make sure it sits in the hopper evenly. Also make sure that when you were installing the printer you did not drop something or a piece of the packaging is not stuck in the side. Use a flash light to inspect the paper path
May 28, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Norton 360
Yes, and there's little you can do about. None of the commercial packages is 100% perfect all the time, the malware writers try to stay one step ahead.
Oct 31, 2009 | Symantec Norton 360 Version 2.0 for PC
Need to move front passenger seat much further back
the only way to do this is to take the seat out remove it from the rails take the rails to a machine shop and have them weld on extensions for the seat to slide on. you will also have to remove the rear seat stop so it will go further back and have them make catches in the extension for the seat to catch onto.
Aug 28, 2009 | 2004 Ford F350
2002 2500 Silverado tailgate handle will not release catches
You will need to remove the trim piece the is under the release handle. Be carefull those things tend to break the little tabs that hold them on. Anyway pop (pry) it off with a screwdriver. Once it is off you can see that the little clips that hold the rods to the handle assy are broke. These clips are color coded. Most likely yellow or green. You might be able to get them at say Pep Boys or some place like that but they might make you buy an assortment package , then you get clips you will never use. Good luck, hope this is helpfull.
Feb 11, 2009 | 2002 Chevrolet Silverado 2500HD
Oil
Warm the engine to ensure maximum oil drainage. Steady the bike on a stand or secure jack, as close to level as possible. Ensure the availability of a pan that can contain at least three litres of oil, with enough extra room to lift and move the pan. Slide the catch pan under the center of the oil pan, and remove the large oil drain plug from the center of the oil pan. If the catch pan is large enough to reach the oil filter, loosen the filter at the same time to allow better flow. Once the oil has finished draining from the plug hole, replace the plug and torque to setting. Remove the oil filter. Apply a film of oil to the gasket of a new filter, and install the new filter as per the manufacturer recommend tightness as listed on the package. Remove the oil filler plug on the left side of the engine case and pour 3 litres of 10W40 or 20W50 (depending on climate). Replace the oil filler plug.
Nov 10, 2008 | 2003 kawasaki VN 800 Vulcan Drifter
Hickory Hardware 1-1/2 In. Statuary Bronze Small Magnetic Catch - BEL-P650-STB Logo
219 people viewed this question
Top Hickory Hardware Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hickory Hardware Hardware and Accessory Expert? Answer questions, earn points and help others
